[Geoserver-devel] Build failed in Jenkins: geoserver-master #5644
See <https://build.geoserver.org/job/geoserver-master/5644/display/redirect?page=changes&gt;
Changes:
[niels] Taskmanager community module: part 2
[...truncated 9.20 MB...]
Mar 13, 2018 12:06:53 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Mar 13, 2018 12:06:54 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Mar 13, 2018 12:06:56 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Mar 13, 2018 12:06:57 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 35
Mar 13, 2018 12:06:59 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Mar 13, 2018 12:07:00 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.979 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
Mar 13, 2018 12:07:03 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 17
Mar 13, 2018 12:07:05 PM org.geoserver.catalog.ResourcePool getFeatureType
Mar 13, 2018 12:07:06 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 22
INFO: load to target took 23
Mar 13, 2018 12:07:07 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.353 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Mar 13, 2018 12:07:08 PM org.geoserver.platform.GeoServerExtensions checkContext
Mar 13, 2018 12:07:08 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.01 sec
Results :
Tests run: 66, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.163 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.965 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.979 s]
[INFO] Main Module ........................................ SUCCESS [01:01 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.077 s]
[INFO] GeoServer Security Tests Module .................... FAILURE [03:30 min]
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [01:06 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.901 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [01:02 min]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [01:06 min]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 58.007 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:38 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:53 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.669 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.782 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [03:32 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:43 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 27.969 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 25.622 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 14.824 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.068 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 36.999 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:18 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 15.352 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.356 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 19.260 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.044 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SUCCESS [ 14.352 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.045 s]
[INFO] Printing Module .................................... SUCCESS [ 20.047 s]
[INFO] Community Space .................................... SUCCESS [ 0.061 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:27 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 36.333 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.118 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 15.716 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.897 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.386 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.209 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.202 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.484 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.118 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.272 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.051 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.679 s]
[INFO] OGR WFS ............................................ SUCCESS [ 22.557 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.049 s]
[INFO] Web Processing Service Module ...................... SUCCESS [03:05 min]
[INFO] OGR WPS ............................................ SUCCESS [ 12.450 s]
[INFO] Excel Output Format ................................ SUCCESS [ 39.479 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.494 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.718 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.505 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 19.534 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 20.230 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 27.770 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.359 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.061 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 57.008 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.328 s]
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 23.200 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 50.624 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 31.744 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.093 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 16.030 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.839 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:39 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.196 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 22.041 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.585 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.026 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 42.868 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.167 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.508 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.047 s]
[INFO] Importer Core Module ............................... SUCCESS [01:03 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 47.847 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 16.701 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.833 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 20.300 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 19.321 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 49.295 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 17.831 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 17.862 s]
[INFO] BUILD FAILURE
[INFO] Total time: 24:58 min (Wall Clock)
[INFO] Finished at: 2018-03-13T12:07:08+00:00
[INFO] Final Memory: 137M/1043M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-security-tests: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/security/security-tests/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-security-tests
Not sending mail to unregistered user niels@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/5645/display/redirect?page=changes&gt;
