See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5166/changes>
Changes:
[simon.hofer] [GEOS-6799] place dxf attributes on interior point so
[...truncated 200150 lines...]
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-app ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/test-classes>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.13-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports>
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [9496 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.331 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.736 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.258 s]
[INFO] Main Module ........................................ SUCCESS [01:35 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.089 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:33 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.832 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:07 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.769 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.815 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.296 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 55.110 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:49 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:31 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.347 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.652 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:01 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:50 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 22.092 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 26.299 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 16.611 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.062 s]
[INFO] Core UI Module ..................................... SUCCESS [01:25 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.778 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 58.839 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.157 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.543 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.882 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.091 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:04 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:48 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:19 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.383 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.050 s]
[INFO] Printing Module .................................... SUCCESS [ 13.995 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 16.458 s]
[INFO] Community Space .................................... SUCCESS [ 0.135 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.068 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:45 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.201 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.858 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.743 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.107 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 3.055 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 3.600 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.275 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.992 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.967 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.327 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.035 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.071 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.152 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.060 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:39 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.306 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.344 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.543 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.251 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.480 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.041 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.091 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.606 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.103 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.034 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.074 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 26.614 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.889 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.211 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.848 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.063 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.913 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 24.325 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 40.034 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 20.831 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.048 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.022 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.710 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.877 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.028 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.031 s]
[INFO] DXF WFS output format .............................. FAILURE [ 14.609 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.029 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 21.067 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.320 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.472 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.074 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.641 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 44.205 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 20.415 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.036 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.294 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.860 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 38.990 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.652 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.273 s]
[INFO] BUILD FAILURE
[INFO] Total time: 23:53 min (Wall Clock)
[INFO] Finished at: 2017-10-23T07:48:53+00:00
[INFO] Final Memory: 136M/517M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-dxf-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-dxf-core
