[Geoserver-devel] Build failed in Jenkins: geoserver-master #5210
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5210/&gt;
[...truncated 117261 lines...]
Nov 05, 2017 1:22:37 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ResourcePool', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Nov 05, 2017 1:22:38 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
Nov 05, 2017 1:22:38 PM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Nov 05, 2017 1:22:39 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 05, 2017 1:22:40 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Nov 05, 2017 1:22:44 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Nov 05, 2017 1:22:45 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.424 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.483 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.850 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.553 s]
[INFO] Main Module ........................................ SUCCESS [01:36 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.080 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:26 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.514 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:11 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.896 s]
[INFO] Web Coverage Service 1.0 Module .................... FAILURE [ 23.740 s]
[INFO] Web Coverage Service 1.1 Module .................... FAILURE [ 27.864 s]
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SUCCESS [01:48 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:40 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.962 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.482 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:08 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:52 min]
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 26.052 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 17.121 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.042 s]
[INFO] Core UI Module ..................................... SUCCESS [01:24 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 37.718 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:03 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 15.901 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.714 s]
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.096 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:07 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:27 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:16 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.483 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SUCCESS [ 14.228 s]
[INFO] Community Space .................................... SUCCESS [ 0.864 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:43 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.114 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.744 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.470 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.042 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.664 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.431 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.234 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.686 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.314 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.267 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.088 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.990 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 15.909 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.466 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.025 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.729 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.975 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.632 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.085 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.124 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.887 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.462 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.276 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 20.844 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.045 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.133 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.578 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 41.220 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.030 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.319 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.748 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.474 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.601 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 45.321 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.156 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.923 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.484 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.022 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.901 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 17.108 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:14 min (Wall Clock)
[INFO] Finished at: 2017-11-05T13:22:46+00:00
[INFO] Final Memory: 124M/574M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs1_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wcs1_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs1_1: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wcs1_1/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs1_0
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5211/&gt;
[...truncated 117270 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/surefire-reports&gt;
T E S T S
Running org.geoserver.importer.web.ImportTaskTableTest
Nov 05, 2017 1:49:06 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerConfigurationLock', but ApplicationContext is unset.
Nov 05, 2017 1:49:07 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 05, 2017 1:49:07 PM org.geotools.image.ImageWorker <clinit>
Nov 05, 2017 1:49:08 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 05, 2017 1:49:09 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 05, 2017 1:49:13 PM org.geoserver.catalog.ResourcePool getFeatureType
Nov 05, 2017 1:49:14 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.236 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.454 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.101 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.859 s]
[INFO] Main Module ........................................ SUCCESS [01:32 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.062 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:27 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.273 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:05 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.321 s]
[INFO] Web Coverage Service 1.0 Module .................... FAILURE [ 24.012 s]
[INFO] Web Coverage Service 1.1 Module .................... FAILURE [ 24.946 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:45 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:33 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.554 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.137 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:11 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:53 min]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 24.854 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 17.514 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.259 s]
[INFO] Core UI Module ..................................... SUCCESS [01:22 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 37.172 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:01 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 14.425 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.578 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.060 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:03 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:31 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:20 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.404 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] Printing Module .................................... SUCCESS [ 14.623 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:42 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.072 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.562 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.200 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.453 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.476 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.263 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.307 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.942 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.865 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.333 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.047 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.130 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.584 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.491 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.464 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.168 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.491 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.591 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.574 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.233 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.070 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.225 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.040 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.916 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.423 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 20.456 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.041 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.989 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.345 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 41.241 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.065 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.055 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.032 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.333 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.057 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.804 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 44.806 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.417 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.959 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.434 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.956 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.132 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 17.097 s]
[INFO] Total time: 19:49 min (Wall Clock)
[INFO] Finished at: 2017-11-05T13:49:16+00:00
[INFO] Final Memory: 124M/553M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5212/&gt;
[...truncated 117302 lines...]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/test-classes&gt;
[INFO]
T E S T S
Nov 05, 2017 5:26:12 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 05, 2017 5:26:13 PM org.geotools.image.ImageWorker <clinit>
Nov 05, 2017 5:26:13 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 05, 2017 5:26:15 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 05, 2017 5:26:18 PM org.geoserver.catalog.ResourcePool getFeatureType
Nov 05, 2017 5:26:20 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.181 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.933 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.831 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.350 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.054 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:29 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 42.728 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:02 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.481 s]
[INFO] Web Coverage Service 1.0 Module .................... FAILURE [ 22.954 s]
[INFO] Web Coverage Service 1.1 Module .................... FAILURE [ 26.258 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:35 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.504 s]
[INFO] gs-rest ............................................ SUCCESS [ 17.270 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 26.359 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 16.396 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.090 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 37.509 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 14.176 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.822 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:06 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.317 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.110 s]
[INFO] Printing Module .................................... SUCCESS [ 14.117 s]
[INFO] Community Space .................................... SUCCESS [ 0.076 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.044 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:44 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.078 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.381 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 15.147 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.111 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.443 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.236 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.256 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.811 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.852 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.256 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.040 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.110 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.022 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.051 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.972 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.482 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.106 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.493 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.831 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.355 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.272 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.059 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.978 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.076 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.426 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.570 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 20.425 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.050 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.249 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.794 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 40.056 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.039 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 16.014 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.051 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.989 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.202 s]
[INFO] Importer Core Module ............................... SUCCESS [ 46.059 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 44.957 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 17.706 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.216 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.967 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.854 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.745 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.425 s]
[INFO] Total time: 19:51 min (Wall Clock)
[INFO] Finished at: 2017-11-05T17:26:20+00:00
[INFO] Final Memory: 125M/655M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5213/&gt;
[...truncated 117225 lines...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.275 sec
Results :
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.13-SNAPSHOT/gs-importer-bdb-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.13-SNAPSHOT/gs-importer-bdb-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.13-SNAPSHOT/gs-importer-bdb-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.13-SNAPSHOT/gs-importer-bdb-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.13-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.13-SNAPSHOT/gs-importer-bdb-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.13-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Nov 05, 2017 6:09:22 PM org.geoserver.platform.GeoServerExtensions checkContext
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Nov 05, 2017 6:09:25 PM org.geoserver.catalog.ResourcePool getFeatureType
Nov 05, 2017 6:09:27 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.716 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.995 s]
[INFO] Core Platform Module ............................... SUCCESS [ 17.587 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.532 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.766 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.352 s]
[INFO] Web Coverage Service 1.0 Module .................... FAILURE [ 23.701 s]
[INFO] Web Coverage Service 1.1 Module .................... FAILURE [ 26.126 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:47 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:37 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.953 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.751 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:09 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:50 min]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 25.765 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 17.917 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 3.814 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 38.057 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 14.113 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.838 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.050 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:01 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:28 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:17 min]
[INFO] REST UI Module ..................................... SUCCESS [ 14.020 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.058 s]
[INFO] Printing Module .................................... SUCCESS [ 14.526 s]
[INFO] Community Space .................................... SUCCESS [ 0.077 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.408 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.574 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.567 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.084 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.432 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.421 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.663 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.830 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.300 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.035 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.210 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.347 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.029 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.170 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.443 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.149 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.515 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.353 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.323 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.249 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.103 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.510 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 23.357 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 21.388 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.046 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.814 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.174 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 39.632 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 16.518 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.033 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.790 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.740 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.802 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.770 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.177 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.931 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.624 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.402 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.659 s]
[INFO] Total time: 19:47 min (Wall Clock)
[INFO] Finished at: 2017-11-05T18:09:28+00:00
[INFO] Final Memory: 124M/657M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
This is a sequence of failures apparently triggered by this initial build:
http://ares.boundlessgeo.com/jenkins/job/geotools-master/2343/
  1. [GEOS-8227] - improve whitespace handling in XML Parser (#1729) (detail)
Changing whitespace handling is causing issues in GeoServer. I do not have time to look
into it (late, tomorrow I have to travel), but I would guess a 50/50 chance of regression
vs wrong test expectation
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Wow, I wasn’t expecting that many issues to pop up. I’ve reverted the commit for now.
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5214/&gt;
Hehehe, “and you will touch xml parser/encoder, and you will know pain and despair”
Ian
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
