[Geoserver-devel] Build failed in Jenkins: geoserver-master #5571
See <https://build.geoserver.org/job/geoserver-master/5571/display/redirect?page=changes&gt;
Changes:
[tbarsballe] Updated version to 2.14-SNAPSHOT, updated GeoTools dependency to
[...truncated 10.83 MB...]
Feb 20, 2018 10:32:49 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
Feb 20, 2018 10:32:50 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 41
Feb 20, 2018 10:32:51 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Feb 20, 2018 10:32:53 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.727 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
Feb 20, 2018 10:32:57 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 27
Feb 20, 2018 10:32:59 PM org.geoserver.catalog.ResourcePool getFeatureType
Feb 20, 2018 10:32:59 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 21
Feb 20, 2018 10:33:00 PM org.geoserver.importer.Importer copyFromFeatureReader
Feb 20, 2018 10:33:01 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.261 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Feb 20, 2018 10:33:01 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Feb 20, 2018 10:33:02 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.053 sec
Results :
Tests run: 66, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.786 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.037 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.584 s]
[INFO] Main Module ........................................ SUCCESS [ 58.162 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.058 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:13 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.554 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.465 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.824 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.626 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.528 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 36.974 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:29 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:54 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 26.500 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.082 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 7.046 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:15 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.615 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.671 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.462 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.101 s]
[INFO] Core UI Module ..................................... SUCCESS [01:06 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.972 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.251 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.354 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.215 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.038 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:29 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:01 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.927 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.390 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] Printing Module .................................... SUCCESS [ 11.332 s]
[INFO] Community Space .................................... SUCCESS [ 0.066 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:44 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.711 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.475 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.724 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.873 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.375 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.228 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.208 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.446 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.341 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.280 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.043 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.726 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.438 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.041 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:03 min]
[INFO] OGR WPS ............................................ SUCCESS [ 16.076 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.924 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.503 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.305 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.447 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.448 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 21.180 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.894 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.279 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.903 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.028 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 23.915 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.417 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.106 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.906 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.883 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 25.064 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.049 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.900 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.870 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 34.044 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.961 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.063 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.524 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.041 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.040 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.330 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.127 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.932 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.049 s]
[INFO] Importer Core Module ............................... SUCCESS [ 45.824 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 51.444 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 17.596 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.424 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.347 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.067 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 33.913 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.144 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 15:49 min (Wall Clock)
[INFO] Finished at: 2018-02-20T22:33:02+00:00
[INFO] Final Memory: 137M/965M
[ERROR] Failed to execute goal on project gs-gwc: Could not resolve dependencies for project org.geoserver:gs-gwc:jar:2.14-SNAPSHOT: The following artifacts could not be resolved: org.geowebcache:gwc-core:jar:1.14-SNAPSHOT, org.geowebcache:gwc-georss:jar:1.14-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.14-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.14-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.14-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.14-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.14-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.14-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.14-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.14-SNAPSHOT, org.geowebcache:gwc-core:jar:tests:1.14-SNAPSHOT: Could not find artifact org.geowebcache:gwc-core:jar:1.14-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
Not sending mail to unregistered user tbarsballe@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/5572/display/redirect?page=changes&gt;
Changes:
[tbarsballe] Update doc pom to 2.14-SNAPSHOT
[...truncated 10.85 MB...]
Feb 22, 2018 1:02:32 AM org.geoserver.platform.GeoServerExtensions checkContext
Feb 22, 2018 1:02:34 AM org.geoserver.catalog.ResourcePool getFeatureType
Feb 22, 2018 1:02:35 AM org.geoserver.catalog.ResourcePool getFeatureType
Feb 22, 2018 1:02:35 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 23
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.809 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Feb 22, 2018 1:02:38 AM org.geoserver.catalog.ResourcePool getFeatureType
Feb 22, 2018 1:02:39 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 16
INFO: load to target took 14
Feb 22, 2018 1:02:40 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.044 sec
Feb 22, 2018 1:02:40 AM org.geoserver.platform.GeoServerExtensions checkContext
Feb 22, 2018 1:02:41 AM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.872 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.686 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.993 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.306 s]
[INFO] Main Module ........................................ SUCCESS [ 59.699 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.069 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:10 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.782 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.660 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.207 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.575 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.840 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.672 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:32 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 25.884 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.630 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 6.919 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.618 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.762 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 13.013 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.094 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.865 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.018 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.354 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.020 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.043 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:02 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.925 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.375 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 11.462 s]
[INFO] Community Space .................................... SUCCESS [ 0.077 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:37 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.998 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.352 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.756 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.934 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.404 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.209 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.211 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.529 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.176 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.265 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.048 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.895 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.382 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:04 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.872 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.194 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.467 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.249 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.540 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.206 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.424 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 24.133 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.963 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.319 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.576 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.470 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.240 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.135 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.231 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 24.500 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.058 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.657 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.838 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 35.821 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.801 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.025 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.754 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.461 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.035 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.411 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.996 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.591 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.048 s]
[INFO] Importer Core Module ............................... SUCCESS [ 45.817 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 41.124 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.472 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.016 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.621 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.034 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 34.754 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.829 s]
[INFO] Total time: 15:28 min (Wall Clock)
[INFO] Finished at: 2018-02-22T01:02:41+00:00
[INFO] Final Memory: 137M/956M
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5573/display/redirect?page=changes&gt;
Changes:
[Alessio Fabiani] - Remove verbose exception from notification community module
[...truncated 10.84 MB...]
Feb 22, 2018 10:22:30 AM org.geoserver.platform.GeoServerExtensions checkContext
Feb 22, 2018 10:22:32 AM org.geoserver.catalog.ResourcePool getFeatureType
Feb 22, 2018 10:22:33 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.881 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Feb 22, 2018 10:22:34 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 28
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Feb 22, 2018 10:22:37 AM org.geoserver.catalog.ResourcePool getFeatureType
Feb 22, 2018 10:22:37 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 15
Feb 22, 2018 10:22:38 AM org.geoserver.importer.Importer copyFromFeatureReader
Feb 22, 2018 10:22:38 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.191 sec
Feb 22, 2018 10:22:39 AM org.geoserver.platform.GeoServerExtensions checkContext
Feb 22, 2018 10:22:40 AM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.966 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.899 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.922 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.871 s]
[INFO] Main Module ........................................ SUCCESS [ 58.286 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.061 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:15 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.703 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.774 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.528 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.446 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.750 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.530 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:31 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:53 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 25.609 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.647 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 7.479 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.602 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.786 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.604 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.056 s]
[INFO] Core UI Module ..................................... SUCCESS [01:05 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.186 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.032 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.529 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.364 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.049 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:30 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.167 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.153 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.035 s]
[INFO] Printing Module .................................... SUCCESS [ 11.463 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:39 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.128 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.541 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.871 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.895 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.380 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.228 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.421 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.681 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.246 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.016 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.820 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.238 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] OGR WPS ............................................ SUCCESS [ 11.195 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.978 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.494 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.977 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.491 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.296 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.152 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 23.051 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.121 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.866 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.024 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 23.421 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.331 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.745 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.118 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.187 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.842 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 25.093 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.048 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.685 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.271 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 34.273 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.744 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.349 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.608 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.058 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 14.889 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.969 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.177 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.046 s]
[INFO] Importer Core Module ............................... SUCCESS [ 46.359 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 41.765 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.334 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.897 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.984 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 19.459 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.591 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.345 s]
[INFO] Total time: 15:30 min (Wall Clock)
[INFO] Finished at: 2018-02-22T10:22:40+00:00
[INFO] Final Memory: 135M/1147M
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5574/display/redirect?page=changes&gt;
Changes:
[tbarsballe] One more doc pom update to 2.14-SNAPSHOT
Feb 22, 2018 6:42:36 PM org.geoserver.platform.GeoServerExtensions checkContext
Feb 22, 2018 6:42:36 PM org.geoserver.importer.Importer copyFromFeatureReader
Feb 22, 2018 6:42:38 PM org.geoserver.catalog.ResourcePool getFeatureType
Feb 22, 2018 6:42:39 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.939 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Feb 22, 2018 6:42:42 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 45
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Feb 22, 2018 6:42:44 PM org.geoserver.catalog.ResourcePool getFeatureType
Feb 22, 2018 6:42:44 PM org.geoserver.importer.Importer copyFromFeatureReader
Feb 22, 2018 6:42:45 PM org.geoserver.importer.Importer copyFromFeatureReader
Feb 22, 2018 6:42:45 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.16 sec
Feb 22, 2018 6:42:46 PM org.geoserver.platform.GeoServerExtensions checkContext
Feb 22, 2018 6:42:47 PM org.geoserver.importer.Importer createContextStore
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.965 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.310 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.067 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.075 s]
[INFO] Main Module ........................................ SUCCESS [ 59.033 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.057 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:19 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.377 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.325 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.443 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.137 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 17.408 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.583 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 25.691 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.672 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 7.155 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:13 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.679 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.807 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 13.027 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.050 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 36.893 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.243 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.659 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:28 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.959 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.380 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.039 s]
[INFO] Printing Module .................................... SUCCESS [ 11.008 s]
[INFO] Community Space .................................... SUCCESS [ 0.076 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:41 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.744 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.673 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.816 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.925 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.409 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.215 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.215 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.868 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.843 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.329 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.051 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.026 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.549 s]
[INFO] OGR WPS ............................................ SUCCESS [ 10.844 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.206 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.451 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.371 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.455 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.363 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.914 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 24.396 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.114 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.985 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.166 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.174 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.023 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.806 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.117 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.585 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 23.331 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.043 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.098 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.556 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 35.494 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.050 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.054 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.525 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.638 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.044 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.836 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.954 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.144 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 47.317 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 41.003 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.122 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.632 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.737 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.406 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.224 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.430 s]
[INFO] Total time: 15:35 min (Wall Clock)
[INFO] Finished at: 2018-02-22T18:42:47+00:00
[INFO] Final Memory: 138M/1076M
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5575/display/redirect?page=changes&gt;
Changes:
[Alessio Fabiani] [Notification comunity plugin] - Wrap NPE
[...truncated 542.17 KB...]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Ysld GeoServer Plugin
[INFO]
[INFO] Skipping GeoServer CSS Styling
[INFO]
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.297 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.391 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.198 s]
[INFO] Main Module ........................................ FAILURE [01:37 min]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.090 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.038 s]
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.929 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.416 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.213 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.230 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.623 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.260 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.040 s]
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.050 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.547 s]
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.539 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.040 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Total time: 02:11 min (Wall Clock)
[INFO] Finished at: 2018-02-22T19:32:23+00:00
[INFO] Final Memory: 113M/779M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <https://build.geoserver.org/job/geoserver-master/5576/display/redirect&gt;
