[Geoserver-devel] Build failed in Jenkins: geoserver-master #4999
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4999/&gt;
[...truncated 54860 lines...]
  at com.sun.jndi.ldap.LdapCtx.c_destroySubcontext(LdapCtx.java:868)
  at com.sun.jndi.toolkit.ctx.ComponentContext.p_destroySubcontext(ComponentContext.java:669)
  at com.sun.jndi.toolkit.ctx.PartialCompositeContext.destroySubcontext(PartialCompositeContext.java:354)
  at javax.naming.InitialContext.destroySubcontext(InitialContext.java:485)
  at org.geoserver.security.ldap.LDAPTestUtils.clearSubContexts(LDAPTestUtils.java:213)
  at org.geoserver.security.ldap.LDAPTestUtils.clearSubContexts(LDAPTestUtils.java:181)
  at org.geoserver.security.ldap.LDAPTestUtils.cleanAndSetup(LDAPTestUtils.java:251)
  at org.geoserver.security.ldap.LDAPTestUtils.initLdapServer(LDAPTestUtils.java:125)
  at org.geoserver.security.ldap.LDAPUserGroupServiceTest.createUserGroupService(LDAPUserGroupServiceTest.java:44)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
25 Aug 08:27:27 WARN [ldap.LdapProtocolHandler] - Null LdapSession given to cleanUpSession.
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
25 Aug 08:27:34 ERROR [registries.DefaultAttributeTypeRegistry] - attributeType w/ OID 2.5.4.16 not registered!
javax.naming.ContextNotEmptyException: [LDAP: error code 66 - NOT_ALLOWED_ON_NON_LEAF: failed for Del request
        Entry : '2.5.4.11=people,0.9.2342.19200300.100.1.25=example,0.9.2342.19200300.100.1.25=com'
: null]; remaining name 'ou=People,dc=example,dc=com'
  at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3170)
  at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:3081)
  at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2888)
25 Aug 08:27:35 WARN [ldap.LdapProtocolHandler] - Null LdapSession given to cleanUpSession.
Tests run: 13, Failures: 0, Errors: 0, Skipped: 13, Time elapsed: 115.706 sec
Results :
Tests run: 35, Failures: 0, Errors: 0, Skipped: 35
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-ldap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/target/gs-sec-ldap-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-ldap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/target/gs-sec-ldap-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-ldap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/target/gs-sec-ldap-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-ldap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/target/gs-sec-ldap-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-ldap ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/target/gs-sec-ldap-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.12-SNAPSHOT/gs-sec-ldap-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.12-SNAPSHOT/gs-sec-ldap-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/target/gs-sec-ldap-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.12-SNAPSHOT/gs-sec-ldap-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/target/gs-sec-ldap-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.12-SNAPSHOT/gs-sec-ldap-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/security/ldap/target/gs-sec-ldap-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.12-SNAPSHOT/gs-sec-ldap-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 43.429 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.568 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 21.121 s]
[INFO] Main Module ........................................ SUCCESS [03:28 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.268 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:01 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [07:00 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.239 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 30.846 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 37.635 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:16 min]
[INFO] Web Feature Service Module ......................... FAILURE [01:56 min]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 20.712 s]
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.277 s]
[INFO] Core UI Module ..................................... SUCCESS [01:41 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.275 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.235 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 23.634 s]
[INFO] Community Space .................................... SUCCESS [ 0.160 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.097 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 16.584 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.499 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.683 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.824 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.509 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.879 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.275 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.076 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.595 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.103 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 1.081 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.705 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.788 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.607 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.158 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.283 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 18.775 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.716 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 49.647 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.502 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.032 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.031 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 24.511 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 15.725 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 31.108 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 14:14 min (Wall Clock)
[INFO] Finished at: 2017-08-25T08:27:39+00:00
[INFO] Final Memory: 112M/645M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5000/changes&gt;
Changes:
[nuno.oliveira] [GEOS-8263] Allow in layer preview filtering (CQL, OGC and FeatureID)
[...truncated 86102 lines...]
Aug 25, 2017 10:01:38 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Aug 25, 2017 10:01:38 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Aug 25, 2017 10:01:38 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Aug 25, 2017 10:01:38 AM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Aug 25, 2017 10:01:38 AM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
Aug 25, 2017 10:01:39 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Aug 25, 2017 10:01:39 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Aug 25, 2017 10:01:39 AM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Aug 25, 2017 10:01:39 AM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Aug 25, 2017 10:01:39 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 18 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 12 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.861 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-test-sources.jar
Aug 25, 2017 10:01:41 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.216 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [01:29 min]
[INFO] Core Platform Module ............................... SUCCESS [ 35.543 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 38.810 s]
[INFO] Main Module ........................................ SUCCESS [03:12 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.731 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:02 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [06:03 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 9.134 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 34.936 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 37.145 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:09 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:10 min]
[INFO] Web Map Service Module ............................. FAILURE [03:24 min]
[INFO] gs-rest ............................................ SUCCESS [ 22.500 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.620 s]
[INFO] Core UI Module ..................................... SUCCESS [01:54 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.425 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 17.692 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.421 s]
[INFO] Printing Module .................................... SUCCESS [ 18.979 s]
[INFO] Community Space .................................... SUCCESS [ 3.981 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.254 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 31.565 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 15.560 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 8.921 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.458 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.797 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.734 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.331 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.774 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.236 s]
[INFO] OGR CORE ........................................... SUCCESS [ 14.673 s]
[INFO] OGR WFS ............................................ SUCCESS [ 11.327 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.314 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:59 min]
[INFO] OGR WPS ............................................ SUCCESS [ 20.988 s]
[INFO] Excel Output Format ................................ SUCCESS [ 19.572 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.498 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.171 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.776 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 12.340 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 28.199 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 19.124 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.675 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.307 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.330 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 15.681 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.390 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 57.674 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.568 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.259 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 16.525 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.366 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.238 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 30.677 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 17.069 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 27.413 s]
[INFO] Total time: 19:54 min (Wall Clock)
[INFO] Finished at: 2017-08-25T10:01:43+00:00
[INFO] Final Memory: 116M/557M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Already reverted this commit, working on it ... sorry for the spam.
Changes:
Members [1] {
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
  The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5001/changes&gt;
