See <https://build.geoserver.org/job/geoserver-master/5360/display/redirect>
[...truncated 10.84 MB...]
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Dec 07, 2017 5:01:54 PM org.geoserver.catalog.ResourcePool getFeatureType
Dec 07, 2017 5:01:55 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.861 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.13-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.13-SNAPSHOT/gs-importer-web-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.13-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
Dec 07, 2017 5:01:56 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 21
Dec 07, 2017 5:01:57 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.671 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Dec 07, 2017 5:01:58 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
Dec 07, 2017 5:01:58 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.357 sec
Results :
Tests run: 57, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [01:21 min]
[INFO] Core Platform Module ............................... SUCCESS [ 11.069 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 46.247 s]
[INFO] Main Module ........................................ SUCCESS [ 58.605 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.075 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:11 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.782 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.648 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.681 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.385 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.411 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.702 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:27 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:52 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.048 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.460 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:56 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:16 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.921 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.485 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.521 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.077 s]
[INFO] Core UI Module ..................................... SUCCESS [01:02 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 28.087 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 9.879 s]
[INFO] Demos Module ....................................... SUCCESS [ 15.890 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.981 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.042 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:28 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:01 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.695 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.203 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.057 s]
[INFO] Printing Module .................................... SUCCESS [ 11.537 s]
[INFO] Community Space .................................... SUCCESS [ 0.072 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:36 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.840 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.385 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.783 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 29.403 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 3.564 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 3.149 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.979 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.047 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.310 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.168 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.589 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.349 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:05 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.872 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.314 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.469 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 8.488 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.689 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.773 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.369 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.754 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.014 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.813 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.046 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.221 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.929 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.023 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.789 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.011 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.724 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.628 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.044 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.077 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.412 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.215 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.040 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.185 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.446 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 14.907 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.041 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.597 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.033 s]
[INFO] Importer Core Module ............................... SUCCESS [ 45.079 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.877 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 12.949 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.172 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.486 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.774 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.612 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.613 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17:57 min (Wall Clock)
[INFO] Finished at: 2017-12-07T17:01:58+00:00
[INFO] Final Memory: 138M/1055M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
