[Geoserver-devel] Build failed in Jenkins: geoserver-master #5310
See <https://build.geoserver.org/job/geoserver-master/5310/display/redirect&gt;
[...truncated 10.66 MB...]
Nov 26, 2017 1:38:03 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
Nov 26, 2017 1:38:03 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 48
Nov 26, 2017 1:38:05 AM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Nov 26, 2017 1:38:06 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.798 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.13-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Nov 26, 2017 1:38:07 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 25
Nov 26, 2017 1:38:07 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.78 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Nov 26, 2017 1:38:08 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
Nov 26, 2017 1:38:09 AM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.395 sec
Results :
Tests run: 57, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.921 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.577 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.952 s]
[INFO] Main Module ........................................ SUCCESS [ 55.862 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.071 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:10 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.632 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.426 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.597 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.985 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.571 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 36.971 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:21 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:51 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 26.403 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.627 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:37 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:13 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.998 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.490 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 11.701 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.077 s]
[INFO] Core UI Module ..................................... SUCCESS [01:00 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 28.488 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.236 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.343 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.219 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.049 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:29 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:01 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.350 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.128 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.052 s]
[INFO] Printing Module .................................... SUCCESS [ 11.667 s]
[INFO] Community Space .................................... SUCCESS [ 0.076 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.041 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:36 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.705 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.280 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.384 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.960 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.404 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.205 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.194 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.334 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.975 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.298 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.025 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.033 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.287 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:03 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.415 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.202 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.417 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.075 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.473 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.641 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 15.652 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.781 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.695 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.073 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.558 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.838 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.106 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.058 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.126 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.263 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.860 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.950 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.715 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.588 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.935 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.288 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.238 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.041 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.460 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.487 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.255 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.055 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.344 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.560 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 12.863 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.963 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.659 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.306 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.884 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.168 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 15:41 min (Wall Clock)
[INFO] Finished at: 2017-11-26T01:38:09+00:00
[INFO] Final Memory: 137M/1095M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-master/5311/display/redirect?page=changes&gt;
Changes:
[jared.erickson] Fixes for GEOS-8427: rename scriptMgr to scriptManager, fix ruby test,
[...truncated 10.67 MB...]
Nov 26, 2017 9:17:03 AM org.geoserver.catalog.ResourcePool getFeatureType
Nov 26, 2017 9:17:04 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.34 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Nov 26, 2017 9:17:05 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 33
Nov 26, 2017 9:17:06 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.255 sec
Nov 26, 2017 9:17:07 AM org.geoserver.platform.GeoServerExtensions checkContext
Nov 26, 2017 9:17:07 AM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.606 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.785 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.729 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.899 s]
[INFO] Main Module ........................................ SUCCESS [01:36 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.081 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:26 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 45.575 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 26.189 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.041 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 18.733 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 23.612 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 43.224 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:50 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:26 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 35.324 s]
[INFO] gs-rest ............................................ SUCCESS [ 20.260 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:04 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:37 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 21.275 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 23.547 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 15.408 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.094 s]
[INFO] Core UI Module ..................................... SUCCESS [01:23 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 37.168 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.287 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.923 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.649 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.150 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:56 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:18 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 23.329 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.267 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.038 s]
[INFO] Printing Module .................................... SUCCESS [ 15.876 s]
[INFO] Community Space .................................... SUCCESS [ 0.090 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:04 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.662 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.030 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.956 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.915 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.437 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.276 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.276 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.402 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.213 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.313 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.059 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.523 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.589 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.070 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:23 min]
[INFO] OGR WPS ............................................ SUCCESS [ 12.373 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.335 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.525 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.973 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.527 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 12.677 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 25.865 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 33.852 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.613 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.567 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.031 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 31.554 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 11.377 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.732 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.843 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.447 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 20.480 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.044 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.290 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.340 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.929 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.703 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.056 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.686 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.996 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.054 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.202 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 16.667 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.520 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.059 s]
[INFO] Importer Core Module ............................... SUCCESS [ 55.925 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.675 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 16.507 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.236 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.220 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 24.509 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 48.173 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.714 s]
[INFO] Total time: 20:28 min (Wall Clock)
[INFO] Finished at: 2017-11-26T09:17:08+00:00
[INFO] Final Memory: 137M/1085M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user jared.erickson@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/5312/display/redirect&gt;
[...truncated 10.69 MB...]
Nov 27, 2017 10:36:46 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Nov 27, 2017 10:36:46 AM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.051 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Nov 27, 2017 10:36:47 AM org.geoserver.platform.GeoServerExtensions checkContext
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.31 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [02:07 min]
[INFO] Core Platform Module ............................... SUCCESS [ 11.257 s]
[INFO] Open Web Service Module ............................ SUCCESS [02:42 min]
[INFO] Main Module ........................................ SUCCESS [07:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.066 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:09 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.425 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.167 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.516 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 29.635 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 17.425 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.760 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:19 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:50 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 23.988 s]
[INFO] gs-rest ............................................ SUCCESS [ 14.968 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [03:26 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:08 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.942 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 20.309 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.082 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.061 s]
[INFO] Core UI Module ..................................... SUCCESS [01:13 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 24.393 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.876 s]
[INFO] Demos Module ....................................... SUCCESS [ 13.632 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.646 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.039 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:20 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.666 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.535 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SUCCESS [ 11.172 s]
[INFO] Community Space .................................... SUCCESS [ 0.062 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:35 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 21.428 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 26.412 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.624 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [01:03 min]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 21.714 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 10.912 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 19.646 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.842 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 43.686 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 26.189 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.019 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.807 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.486 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.014 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:07 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.947 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.395 s]
[INFO] Chart external graphics support .................... SUCCESS [ 44.657 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 6.006 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 39.882 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.808 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 26.878 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 18.793 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.832 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 6.404 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.032 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 22.222 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.423 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.628 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.110 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.702 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 19.037 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 15.769 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.584 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 35.137 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.107 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.017 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.401 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.841 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.018 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 14.707 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.804 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 25.194 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.140 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.275 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 35.062 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.369 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.208 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 33.677 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.925 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 38.507 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 7.749 s]
[INFO] Total time: 29:36 min (Wall Clock)
[INFO] Finished at: 2017-11-27T10:36:50+00:00
[INFO] Final Memory: 138M/1053M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5313/display/redirect&gt;
[...truncated 10.68 MB...]
Nov 27, 2017 10:56:26 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 18
Nov 27, 2017 10:56:27 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.386 sec
Nov 27, 2017 10:56:28 AM org.geoserver.platform.GeoServerExtensions checkContext
Nov 27, 2017 10:56:28 AM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.074 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Nov 27, 2017 10:56:28 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.86 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.428 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.337 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.210 s]
[INFO] Main Module ........................................ SUCCESS [ 55.530 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.093 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:12 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.115 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.929 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.853 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 21.854 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.080 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.710 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 20.614 s]
[INFO] gs-rest ............................................ SUCCESS [ 14.833 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:15 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:15 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.940 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.762 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.074 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.066 s]
[INFO] Core UI Module ..................................... SUCCESS [ 59.418 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.496 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.984 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.753 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 11.981 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.054 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:28 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 58.775 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.208 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.089 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.039 s]
[INFO] Printing Module .................................... SUCCESS [ 13.406 s]
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:53 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.453 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.804 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.465 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.905 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.383 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.218 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.209 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.262 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.969 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.250 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.044 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.959 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.146 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.019 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:04 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.720 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.043 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.447 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.937 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.526 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.555 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.887 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.494 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.173 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.060 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 23.227 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.403 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.022 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.291 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.849 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.446 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.843 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.062 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.487 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.199 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 33.762 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.153 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.040 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.217 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.162 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.030 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 16.871 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.630 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.057 s]
[INFO] Importer Core Module ............................... SUCCESS [01:05 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 35.895 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.320 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.810 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.554 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.056 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 46.933 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.035 s]
[INFO] Total time: 16:21 min (Wall Clock)
[INFO] Finished at: 2017-11-27T10:56:30+00:00
[INFO] Final Memory: 138M/1051M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5314/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Working around https://github.com/opengeospatial/ets-wfs20/issues/75
Nov 27, 2017 12:13:12 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 50
Nov 27, 2017 12:13:14 PM org.geoserver.catalog.ResourcePool getFeatureType
Nov 27, 2017 12:13:15 PM org.geoserver.catalog.ResourcePool getFeatureType
Nov 27, 2017 12:13:15 PM org.geoserver.importer.Importer copyFromFeatureReader
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.765 sec
Results :
[INFO]
Nov 27, 2017 12:13:16 PM org.geoserver.catalog.ResourcePool getFeatureType
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.763 sec
Nov 27, 2017 12:13:16 PM org.geoserver.platform.GeoServerExtensions checkContext
Nov 27, 2017 12:13:17 PM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.381 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.985 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.521 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.507 s]
[INFO] Main Module ........................................ SUCCESS [01:04 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.102 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:11 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.014 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.019 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.066 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.011 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.248 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.659 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:37 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:50 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.230 s]
[INFO] gs-rest ............................................ SUCCESS [ 18.153 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:35 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:12 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.019 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.114 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 11.809 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.078 s]
[INFO] Core UI Module ..................................... SUCCESS [01:12 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 28.351 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.001 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.346 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.381 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:26 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.722 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.073 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.092 s]
[INFO] Printing Module .................................... SUCCESS [ 11.471 s]
[INFO] Community Space .................................... SUCCESS [ 0.055 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:37 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.396 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.599 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.639 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.946 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.384 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.245 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.216 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.237 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.799 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.382 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.058 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.806 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.349 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] OGR WPS ............................................ SUCCESS [ 11.293 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.242 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.535 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.818 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.525 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.516 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 10.499 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.045 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.796 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.914 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.036 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 23.614 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.626 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.603 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.072 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.664 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.828 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.065 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.176 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.929 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.825 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.041 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.048 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.315 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.263 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.048 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.349 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.794 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.732 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.138 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 35.164 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 12.875 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.646 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.426 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.070 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.786 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.643 s]
[INFO] Total time: 16:09 min (Wall Clock)
[INFO] Finished at: 2017-11-27T12:13:18+00:00
[INFO] Final Memory: 136M/1157M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5315/display/redirect&gt;
Nov 27, 2017 12:51:26 PM org.geoserver.catalog.ResourcePool getFeatureType
Nov 27, 2017 12:51:27 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.912 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Nov 27, 2017 12:51:28 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 22
Nov 27, 2017 12:51:28 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.714 sec
Nov 27, 2017 12:51:29 PM org.geoserver.platform.GeoServerExtensions checkContext
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Nov 27, 2017 12:51:30 PM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.309 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.698 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.919 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.940 s]
[INFO] Main Module ........................................ SUCCESS [01:35 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.074 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.861 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.681 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.307 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.227 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.328 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.976 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 21.111 s]
[INFO] gs-rest ............................................ SUCCESS [ 14.691 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:29 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.758 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.451 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.993 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.068 s]
[INFO] Core UI Module ..................................... SUCCESS [ 58.658 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 24.667 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.955 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.812 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.660 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:00 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.612 s]
[INFO] REST UI Module ..................................... SUCCESS [ 9.894 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.027 s]
[INFO] Printing Module .................................... SUCCESS [ 11.626 s]
[INFO] Community Space .................................... SUCCESS [ 0.038 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:23 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.651 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.716 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.499 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.894 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.388 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.227 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.197 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.721 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.525 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.291 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.057 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.890 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.322 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.046 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:15 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.937 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.937 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.468 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.618 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.512 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.216 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.879 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.398 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.717 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.840 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 22.088 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.485 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.145 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.196 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.641 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 25.641 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.119 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.554 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.891 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 29.104 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.923 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.036 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.123 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.373 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.032 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.502 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.410 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.337 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.043 s]
[INFO] Importer Core Module ............................... SUCCESS [01:27 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.300 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.722 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.880 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 13.884 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.908 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 49.800 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 7.808 s]
[INFO] Total time: 17:06 min (Wall Clock)
[INFO] Finished at: 2017-11-27T12:51:30+00:00
[INFO] Final Memory: 135M/1099M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5316/display/redirect&gt;
Nov 27, 2017 1:33:46 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
Nov 27, 2017 1:33:46 PM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.038 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Nov 27, 2017 1:33:47 PM org.geoserver.platform.GeoServerExtensions checkContext
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.344 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [02:24 min]
[INFO] Core Platform Module ............................... SUCCESS [ 10.797 s]
[INFO] Open Web Service Module ............................ SUCCESS [03:12 min]
[INFO] Main Module ........................................ SUCCESS [08:27 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 33.438 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.598 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.363 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 42.562 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 17.439 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 38.437 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:16 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:56 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 25.200 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.058 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [05:18 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:07 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.163 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 19.007 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.076 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.059 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 24.367 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.952 s]
[INFO] Demos Module ....................................... SUCCESS [ 13.638 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.030 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.036 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 56.923 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.989 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.331 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.046 s]
[INFO] Printing Module .................................... SUCCESS [ 11.257 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:22 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 18.511 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [01:11 min]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.787 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [01:25 min]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 31.320 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 16.274 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 15.102 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.928 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 39.446 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 16.955 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.918 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.480 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.016 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:49 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.806 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.406 s]
[INFO] Chart external graphics support .................... SUCCESS [ 30.900 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 12.806 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 32.826 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.514 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 16.607 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 26.728 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.550 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 15.438 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 18.279 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.578 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.069 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.474 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.065 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.305 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.911 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 43.003 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 43.858 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 6.893 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 34.433 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.074 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.324 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.069 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.016 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 14.680 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.663 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 40.668 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.039 s]
[INFO] Importer Core Module ............................... SUCCESS [01:20 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 35.284 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.001 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.829 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [01:34 min]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 13.540 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 54.696 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 6.381 s]
[INFO] Total time: 34:26 min (Wall Clock)
[INFO] Finished at: 2017-11-27T13:33:50+00:00
[INFO] Final Memory: 137M/1121M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5317/display/redirect?page=changes&gt;
This failed build was my fault, my apologies for the fixing delay.
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
  The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
