[Geoserver-devel] Build failed in Jenkins: geoserver-master #553
See <http://ares.opengeo.org/jenkins/job/geoserver-master/553/&gt;
[...truncated 26431 lines...]
Results :
Tests in error:
  testCapabilitiesLinks(org.geoserver.gwc.web.GWCServiceLinksTest)
  testCapabilitiesLinks(org.geoserver.gwc.web.GWCServiceLinksTest): you can only locate or create sessions in the context of a request cycle
  testEditEnableWMSC(org.geoserver.gwc.web.GWCSettingsPageTest): Unexpected exception parsing XML document from URL [jar:<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml\];> nested exception is java.lang.NullPointerException
  testEditEnableWMSC(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testEditEnableWMTS(org.geoserver.gwc.web.GWCSettingsPageTest)
  testEditEnableWMTS(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testEditEnableTMS(org.geoserver.gwc.web.GWCSettingsPageTest)
  testEditEnableTMS(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testEditLockProvider(org.geoserver.gwc.web.GWCSettingsPageTest)
  testEditLockProvider(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testEnableAutoCacheStyles(org.geoserver.gwc.web.GWCSettingsPageTest)
  testEnableAutoCacheStyles(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testDisableCacheLayersByDefault(org.geoserver.gwc.web.GWCSettingsPageTest)
  testDisableCacheLayersByDefault(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testSetDefaultCacheFormats(org.geoserver.gwc.web.GWCSettingsPageTest)
  testSetDefaultCacheFormats(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testDisableAutoCacheStyles(org.geoserver.gwc.web.GWCSettingsPageTest)
  testDisableAutoCacheStyles(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testEditDirectWMSIntegration(org.geoserver.gwc.web.GWCSettingsPageTest)
  testEditDirectWMSIntegration(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testEnableCacheLayersByDefault(org.geoserver.gwc.web.GWCSettingsPageTest)
  testEnableCacheLayersByDefault(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testPageLoad(org.geoserver.gwc.web.GWCSettingsPageTest)
  testPageLoad(org.geoserver.gwc.web.GWCSettingsPageTest): you can only locate or create sessions in the context of a request cycle
  testCreateFromScratch(org.geoserver.gwc.web.gridset.GridSetNewPageTest): Unexpected exception parsing XML document from URL [jar:<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml\];> nested exception is java.lang.NullPointerException
  testCreateFromScratch(org.geoserver.gwc.web.gridset.GridSetNewPageTest): you can only locate or create sessions in the context of a request cycle
  testCreateFromTemplate(org.geoserver.gwc.web.gridset.GridSetNewPageTest): There is no application attached to current thread main
  testCreateFromTemplate(org.geoserver.gwc.web.gridset.GridSetNewPageTest): you can only locate or create sessions in the context of a request cycle
  testPageLoad(org.geoserver.gwc.web.gridset.GridSetNewPageTest): There is no application attached to current thread main
  testPageLoad(org.geoserver.gwc.web.gridset.GridSetNewPageTest): you can only locate or create sessions in the context of a request cycle
  testPageLoad(org.geoserver.gwc.web.gridset.GridSetsPageTest): Unexpected exception parsing XML document from URL [jar:<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml\];> nested exception is java.lang.NullPointerException
  testPageLoad(org.geoserver.gwc.web.gridset.GridSetsPageTest): you can only locate or create sessions in the context of a request cycle
  testQuotaDisabled(org.geoserver.gwc.web.layer.CachedLayerProviderTest): Unexpected exception parsing XML document from URL [jar:<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml\];> nested exception is java.lang.NullPointerException
  testQuotaEnabled(org.geoserver.gwc.web.layer.CachedLayerProviderTest): Unexpected exception parsing XML document from URL [jar:<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml\];> nested exception is java.lang.NullPointerException
  testPageLoad(org.geoserver.gwc.web.layer.CachedLayersPageTest): Unexpected exception parsing XML document from URL [jar:<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml\];> nested exception is java.lang.NullPointerException
  testPageLoad(org.geoserver.gwc.web.layer.CachedLayersPageTest): you can only locate or create sessions in the context of a request cycle
  testPageLoadForGeometrylessLayer(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): Unexpected exception parsing XML document from URL [jar:<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml\];> nested exception is java.lang.NullPointerException
  testPageLoadForGeometrylessLayer(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): you can only locate or create sessions in the context of a request cycle
  testSaveExisting(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): BeanFactory not initialized or already closed - call 'refresh' before accessing beans via the ApplicationContext
  testSaveExisting(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): you can only locate or create sessions in the context of a request cycle
  testRemoveExisting(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): BeanFactory not initialized or already closed - call 'refresh' before accessing beans via the ApplicationContext
  testRemoveExisting(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): you can only locate or create sessions in the context of a request cycle
  testSaveNew(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): BeanFactory not initialized or already closed - call 'refresh' before accessing beans via the ApplicationContext
  testSaveNew(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): you can only locate or create sessions in the context of a request cycle
  testPageLoad(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): BeanFactory not initialized or already closed - call 'refresh' before accessing beans via the ApplicationContext
  testPageLoad(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): you can only locate or create sessions in the context of a request cycle
  testCreateOwnModelExisting(org.geoserver.gwc.web.layer.LayerEditCacheOptionsTabPanelInfoTest)
  testCreateOwnModelNew(org.geoserver.gwc.web.layer.LayerEditCacheOptionsTabPanelInfoTest)
  testPageLoad(org.geoserver.gwc.web.layer.NewCachedLayerPageTest): Unexpected exception parsing XML document from URL [jar:<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml\];> nested exception is java.lang.NullPointerException
  testPageLoad(org.geoserver.gwc.web.layer.NewCachedLayerPageTest): you can only locate or create sessions in the context of a request cycle
Tests run: 57, Failures: 0, Errors: 57, Skipped: 0
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-rest ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/rest/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-rest ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/rest/target/test-classes&gt;
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.131s]
[INFO] Core Platform Module .............................. SUCCESS [16.143s]
[INFO] Open Web Service Module ........................... SUCCESS [16.249s]
[INFO] Main Module ....................................... SUCCESS [2:53.763s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.780s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:47.660s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:16.009s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.951s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.238s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.903s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.952s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:04.175s]
[INFO] Web Map Service Module ............................ SUCCESS [6:11.053s]
[INFO] KML support for GeoServer ......................... SUCCESS [2:29.198s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:35.309s]
[INFO] REST Support Module ............................... SUCCESS [46.322s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:05.423s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.578s]
[INFO] Core UI Module .................................... SUCCESS [2:40.137s]
[INFO] WMS UI Module ..................................... SUCCESS [1:04.068s]
[INFO] GWC UI Module ..................................... FAILURE [53.912s]
[INFO] WFS UI Module ..................................... SUCCESS [45.974s]
[INFO] Demoes Module ..................................... SUCCESS [1:05.988s]
[INFO] Security UI Modules ............................... SUCCESS [0.331s]
[INFO] Security UI Core Module ........................... SUCCESS [4:47.263s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.292s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.970s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.202s]
[INFO] Printing Module ................................... SUCCESS [38.457s]
[INFO] Application Schema Support ........................ SUCCESS [0.274s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.661s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.442s]
[INFO] GeoSearch Index Module ............................ SUCCESS [1:00.129s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.741s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.160s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.632s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.542s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.607s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.883s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.194s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.572s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [34.843s]
[INFO] Excel Output Format ............................... SUCCESS [41.543s]
[INFO] Validation Module ................................. SUCCESS [4.188s]
[INFO] Chart external graphics support ................... SUCCESS [1.339s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.284s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.970s]
[INFO] OWS request flow controller ....................... SUCCESS [22.436s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.269s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:11.012s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [57.192s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.595s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.187s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.838s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [50.918s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [50.172s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.350s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.153s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [30.133s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [2:49.049s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.283s]
[INFO] DXF output format ................................. SUCCESS [38.326s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [48.107s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.295s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [1:04.887s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [52.147s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.371s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 33:16.422s (Wall Clock)
[INFO] Finished at: Tue Jun 10 00:25:31 UTC 2014
[INFO] Final Memory: 68M/213M
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-rest ---
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-gwc
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/rest/target/surefire-reports&gt;
T E S T S
See <http://ares.opengeo.org/jenkins/job/geoserver-master/554/changes&gt;
Changes:
[gabriel.roldan] upgrade to guava 17.0
[...truncated 4367 lines...]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.216 sec
Running org.geoserver.web.data.store.DataAccessEditPageTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.025 sec
Running org.geoserver.wfs.json.GeoJsonDescribeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.418 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.848 sec
Running org.geoserver.wfs.json.JSONTypeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.wfs.kvp.Filter_1_0_0_KvpParserTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.wfs.kvp.Filter_1_1_0_KvpParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.815 sec
Running org.geoserver.web.data.store.NewDataPageTest
Feature type cite:InvalidTypeName unknown
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.518 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.831 sec
Running org.geoserver.web.data.store.ShapefileDirectoryStorePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.366 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.974 sec
Running org.geoserver.web.data.store.StoreModelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.726 sec
Running org.geoserver.web.data.store.StorePageTest
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.014 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.225 sec
Running org.geoserver.wfs.v1_1.AliasTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.157 sec
Running org.geoserver.web.data.store.panel.FileModelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.004 sec
Running org.geoserver.wfs.v1_1.BoundingBox3DTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.111 sec
Running org.geoserver.web.data.workspace.WorkspaceEditPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.5 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.861 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureResponseTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.058 sec
Running org.geoserver.web.data.workspace.WorkspaceNewPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.486 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.975 sec
Running org.geoserver.web.data.workspace.WorkspacePageTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.874 sec
Running org.geoserver.wfs.v1_1.GetCapabilitiesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.946 sec
Running org.geoserver.web.publish.HTTPLayerConfigTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.528 sec
Running org.geoserver.wfs.v1_1.GetFeatureBboxTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.553 sec
Running org.geoserver.web.wicket.CRSPanelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.752 sec
Running org.geoserver.wfs.v1_1.GetFeatureTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.414 sec
Running org.geoserver.web.wicket.EnvelopePanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.661 sec
Running org.geoserver.web.wicket.FileExistsValidatorTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.web.wicket.GeoServerPagingNavigatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.203 sec
Running org.geoserver.web.wicket.GeoServerTablePanelTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.094 sec
Running org.geoserver.web.wicket.KeywordsEditorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.154 sec
Running org.geoserver.web.wicket.SRSPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.519 sec
Running org.geoserver.web.wicket.SRSToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.web.wicket.WKTToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.web.wicket.browser.FileBreadcrumsTest
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.403 sec
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.095 sec
Running org.geoserver.web.wicket.browser.FileDataViewTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Running org.geoserver.web.wicket.browser.GeoServerFileChooserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.225 sec
Running org.geoserver.wfs.v1_1.LockFeatureTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.211 sec
Running org.geoserver.web.wicket.property.PropertyEditorFormComponentTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.683 sec
Running org.geoserver.wfs.v1_1.TransactionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.002 sec
Results :
Failed tests: testSave(org.geoserver.web.admin.ContactPageTest): expected:<GeoServerHomePage> but was:<GeoServerErrorPage>
Tests run: 145, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Validation Module
[INFO]
[INFO] Skipping Feature Generalization Extension
[INFO]
[INFO] Skipping OWS request flow controller
[INFO]
[INFO] Skipping Catalog Services for the Web parent
[INFO]
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.505 sec
Running org.geoserver.wfs.v1_1.VersionNegotiationTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.280s]
[INFO] Core Platform Module .............................. SUCCESS [15.679s]
[INFO] Open Web Service Module ........................... SUCCESS [18.219s]
[INFO] Main Module ....................................... SUCCESS [2:52.383s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.024s]
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SUCCESS [6.317s]
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [44.597s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.496s]
[INFO] Core UI Module .................................... FAILURE [2:28.635s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.337s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.180s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.325s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [4.137s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.905s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.670s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.647s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.433s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.871s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [3.868s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.886s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.370s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.213s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.188s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Total time: 7:02.847s (Wall Clock)
[INFO] Finished at: Tue Jun 10 00:32:58 UTC 2014
[INFO] Final Memory: 41M/282M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/555/&gt;
[...truncated 4366 lines...]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.wfs.json.GeoJSONBuilderTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.wfs.json.GeoJSONTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.916 sec
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.8 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.875 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.384 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.62 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.237 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.156 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.782 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.721 sec
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.107 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.159 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.557 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.631 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.873 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.508 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.932 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.43 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.617 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.303 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.25 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.324 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.4 sec
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.788 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.032 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.617 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.733 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.955 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.632 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.131 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.789 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.087 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.257 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.201 sec
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.635 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.019 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.48 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.445 sec
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.031s]
[INFO] Core Platform Module .............................. SUCCESS [20.158s]
[INFO] Open Web Service Module ........................... SUCCESS [23.360s]
[INFO] Main Module ....................................... SUCCESS [2:57.085s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.748s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.897s]
[INFO] REST Support Module ............................... SUCCESS [43.195s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.625s]
[INFO] Core UI Module .................................... FAILURE [2:30.869s]
[INFO] Community Space ................................... SUCCESS [0.444s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.419s]
[INFO] Application Schema Support ........................ SUCCESS [0.414s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.641s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.054s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.787s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.865s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.151s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.745s]
[INFO] Chart external graphics support ................... SUCCESS [1.469s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.030s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.478s]
[INFO] DXF output format ................................. SUCCESS [0.523s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.703s]
[INFO] Total time: 7:17.562s (Wall Clock)
[INFO] Finished at: Tue Jun 10 00:40:25 UTC 2014
[INFO] Final Memory: 44M/378M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/556/changes&gt;
