See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5250/>
[...truncated 141948 lines...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.332 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.13-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports>
T E S T S
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.073 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.194 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [383 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.484 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.624 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.042 s]
[INFO] Main Module ........................................ SUCCESS [01:28 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.063 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:31 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.798 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:09 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.344 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.150 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.866 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 53.885 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:46 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:36 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.194 s]
[INFO] gs-rest ............................................ SUCCESS [ 18.308 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:08 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:52 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 22.115 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 25.314 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 16.628 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.047 s]
[INFO] Core UI Module ..................................... SUCCESS [01:19 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 39.206 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:01 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 14.353 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.832 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.605 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:06 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:28 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:15 min]
[INFO] REST UI Module ..................................... SUCCESS [ 14.094 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.047 s]
[INFO] Printing Module .................................... SUCCESS [ 14.007 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.647 s]
[INFO] Community Space .................................... SUCCESS [ 0.032 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:42 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.175 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.400 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.957 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.081 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 2.492 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.260 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.280 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.503 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.677 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.262 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.184 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.238 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.315 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.936 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.495 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.154 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.981 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.398 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.502 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.896 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.823 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.104 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.044 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 27.558 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.971 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.688 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.173 s]
[INFO] XLST based WFS output format ....................... FAILURE [ 23.928 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 40.564 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 21.105 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.041 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.846 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.240 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.465 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.867 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.592 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.573 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.131 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.671 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.278 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.143 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.056 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.420 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.964 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.907 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.982 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.393 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.866 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 40.258 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.757 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.920 s]
[INFO] BUILD FAILURE
[INFO] Total time: 23:30 min (Wall Clock)
[INFO] Finished at: 2017-11-14T21:19:54+00:00
[INFO] Final Memory: 136M/548M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-xslt: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/xslt/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-xslt
