[Geoserver-devel] Build failed in Jenkins: geoserver-master #5408
See <https://build.geoserver.org/job/geoserver-master/5408/display/redirect&gt;
[...truncated 9.05 MB...]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Dec 20, 2017 10:43:47 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerConfigurationLock', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ResourcePool', but ApplicationContext is unset.
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
Dec 20, 2017 10:43:48 AM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
Dec 20, 2017 10:43:48 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
Dec 20, 2017 10:43:49 AM org.geoserver.platform.GeoServerExtensions checkContext
Dec 20, 2017 10:43:50 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.141 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.636 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.085 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.536 s]
[INFO] Main Module ........................................ SUCCESS [ 55.316 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:10 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.604 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.141 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.525 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.318 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.488 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.100 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:30 min]
[INFO] Web Map Service Module ............................. FAILURE [01:56 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 15.797 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:14 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.129 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.281 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.054 s]
[INFO] Core UI Module ..................................... SUCCESS [01:03 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.580 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:28 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 59.914 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.170 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.226 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SUCCESS [ 11.268 s]
[INFO] Community Space .................................... SUCCESS [ 0.074 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.847 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.975 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.068 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.894 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.374 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.211 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.232 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.418 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.340 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.034 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.809 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.940 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.028 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:06 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.066 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.611 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.458 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.319 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.402 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.977 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 26.407 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.696 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.208 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.025 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.830 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.227 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.968 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.045 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.030 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.392 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 35.179 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.340 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.032 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 12.026 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.034 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.149 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.927 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.720 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:52 min (Wall Clock)
[INFO] Finished at: 2017-12-20T10:43:52+00:00
[INFO] Final Memory: 129M/1066M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-master/5409/display/redirect&gt;
[...truncated 535.85 KB...]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Ysld GeoServer Plugin
[INFO]
[INFO] Skipping GeoServer CSS Styling
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.268 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.959 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.712 s]
[INFO] Main Module ........................................ FAILURE [ 54.463 s]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.063 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.027 s]
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.036 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.891 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.383 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.207 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.225 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.618 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.318 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.025 s]
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.499 s]
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.540 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.066 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.040 s]
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] Total time: 01:23 min (Wall Clock)
[INFO] Finished at: 2017-12-20T10:48:07+00:00
[INFO] Final Memory: 113M/777M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <https://build.geoserver.org/job/geoserver-master/5410/display/redirect?page=changes&gt;
Changes:
[noreply] Quick typo fix
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Dec 20, 2017 11:22:52 AM org.geoserver.platform.GeoServerExtensions checkContext
Dec 20, 2017 11:22:53 AM org.geoserver.platform.GeoServerExtensions checkContext
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Dec 20, 2017 11:22:53 AM org.geotools.image.ImageWorker <clinit>
Dec 20, 2017 11:22:54 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.954 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.522 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.225 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.144 s]
[INFO] Main Module ........................................ SUCCESS [ 55.055 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.073 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:13 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.594 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.960 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.568 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.230 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.539 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 39.384 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:31 min]
[INFO] Web Map Service Module ............................. FAILURE [01:54 min]
[INFO] gs-rest ............................................ SUCCESS [ 15.788 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:11 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.760 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 19.205 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.068 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.256 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:30 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 59.857 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.187 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.802 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 11.635 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.729 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.451 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.535 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.906 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.378 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.199 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.206 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.984 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.269 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.525 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.232 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:05 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.824 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.124 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.480 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.924 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.520 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.649 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 11.255 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.220 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.924 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.036 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.050 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.794 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.295 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 18.622 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.024 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.454 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.529 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 34.230 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.337 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.050 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.701 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.853 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.055 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.613 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.069 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.152 s]
[INFO] Total time: 10:47 min (Wall Clock)
[INFO] Finished at: 2017-12-20T11:22:56+00:00
[INFO] Final Memory: 129M/1033M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/5411/display/redirect?page=changes&gt;
