[Geoserver-devel] Build failed in Jenkins: geoserver-master #497
See <http://ares.opengeo.org/jenkins/job/geoserver-master/497/&gt;
[...truncated 70903 lines...]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Change compile target to 1.7
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 13.05.2014 @ 00:02:48 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-May-2014 08:25
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2014 @ 08:31:37 UTC
[INFO] [GitCommitIdMojo] build.branch = 9d5b648f04ad7b153f60562f9c5cbc330c275c75
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 9d5b648
[INFO] [GitCommitIdMojo] build.commit.id = 9d5b648f04ad7b153f60562f9c5cbc330c275c75
[INFO] [GitCommitIdMojo] build.commit.message.full = Change compile target to 1.7
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-sample-data-access:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sample-data-access:12-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/12-SNAPSHOT/gt-validation-12-SNAPSHOT.jar
[INFO] No sources to compile
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/src/test/resources&gt;
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.6-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.6-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.6-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.6-SNAPSHOT/gs-sample-data-access-test-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.6-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.6-SNAPSHOT/gs-sample-data-access-test-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.6-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.6-SNAPSHOT/gs-sample-data-access-test-2.6-SNAPSHOT-test-sources.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-sample-data-access-test/2.6-SNAPSHOT/gs-sample-data-access-test-2.6-SNAPSHOT.jar
2398/?
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:gs-sample-data-access-test'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:gs-sample-data-access-test:2.6-SNAPSHOT'
[INFO] Uploading project information for gs-sample-data-access-test 2.6-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-sample-data-access-test/2.6-SNAPSHOT/gs-sample-data-access-test-2.6-SNAPSHOT-tests.jar
4096/?
8192/?
11121/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-sample-data-access-test/2.6-SNAPSHOT/gs-sample-data-access-test-2.6-SNAPSHOT-test-sources.jar
4096/?
5572/?
[INFO] Building ArcSDE DataStore Extension
[INFO] task-segment: [deploy]
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2014 @ 08:31:42 UTC
[INFO] Copying 3 resources
[INFO] Copying 10 resources
[INFO] snapshot org.geotools:gt-arcsde-common:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde-common:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:arcsde-plugin:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcsde:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-sde-dummy:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sde-dummy:12-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/src/test/resources&gt;
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/test-classes&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.6-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.6-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.6-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.6-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.6-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-arcsde/2.6-SNAPSHOT/gs-arcsde-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.6-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-arcsde/2.6-SNAPSHOT/gs-arcsde-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.6-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-arcsde/2.6-SNAPSHOT/gs-arcsde-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.6-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-arcsde/2.6-SNAPSHOT/gs-arcsde-2.6-SNAPSHOT-test-sources.jar
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-arcsde/2.6-SNAPSHOT/gs-arcsde-2.6-SNAPSHOT.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
29468/?
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:gs-arcsde:2.6-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:gs-arcsde'
[INFO] Uploading project information for gs-arcsde 2.6-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-arcsde/2.6-SNAPSHOT/gs-arcsde-2.6-SNAPSHOT-tests.jar
4096/?
8192/?
9756/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-arcsde/2.6-SNAPSHOT/gs-arcsde-2.6-SNAPSHOT-sources.jar
4096/?
8192/?
12288/?
16384/?
16645/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-arcsde/2.6-SNAPSHOT/gs-arcsde-2.6-SNAPSHOT-test-sources.jar
3380/?
[INFO] Building GeoSearch Index Module
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2014 @ 08:31:53 UTC
[INFO] Copying 9 resources
[INFO] Compiling 12 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/geosearch/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/geosearch/src/main/java/org/geoserver/geosearch/rest/GeoSearchLayer.java&gt;:\[29,29\] error: cannot access ServiceException
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 5 minutes 59 seconds
[INFO] Finished at: Tue May 13 08:31:57 UTC 2014
[INFO] Final Memory: 87M/421M
See <http://ares.opengeo.org/jenkins/job/geoserver-master/498/&gt;
[...truncated 20478 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 13-May-2014 11:41
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2014 @ 12:20:23 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-restconfig ---
[INFO] Copying 37 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-restconfig ---
[INFO] Compiling 77 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/classes&gt;
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.591 sec
Running org.geoserver.gwc.GWCTransactionListenerTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.262 sec
Running org.geoserver.gwc.RESTIntegrationTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-restconfig ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-restconfig ---
[INFO] Compiling 33 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/test-classes&gt;
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.912 sec
Running org.geoserver.gwc.ResponseUtilsURLManglerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.gwc.config.GWCConfigPersisterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.073 sec
Running org.geoserver.gwc.config.GWCConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.11 sec
Running org.geoserver.gwc.config.GWCInitializerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.16 sec
Running org.geoserver.gwc.layer.CatalogConfigurationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.874 sec
Running org.geoserver.gwc.layer.CatalogLayerEventListenerTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.621 sec
Running org.geoserver.gwc.layer.CatalogStyleChangeListenerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
Running org.geoserver.gwc.layer.DefaultTileLayerCatalogTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.gwc.layer.GeoServerTileLayerInfoPersistenceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.091 sec
Running org.geoserver.gwc.layer.GeoServerTileLayerTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.473 sec
Running org.geoserver.gwc.layer.LegacyTileLayerInfoLoaderTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.gwc.layer.TileLayerInfoUtilTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.geoserver.gwc.wms.CachingExtendedCapabilitiesProviderTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-restconfig ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt;
T E S T S
Running org.geoserver.catalog.rest.AdminRequestTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.051 sec
Results :
Failed tests: testCachingHeadersNestedLayerGroup(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
  testCachingHeadersFlatLayerGroup(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
Tests run: 153, Failures: 2, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.177s]
[INFO] Core Platform Module .............................. SUCCESS [17.383s]
[INFO] Open Web Service Module ........................... SUCCESS [20.378s]
[INFO] Main Module ....................................... SUCCESS [4:40.157s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.151s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [2:37.754s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:03.677s]
[INFO] Web Coverage Service Module ....................... SUCCESS [9.324s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [2:00.852s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2:29.040s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [3:30.843s]
[INFO] Web Feature Service Module ........................ SUCCESS [9:34.620s]
[INFO] Web Map Service Module ............................ SUCCESS [10:37.182s]
[INFO] KML support for GeoServer ......................... SUCCESS [2:33.558s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [4:11.371s]
[INFO] REST Support Module ............................... SUCCESS [1:12.426s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.309s]
[INFO] Core UI Module .................................... SUCCESS [4:48.925s]
[INFO] WFS UI Module ..................................... SUCCESS [1:20.171s]
[INFO] Security UI Modules ............................... SUCCESS [1.029s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.286s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.876s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.197s]
[INFO] Printing Module ................................... SUCCESS [1:07.763s]
[INFO] Application Schema Support ........................ SUCCESS [0.185s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [1:08.866s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [56.230s]
[INFO] H2 DataStore Extension ............................ SUCCESS [41.325s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.379s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.693s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.539s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.626s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.468s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.645s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [1:08.333s]
[INFO] Excel Output Format ............................... SUCCESS [1:12.257s]
[INFO] Validation Module ................................. SUCCESS [7.053s]
[INFO] Chart external graphics support ................... SUCCESS [1.393s]
[INFO] Feature Generalization Extension .................. SUCCESS [9.521s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.022s]
[INFO] OWS request flow controller ....................... SUCCESS [48.377s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.385s]
[INFO] Web Processing Service Module ..................... SUCCESS [7:54.472s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [1:31.585s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [8.030s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [1.868s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [1:15.643s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.679s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [47.054s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [51.825s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.378s]
[INFO] DXF output format ................................. SUCCESS [1:15.735s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.289s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 39:42.332s (Wall Clock)
[INFO] Finished at: Tue May 13 12:21:10 UTC 2014
[INFO] Final Memory: 60M/231M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.opengeo.org/jenkins/job/geoserver-master/499/changes&gt;
Changes:
[jody.garnett] Call GeoTools init and suppress JAI warnings
[...truncated 20952 lines...]
  at java.lang.reflect.Method.invoke(Method.java:606)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:775)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:273)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1427)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1446)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1381)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:930)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:913)
  at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:898)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1224)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1159)
  at org.geoserver.catalog.rest.CoverageTest.testPostAsXML(CoverageTest.java:184)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
  at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
  at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
  ... 97 more
./target/default4377593367174807795data/temp/wcs/usa_20988817054163867.tif
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.664 sec
Running org.geoserver.catalog.rest.DataStoreFileResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.683 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.101 sec
Running org.geoserver.catalog.rest.DataStoreFileUploadTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.975s]
[INFO] Core Platform Module .............................. SUCCESS [14.984s]
[INFO] Open Web Service Module ........................... SUCCESS [16.400s]
[INFO] Main Module ....................................... SUCCESS [2:56.566s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.681s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:21.806s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [48.050s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.999s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.507s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.947s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:00.234s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:36.956s]
[INFO] Web Map Service Module ............................ SUCCESS [5:02.984s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.549s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [2:31.446s]
[INFO] REST Support Module ............................... SUCCESS [44.747s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.214s]
[INFO] Core UI Module .................................... SUCCESS [2:31.583s]
[INFO] WFS UI Module ..................................... SUCCESS [49.276s]
[INFO] Security UI Modules ............................... SUCCESS [0.241s]
[INFO] Community Space ................................... SUCCESS [0.234s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.558s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.191s]
[INFO] Printing Module ................................... SUCCESS [38.046s]
[INFO] Application Schema Support ........................ SUCCESS [0.276s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.322s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.505s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.786s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.169s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.593s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.442s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.846s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.997s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.424s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.219s]
[INFO] Excel Output Format ............................... SUCCESS [38.726s]
[INFO] Validation Module ................................. SUCCESS [4.812s]
[INFO] Chart external graphics support ................... SUCCESS [1.282s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.840s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.804s]
[INFO] OWS request flow controller ....................... SUCCESS [27.331s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.321s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:13.205s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.847s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.320s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.193s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.920s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.321s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.741s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [23.792s]
[INFO] DXF output format ................................. SUCCESS [0.482s]
[INFO] DXF output format ................................. SUCCESS [39.225s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.283s]
[INFO] Total time: 22:20.005s (Wall Clock)
[INFO] Finished at: Tue May 13 13:20:45 UTC 2014
[INFO] Final Memory: 61M/339M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/500/changes&gt;
Changes:
[andrea.aime] Adding log config and connection validation to wfs 1.0 too
[...truncated 20781 lines...]
  ... 97 more
./target/default2486668147822693337data/temp/wcs/usa_21005982860619506.tif
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.945 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.169 sec
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.382 sec
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.24 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.053 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.857 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.286 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.359 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.064 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.062 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.831 sec
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.478 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.438 sec
Running org.geoserver.catalog.rest.DataStoreTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.711 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.502 sec
Running org.geoserver.catalog.rest.FeatureTypeTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.199s]
[INFO] Core Platform Module .............................. SUCCESS [19.182s]
[INFO] Open Web Service Module ........................... SUCCESS [22.753s]
[INFO] Main Module ....................................... SUCCESS [3:06.244s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.745s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:21.885s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.706s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.284s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:06.491s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:16.875s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.753s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:24.762s]
[INFO] Web Map Service Module ............................ SUCCESS [5:07.693s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.126s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [2:30.279s]
[INFO] REST Support Module ............................... SUCCESS [50.545s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.450s]
[INFO] Core UI Module .................................... SUCCESS [3:03.484s]
[INFO] WFS UI Module ..................................... SUCCESS [42.906s]
[INFO] Security UI Modules ............................... SUCCESS [0.531s]
[INFO] Community Space ................................... SUCCESS [0.318s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.860s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.352s]
[INFO] Printing Module ................................... SUCCESS [36.454s]
[INFO] Application Schema Support ........................ SUCCESS [0.665s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.039s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.122s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.648s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.317s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.564s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.490s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.553s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.150s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.737s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [39.332s]
[INFO] Excel Output Format ............................... SUCCESS [40.551s]
[INFO] Validation Module ................................. SUCCESS [3.773s]
[INFO] Chart external graphics support ................... SUCCESS [4.848s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.225s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.909s]
[INFO] OWS request flow controller ....................... SUCCESS [30.141s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.337s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:11.230s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [56.988s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.573s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.168s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.142s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.514s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.076s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.612s]
[INFO] DXF output format ................................. SUCCESS [0.393s]
[INFO] DXF output format ................................. SUCCESS [38.711s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.381s]
[INFO] Total time: 23:33.735s (Wall Clock)
[INFO] Finished at: Tue May 13 18:07:01 UTC 2014
[INFO] Final Memory: 61M/341M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/501/&gt;
[...truncated 3738 lines...]
  at org.geoserver.ows.util.OwsUtils.get(OwsUtils.java:153)
  at org.geoserver.ows.util.OwsUtilsTest.testExtended(OwsUtilsTest.java:31)
  at junit.framework.TestCase.runTest(TestCase.java:176)
  at junit.framework.TestCase.runBare(TestCase.java:141)
  at junit.framework.TestResult$1.protect(TestResult.java:122)
  at junit.framework.TestResult.runProtected(TestResult.java:142)
  at junit.framework.TestResult.run(TestResult.java:125)
  at junit.framework.TestCase.run(TestCase.java:129)
  at junit.framework.TestSuite.runTest(TestSuite.java:255)
  at junit.framework.TestSuite.run(TestSuite.java:250)
  at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:84)
testSimple(org.geoserver.ows.util.OwsUtilsTest) Time elapsed: 0 sec <<< ERROR!
java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  at org.geotools.util.SoftValueHashMap.isValid(SoftValueHashMap.java:152)
  at org.geotools.util.SoftValueHashMap.retainStrongly(SoftValueHashMap.java:267)
  at org.geotools.util.SoftValueHashMap.put(SoftValueHashMap.java:300)
  at org.geoserver.ows.util.OwsUtils.classProperties(OwsUtils.java:90)
  at org.geoserver.ows.util.OwsUtils.getter(OwsUtils.java:203)
  at org.geoserver.ows.util.OwsUtilsTest.testSimple(OwsUtilsTest.java:18)
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.031 sec <<< FAILURE!
testParseServiceException(org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest) Time elapsed: 25 sec <<< ERROR!
  at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:183)
  at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:190)
  at org.geotools.xml.impl.ElementHandlerImpl.startElement(ElementHandlerImpl.java:186)
  at org.geotools.xml.impl.ParserHandler.startElement(ParserHandler.java:694)
  at org.apache.xalan.transformer.TransformerIdentityImpl.startElement(TransformerIdentityImpl.java:1072)
  at org.apache.xml.serializer.TreeWalker.startNode(TreeWalker.java:357)
  at org.apache.xml.serializer.TreeWalker.traverse(TreeWalker.java:143)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:389)
  at org.geotools.xml.DOMParser.parse(DOMParser.java:89)
  at org.geotools.xml.test.XMLTestSupport.parse(XMLTestSupport.java:297)
  at org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest.testParseServiceException(ExceptionReportBindingTest.java:46)
Results :
Tests in error:
  testHandleServiceExceptionEncoding(org.geoserver.ows.DefaultServiceExceptionHandlerTest): org/geotools/util/SoftValueHashMap$Reference
  testHandleServiceExceptionCauses(org.geoserver.ows.DefaultServiceExceptionHandlerTest): org/geotools/util/SoftValueHashMap$Reference
  testHandleServiceExceptionEncodingMore(org.geoserver.ows.DefaultServiceExceptionHandlerTest): org/geotools/util/SoftValueHashMap$Reference
  testHandleServiceException(org.geoserver.ows.DefaultServiceExceptionHandlerTest): org/geotools/util/SoftValueHashMap$Reference
  testErrorSavedOnRequestOnGenericException(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
  testDirectInvocationService(org.geoserver.ows.DispatcherTest): Error creating bean with name 'dispatcher' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  testHelloOperationGet(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  testReadContextAndPath(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
  testErrorSavedOnRequestOnNon304ErrorCodeException(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
  testHelloOperationMixed(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  testHttpErrorCodeException(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  testDispatchWithNamespace(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  testNoErrorOn304ErrorCodeException(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
  testReadOpContext(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
  testParseKVP(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  testParseXML(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  testHelloOperationPost(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
  testEncode(org.geoserver.ows.XmlObjectEncodingResponseTest): org/geotools/util/SoftValueHashMap$Reference
  testOutOfOrderSequence(org.geoserver.ows.kvp.ElevationKvpParserTest): org/geotools/util/Range
  testMixed(org.geoserver.ows.kvp.ElevationKvpParserTest): org/geotools/util/Range
  testPeriod(org.geoserver.ows.kvp.ElevationKvpParserTest): org/geotools/util/Range
  initializationError(org.geoserver.ows.kvp.TimeKvpParserTest): org/geotools/util/DateRange
  testPut(org.geoserver.ows.util.OwsUtilsTest): org/geotools/util/SoftValueHashMap$Reference
  testExtended(org.geoserver.ows.util.OwsUtilsTest): org/geotools/util/SoftValueHashMap$Reference
  testSimple(org.geoserver.ows.util.OwsUtilsTest): org/geotools/util/SoftValueHashMap$Reference
  testParseServiceException(org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest): org/geotools/util/SoftValueHashMap$Reference
Tests run: 46, Failures: 0, Errors: 26, Skipped: 0
[INFO]
[INFO] GeoServer ......................................... SUCCESS [11.492s]
[INFO] Core Platform Module .............................. SUCCESS [26.399s]
[INFO] Open Web Service Module ........................... FAILURE [23.502s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [1.528s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.939s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.711s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.703s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.037s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.942s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.643s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.803s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.179s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.788s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.259s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.121s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.291s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.321s]
[INFO] DXF output format ................................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.412s]
[INFO] Total time: 1:08.348s (Wall Clock)
[INFO] Finished at: Tue May 13 21:51:09 UTC 2014
[INFO] Final Memory: 36M/242M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-ows: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
See <http://ares.opengeo.org/jenkins/job/geoserver-master/502/&gt;
[...truncated 20797 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
  at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
  at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
  at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
  at com.sun.media.jai.mlib.MlibWarpRIF.create(MlibWarpRIF.java:65)
  at sun.reflect.GeneratedMethodAccessor170.invoke(Unknown Source)
  at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
  at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
  at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
  at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
  at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
  at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
  at javax.media.jai.RenderedOp.getRendering(RenderedOp.java:888)
  at javax.media.jai.RenderedOp$1.getPropertyNames(RenderedOp.java:1791)
  at javax.media.jai.PropertyEnvironment.mapDefaults(PropertyEnvironment.java:270)
  at javax.media.jai.PropertyEnvironment.getPropertyNames(PropertyEnvironment.java:125)
  at javax.media.jai.WritablePropertySourceImpl.addProperties(WritablePropertySourceImpl.java:298)
  at javax.media.jai.RenderedOp.createPropertySource(RenderedOp.java:1817)
  at javax.media.jai.RenderedOp.setProperty(RenderedOp.java:2034)
  at org.geotools.coverage.processing.operation.Resampler2D.reproject(Resampler2D.java:717)
  at org.geotools.coverage.processing.operation.Resample.doOperation(Resample.java:258)
  at org.vfny.geoserver.util.WCSUtils.resample(WCSUtils.java:132)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:550)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at com.sun.proxy.$Proxy30.getCoverage(Unknown Source)
  ... 97 more
./target/default8297134689742666839data/temp/wcs/usa_21025480876749477.tif
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.301 sec
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.542s]
[INFO] Core Platform Module .............................. SUCCESS [14.968s]
[INFO] Open Web Service Module ........................... SUCCESS [16.003s]
[INFO] Main Module ....................................... SUCCESS [2:56.610s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.739s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:23.195s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [50.111s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.377s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [59.101s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.297s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.844s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:05.308s]
[INFO] Web Map Service Module ............................ SUCCESS [5:22.250s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:29.075s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [2:33.637s]
[INFO] REST Support Module ............................... SUCCESS [49.386s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.793s]
[INFO] Core UI Module .................................... SUCCESS [2:31.554s]
[INFO] WFS UI Module ..................................... SUCCESS [46.965s]
[INFO] Security UI Modules ............................... SUCCESS [0.275s]
[INFO] Community Space ................................... SUCCESS [0.236s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.241s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.182s]
[INFO] Printing Module ................................... SUCCESS [39.220s]
[INFO] Application Schema Support ........................ SUCCESS [0.237s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.956s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.344s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.346s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.196s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.637s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.351s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.418s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.941s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.471s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.960s]
[INFO] Excel Output Format ............................... SUCCESS [39.897s]
[INFO] Validation Module ................................. SUCCESS [4.958s]
[INFO] Chart external graphics support ................... SUCCESS [1.534s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.532s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.821s]
[INFO] OWS request flow controller ....................... SUCCESS [27.635s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.414s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:28.431s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.850s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.225s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.348s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [45.832s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.386s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.569s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.949s]
[INFO] DXF output format ................................. SUCCESS [0.288s]
[INFO] DXF output format ................................. SUCCESS [38.710s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.273s]
[INFO] Total time: 22:50.375s (Wall Clock)
[INFO] Finished at: Tue May 13 23:31:42 UTC 2014
[INFO] Final Memory: 61M/253M
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.803 sec
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/503/&gt;
