[Geoserver-devel] Build failed in Jenkins: geoserver-master #5388
See <https://build.geoserver.org/job/geoserver-master/5388/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-8492] WPS: embedding XML in ComplexData without guarding with
[Andrea Aime] [GEOS-6388] Images not displaying in WMS decorations
[Andrea Aime] [GEOS-8488] Add a new 'large map download' process in wps-download
[...truncated 9.04 MB...]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports&gt;
T E S T S
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
Running org.geoserver.wfs.web.CSWAdminPageTest
Dec 14, 2017 4:32:48 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerConfigurationLock', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ResourcePool', but ApplicationContext is unset.
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
Dec 14, 2017 4:32:48 PM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Dec 14, 2017 4:32:49 PM org.geoserver.platform.GeoServerExtensions checkContext
Dec 14, 2017 4:32:50 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.102 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.003 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.307 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.226 s]
[INFO] Main Module ........................................ SUCCESS [ 55.876 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:14 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.769 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.161 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.605 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.255 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.107 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 36.477 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:30 min]
[INFO] Web Map Service Module ............................. FAILURE [01:52 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 15.634 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:11 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.563 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.209 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.060 s]
[INFO] Core UI Module ..................................... SUCCESS [01:03 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.131 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.042 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:25 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 58.436 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.565 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.249 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.040 s]
[INFO] Printing Module .................................... SUCCESS [ 11.374 s]
[INFO] Community Space .................................... SUCCESS [ 0.062 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.580 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.244 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.208 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.917 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.378 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.227 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.198 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.013 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.303 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.048 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.804 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.127 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.047 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:04 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.876 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.645 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.459 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.882 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.430 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.972 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 21.579 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.093 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.770 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.037 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.184 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.744 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.363 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.081 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.040 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.870 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 33.210 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.839 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.049 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.151 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.779 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.071 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.809 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.963 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.238 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:40 min (Wall Clock)
[INFO] Finished at: 2017-12-14T16:32:52+00:00
[INFO] Final Memory: 128M/1037M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-master/5389/display/redirect?page=changes&gt;
