[Geoserver-devel] Build failed in Jenkins: geoserver-master #5108
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5108/&gt;
[...truncated 197723 lines...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.13-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.13-SNAPSHOT/gs-web-sec-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.13-SNAPSHOT/gs-web-sec-2.13-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Oct 02, 2017 6:21:58 PM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.859 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.334 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.13-SNAPSHOT/gs-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.13-SNAPSHOT/gs-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.13-SNAPSHOT/gs-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.13-SNAPSHOT/gs-sec-cas-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.13-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.13-SNAPSHOT/gs-sec-cas-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.13-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.795 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.747 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.003 s]
[INFO] Main Module ........................................ SUCCESS [02:44 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.069 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 50.431 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:22 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.650 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.324 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.365 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.556 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:49 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:36 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 36.675 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.134 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:28 min]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:22 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.039 s]
[INFO] Core UI Module ..................................... SUCCESS [01:23 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 37.519 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 13.357 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.957 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.574 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:09 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:34 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:20 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.377 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.047 s]
[INFO] Printing Module .................................... SUCCESS [ 15.076 s]
[INFO] Community Space .................................... SUCCESS [ 0.074 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.044 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:46 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.002 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.942 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 16.484 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.513 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.442 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.397 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.235 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.872 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.995 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.589 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.199 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.843 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 1.236 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:34 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.364 s]
[INFO] Excel Output Format ................................ SUCCESS [ 17.213 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.760 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.268 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.509 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.770 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.031 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.755 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.654 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.272 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.041 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.423 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.102 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.073 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.083 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.049 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.490 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 25.492 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 21.474 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.045 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.858 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.163 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 45.102 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.772 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.020 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.347 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.919 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.020 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.038 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.355 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.956 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.055 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.214 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 47.189 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.518 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.940 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.755 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.807 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 40.097 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.169 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:21 min (Wall Clock)
[INFO] Finished at: 2017-10-02T18:22:01+00:00
[INFO] Final Memory: 126M/495M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5109/&gt;
[...truncated 197536 lines...]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Oct 02, 2017 6:53:08 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Oct 02, 2017 6:53:08 PM org.geoserver.catalog.impl.AbstractCatalogFacade resolve
INFO: Failed to resolve workspace for style "gs_emptyMosaic". This means the workspace has not yet been added to the catalog, keep the proxy around
Oct 02, 2017 6:53:08 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 26
INFO: Failed to resolve workspace for style "gs_poi". This means the workspace has not yet been added to the catalog, keep the proxy around
Oct 02, 2017 6:53:09 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.576 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Oct 02, 2017 6:53:09 PM org.geoserver.catalog.impl.AbstractCatalogFacade resolve
INFO: Failed to resolve workspace for style "Default". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "raster". This means the workspace has not yet been added to the catalog, keep the proxy around
Oct 02, 2017 6:53:10 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Oct 02, 2017 6:53:10 PM org.geoserver.catalog.impl.AbstractCatalogFacade resolve
INFO: Failed to resolve workspace for style "point". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "line". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "polygon". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "generic". This means the workspace has not yet been added to the catalog, keep the proxy around
Oct 02, 2017 6:53:11 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.532 sec
Results :
Tests run: 57, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.332 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.491 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.845 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.050 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.623 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:26 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.465 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.534 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.016 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.565 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:33 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 35.722 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.827 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:58 min]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [03:49 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.041 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 36.507 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.477 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.124 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.094 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.048 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:10 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:33 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:19 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.121 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.031 s]
[INFO] Printing Module .................................... SUCCESS [ 14.321 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.400 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.408 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 16.528 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.077 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.435 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.292 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.233 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.750 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.368 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.285 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.043 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.121 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.619 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:32 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.278 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.042 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.458 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.315 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.460 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.845 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.366 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.681 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.402 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.235 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.058 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 23.308 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.937 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.046 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.385 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.634 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 24.309 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 44.435 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.402 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.903 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 44.211 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.998 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.029 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.149 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.913 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.027 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.986 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 15.420 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.712 s]
[INFO] Importer Core Module ............................... SUCCESS [01:13 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 45.963 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.421 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.191 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.736 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 23.953 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 49.468 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.370 s]
[INFO] Total time: 24:39 min (Wall Clock)
[INFO] Finished at: 2017-10-02T18:53:11+00:00
[INFO] Final Memory: 118M/527M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5110/&gt;
[...truncated 197512 lines...]
Oct 02, 2017 9:29:33 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Oct 02, 2017 9:29:34 PM org.geoserver.platform.GeoServerExtensions checkContext
Oct 02, 2017 9:29:34 PM org.geoserver.catalog.impl.AbstractCatalogFacade resolve
INFO: Failed to resolve workspace for style "BasicPolygons". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "Bridges". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "Buildings". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "DividedRoutes". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "Forests". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "Lakes". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "MapNeatline". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "NamedPlaces". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "Ponds". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "RoadSegments". This means the workspace has not yet been added to the catalog, keep the proxy around
INFO: Failed to resolve workspace for style "Streams". This means the workspace has not yet been added to the catalog, keep the proxy around
Oct 02, 2017 9:29:35 PM org.geoserver.platform.GeoServerExtensions checkContext
Oct 02, 2017 9:29:36 PM org.geoserver.catalog.impl.AbstractCatalogFacade resolve
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.739 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.225 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.475 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.553 s]
[INFO] Main Module ........................................ SUCCESS [02:46 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.054 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 56.489 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.375 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.321 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.692 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 54.768 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:32 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 37.709 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.176 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:26 min]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:19 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.736 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.616 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.252 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.520 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.050 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:37 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:26 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.618 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.043 s]
[INFO] Printing Module .................................... SUCCESS [ 13.961 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:43 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.147 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.741 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 17.938 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.230 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.425 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.229 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.303 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.590 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.908 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.286 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.055 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.896 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:33 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.069 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.132 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.450 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.299 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.526 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.558 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.217 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.936 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.994 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.457 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.066 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.212 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.550 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.187 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.663 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 25.797 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 21.855 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.642 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.013 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.306 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.768 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.034 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.023 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.938 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.035 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 21.031 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.059 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.079 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.156 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 45.389 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.422 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.945 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.722 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.734 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 41.768 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.644 s]
[INFO] Total time: 23:14 min (Wall Clock)
[INFO] Finished at: 2017-10-02T21:29:39+00:00
[INFO] Final Memory: 126M/464M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5111/&gt;
[...truncated 197506 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Oct 02, 2017 10:49:34 PM org.geoserver.security.cas.LiveCasData disableTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.795 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.040 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.404 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.303 s]
[INFO] Main Module ........................................ SUCCESS [02:36 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.061 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.709 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:18 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.459 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.660 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.812 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 54.663 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:41 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:31 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 36.315 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.281 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:29 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.042 s]
[INFO] Core UI Module ..................................... SUCCESS [01:19 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 37.266 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.693 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.157 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.778 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.054 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:07 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:21 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.064 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.044 s]
[INFO] Printing Module .................................... SUCCESS [ 13.817 s]
[INFO] Community Space .................................... SUCCESS [ 0.031 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:41 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.073 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.007 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 17.479 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.057 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.446 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.844 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.254 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.078 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.520 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.256 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.144 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.404 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:35 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.335 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.389 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.457 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.786 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.498 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.594 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 28.199 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.014 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.585 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.256 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.314 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.633 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.840 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.087 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.424 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 25.561 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 21.989 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.042 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.868 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.056 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 45.360 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.405 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.431 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.183 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.029 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.339 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.930 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.771 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.058 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.189 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 46.080 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.732 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.050 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.748 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.194 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 39.222 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.446 s]
[INFO] Total time: 22:58 min (Wall Clock)
[INFO] Finished at: 2017-10-02T22:49:37+00:00
[INFO] Final Memory: 126M/463M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5112/changes&gt;
Changes:
[github] Trivial docs fix for geopackage community module
[...truncated 197518 lines...]
[INFO]
Oct 03, 2017 2:45:21 AM org.geoserver.platform.GeoServerExtensions checkContext
Oct 03, 2017 2:45:22 AM org.geoserver.catalog.impl.AbstractCatalogFacade resolve
Oct 03, 2017 2:45:23 AM org.geoserver.platform.GeoServerExtensions checkContext
Oct 03, 2017 2:45:23 AM org.geoserver.catalog.impl.AbstractCatalogFacade resolve
Oct 03, 2017 2:45:24 AM org.geoserver.catalog.impl.AbstractCatalogFacade resolve
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.356 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.509 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.176 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.700 s]
[INFO] Main Module ........................................ SUCCESS [02:57 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.058 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 51.524 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [07:06 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.281 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.218 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.324 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 55.264 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:56 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:50 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 37.596 s]
[INFO] gs-rest ............................................ SUCCESS [ 18.183 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:40 min]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:21 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.114 s]
[INFO] Core UI Module ..................................... SUCCESS [01:32 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 39.482 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.269 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.550 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.418 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:15 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:38 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [02:38 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.265 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] Printing Module .................................... SUCCESS [ 14.237 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.741 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.654 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 16.776 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.033 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.238 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.337 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.920 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.263 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.208 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.555 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:41 min]
[INFO] OGR WPS ............................................ SUCCESS [ 12.144 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.999 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.437 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.366 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.440 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.991 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.972 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 32.072 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.453 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.271 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.045 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.557 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.783 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.489 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.055 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.685 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 26.214 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 22.856 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.055 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.446 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.994 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.188 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.021 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.721 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.829 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 24.231 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 15.989 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.437 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.158 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 48.455 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 21.375 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 17.762 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.821 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.707 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 45.085 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.553 s]
[INFO] Total time: 26:41 min (Wall Clock)
[INFO] Finished at: 2017-10-03T02:45:26+00:00
[INFO] Final Memory: 117M/637M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5113/changes&gt;
