See <http://ares.opengeo.org/jenkins/job/geoserver-master/505/changes>
Changes:
[Ben.Caradoc-Davies] [GEOS-6482] Scale line pixel wrong location causes failure in GetMapIntegrationTest
[...truncated 27345 lines...]
testTimeMosaicManual(org.geoserver.importer.rest.RESTDataTest) Time elapsed: 103 sec <<< ERROR!
org.springframework.web.util.NestedServletException: Handler processing failed; nested exception is java.lang.NoClassDefFoundError: org/opengis/coverage/grid/GridCoordinates
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:972)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1427)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1446)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1381)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1363)
at org.geoserver.importer.rest.RESTDataTest.postNewTaskAsMultiPartForm(RESTDataTest.java:436)
at org.geoserver.importer.rest.RESTDataTest.testTimeMosaicManual(RESTDataTest.java:308)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.lang.NoClassDefFoundError: org/opengis/coverage/grid/GridCoordinates
at org.geotools.gce.image.WorldImageReader.getHRInfo(WorldImageReader.java:312)
at org.geotools.gce.image.WorldImageReader.<init>(WorldImageReader.java:263)
at org.geotools.gce.image.WorldImageFormat.getReader(WorldImageFormat.java:345)
at org.geotools.gce.image.WorldImageFormat.getReader(WorldImageFormat.java:162)
at org.geotools.gce.image.WorldImageFormat.getReader(WorldImageFormat.java:56)
at org.geoserver.importer.GridFormat.gridReader(GridFormat.java:126)
at org.geoserver.importer.mosaic.Mosaic.newSpatialFile(Mosaic.java:103)
at org.geoserver.importer.Directory.prepare(Directory.java:182)
at org.geoserver.importer.mosaic.Mosaic.prepare(Mosaic.java:59)
at org.geoserver.importer.Importer.addTasks(Importer.java:338)
at org.geoserver.importer.Importer.update(Importer.java:324)
at org.geoserver.importer.rest.TaskResource.acceptData(TaskResource.java:105)
at org.geoserver.importer.rest.TaskResource.handlePost(TaskResource.java:98)
at org.restlet.Finder.handle(Finder.java:296)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
... 47 more
Caused by: java.lang.ClassNotFoundException: org.opengis.coverage.grid.GridCoordinates
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
... 71 more
testTimeMosaicManual(org.geoserver.importer.rest.RESTDataTest) Time elapsed: 104 sec <<< ERROR!
java.lang.NoClassDefFoundError: org/geoserver/security/SecureCatalogImpl$2
at org.geoserver.security.SecureCatalogImpl.securityFilter(SecureCatalogImpl.java:1453)
at org.geoserver.security.SecureCatalogImpl.list(SecureCatalogImpl.java:1382)
at org.geoserver.security.SecureCatalogImpl.list(SecureCatalogImpl.java:1375)
at org.geoserver.security.SecureCatalogImpl.filterLayers(SecureCatalogImpl.java:342)
at org.geoserver.security.SecureCatalogImpl.getLayers(SecureCatalogImpl.java:327)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.getLayers(AbstractFilteredCatalog.java:265)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.getLayers(AbstractCatalogDecorator.java:394)
at org.geoserver.catalog.CascadeDeleteVisitor.visitStore(CascadeDeleteVisitor.java:66)
at org.geoserver.catalog.CascadeDeleteVisitor.visit(CascadeDeleteVisitor.java:82)
at org.geoserver.catalog.impl.DataStoreInfoImpl.accept(DataStoreInfoImpl.java:41)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:145)
at com.sun.proxy.$Proxy36.accept(Unknown Source)
at org.geoserver.importer.ImporterTestSupport.removeStore(ImporterTestSupport.java:182)
at org.geoserver.importer.ImporterTestSupport.cleanCatalog(ImporterTestSupport.java:82)
at sun.reflect.GeneratedMethodAccessor120.invoke(Unknown Source)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:33)
Running org.geoserver.importer.rest.TaskResourceTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.480s]
[INFO] Core Platform Module .............................. SUCCESS [15.501s]
[INFO] Open Web Service Module ........................... SUCCESS [16.183s]
[INFO] Main Module ....................................... SUCCESS [2:54.788s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.811s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.050s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [50.957s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.423s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.344s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.054s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.582s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:31.412s]
[INFO] Web Map Service Module ............................ SUCCESS [5:22.178s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:22.037s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:31.662s]
[INFO] REST Support Module ............................... SUCCESS [44.769s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:10.480s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.474s]
[INFO] Core UI Module .................................... SUCCESS [2:26.242s]
[INFO] WMS UI Module ..................................... SUCCESS [1:05.107s]
[INFO] GWC UI Module ..................................... SUCCESS [1:33.019s]
[INFO] WFS UI Module ..................................... SUCCESS [44.960s]
[INFO] Demoes Module ..................................... SUCCESS [59.517s]
[INFO] WCS UI Module ..................................... SUCCESS [55.853s]
[INFO] Security UI Modules ............................... SUCCESS [0.528s]
[INFO] Security UI Core Module ........................... SUCCESS [3:41.248s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:49.495s]
[INFO] Security UI LDAP Module ........................... SUCCESS [1:10.928s]
[INFO] Community Space ................................... SUCCESS [0.223s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.308s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.178s]
[INFO] Printing Module ................................... SUCCESS [37.712s]
[INFO] Application Schema Support ........................ SUCCESS [0.227s]
[INFO] Application Schema Integration Test ............... SUCCESS [4:33.723s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.614s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.541s]
[INFO] GeoSearch Index Module ............................ SUCCESS [49.162s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.109s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.244s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.683s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.532s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.430s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.387s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.983s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.555s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [38.355s]
[INFO] Excel Output Format ............................... SUCCESS [40.862s]
[INFO] Validation Module ................................. SUCCESS [3.580s]
[INFO] Chart external graphics support ................... SUCCESS [2.339s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.753s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.742s]
[INFO] OWS request flow controller ....................... SUCCESS [28.833s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.231s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:18.213s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:00.533s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.692s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.942s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.318s]
[INFO] Core Monitor Extension ............................ SUCCESS [26.260s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [15.327s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.256s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [1:02.281s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:02.200s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.554s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.495s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.552s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.685s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:53.524s]
[INFO] CSW UI Module ..................................... SUCCESS [34.637s]
[INFO] DXF output format ................................. SUCCESS [0.228s]
[INFO] DXF output format ................................. SUCCESS [37.809s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [38.227s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.168s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [46.855s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.118s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [35.331s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.224s]
[INFO] Importer Core Module .............................. SUCCESS [1:47.974s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ FAILURE [1:39.322s]
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 39:37.668s (Wall Clock)
[INFO] Finished at: Fri May 16 09:41:42 UTC 2014
[INFO] Final Memory: 76M/236M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-bdb: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-bdb
