[Geoserver-devel] Build failed in Jenkins: geoserver-master #5295
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5295/changes&gt;
Changes:
[andrea.aime] [GEOS-8424] WFS 2.0 GetPropertyValue with an empty reference should
[...truncated 6087 lines...]
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO]
[INFO] Skipping GWC UI Module
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Ysld GeoServer Plugin
[INFO]
[INFO] Skipping GeoServer CSS Styling
[INFO]
[INFO]
[INFO] Skipping WCS UI Module
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.385 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.439 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.783 s]
[INFO] Main Module ........................................ FAILURE [02:26 min]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.041 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.035 s]
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.085 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.023 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.858 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.520 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.239 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.617 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.694 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.500 s]
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.513 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.026 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 03:04 min (Wall Clock)
[INFO] Finished at: 2017-11-23T17:51:42+00:00
[INFO] Final Memory: 104M/636M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5296/changes&gt;
Changes:
[andrea.aime] [GEOS-8425] WFS 2.0 GetPropertyValue does not support @gml:id value
[...truncated 70901 lines...]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.13-SNAPSHOT/gs-csw-core-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.13-SNAPSHOT/gs-csw-core-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.13-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.13-SNAPSHOT/gs-csw-core-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building CSW UI Module 2.13-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-csw ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-csw ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Nov 23, 2017 6:20:45 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerConfigurationLock', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ResourcePool', but ApplicationContext is unset.
Nov 23, 2017 6:20:46 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
Nov 23, 2017 6:20:46 PM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Nov 23, 2017 6:20:47 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 23, 2017 6:20:48 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.782 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.986 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.854 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 24.731 s]
[INFO] Main Module ........................................ SUCCESS [01:28 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.077 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:33 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 48.637 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:11 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.095 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.084 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.244 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.186 s]
[INFO] Web Feature Service Module ......................... FAILURE [01:46 min]
[INFO] gs-rest ............................................ SUCCESS [ 16.544 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:49 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 23.202 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.044 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] Security UI Modules ................................ SUCCESS [ 0.050 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.679 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] Printing Module .................................... SUCCESS [ 13.888 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.018 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.876 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 12.537 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.215 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.250 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.278 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.174 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.247 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.423 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.469 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.239 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.460 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.679 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.719 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.044 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.702 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.070 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.733 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.320 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.024 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.437 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.616 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.314 s]
[INFO] Total time: 10:42 min (Wall Clock)
[INFO] Finished at: 2017-11-23T18:20:51+00:00
[INFO] Final Memory: 114M/563M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/5297/changes&gt;
