[Geoserver-devel] Build failed in Jenkins: geoserver-master #5738
See <https://build.geoserver.org/job/geoserver-master/5738/display/redirect&gt;
[...truncated 11.17 MB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
Apr 21, 2018 3:25:07 PM org.geoserver.monitor.hib.MonitoringDataSource initializeDataSource
INFO: Configuring monitoring database from: monitoring/db.properties
21 Apr 15:25:08 WARN [impl.SessionFactoryObjectFactory] - Could not bind factory to JNDI
javax.naming.NoInitialContextException: Need to specify class name in environment or system property, or as an applet parameter, or in an application resource file: java.naming.factory.initial
  at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:662)
  at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:313)
  at javax.naming.InitialContext.getURLOrDefaultInitCtx(InitialContext.java:350)
  at javax.naming.InitialContext.getNameParser(InitialContext.java:505)
  at org.hibernate.util.NamingHelper.bind(NamingHelper.java:75)
  at org.hibernate.impl.SessionFactoryObjectFactory.addInstance(SessionFactoryObjectFactory.java:113)
  at org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:365)
  at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1842)
  at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:795)
  at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:717)
  at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:191)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1687)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1624)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:555)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:483)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:742)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:866)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:542)
  at org.geoserver.monitor.hib.HibernateMonitorDAO2Test.initHibernate(HibernateMonitorDAO2Test.java:69)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
[stuff]
[things]
[widgets]
21 Apr 15:25:08 INFO [hib.HibernateMonitorDAO2Test$1] - Closing Root WebApplicationContext: startup date [Sat Apr 21 15:25:06 UTC 2018]; root of context hierarchy
21 Apr 15:25:08 WARN [impl.SessionFactoryObjectFactory] - Could not unbind factory from JNDI
  at javax.naming.InitialContext.unbind(InitialContext.java:441)
  at org.hibernate.impl.SessionFactoryObjectFactory.removeInstance(SessionFactoryObjectFactory.java:139)
  at org.hibernate.impl.SessionFactoryImpl.close(SessionFactoryImpl.java:966)
  at org.geoserver.monitor.hib.HibernateMonitorDAO2.destroy(HibernateMonitorDAO2.java:685)
  at org.springframework.beans.factory.support.DisposableBeanAdapter.destroy(DisposableBeanAdapter.java:272)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroyBean(DefaultSingletonBeanRegistry.java:578)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingleton(DefaultSingletonBeanRegistry.java:554)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.destroySingleton(DefaultListableBeanFactory.java:961)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingletons(DefaultSingletonBeanRegistry.java:523)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.destroySingletons(DefaultListableBeanFactory.java:968)
  at org.springframework.context.support.AbstractApplicationContext.destroyBeans(AbstractApplicationContext.java:1033)
  at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1009)
  at org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:961)
  at org.geoserver.monitor.hib.HibernateMonitorDAO2Test.destroy(HibernateMonitorDAO2Test.java:81)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:33)
No database files have been found in directory target/monitoring for the database monitoring
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.808 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-monitor-hibernate ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-monitor-hibernate ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-monitor-hibernate ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-monitor-hibernate ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-monitor-hibernate ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.578 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.084 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.636 s]
[INFO] Main Module ........................................ SUCCESS [ 59.790 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.056 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:12 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.455 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.575 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.672 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.765 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.238 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.407 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:33 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:57 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 27.583 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.317 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:34 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.411 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.890 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.334 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.073 s]
[INFO] Core UI Module ..................................... SUCCESS [01:05 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 30.213 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 56.066 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.058 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.483 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 11.573 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.050 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:31 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:11 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.800 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.323 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.047 s]
[INFO] Printing Module .................................... SUCCESS [ 11.666 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.357 s]
[INFO] Community Space .................................... SUCCESS [ 0.060 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:32 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.749 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.568 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.571 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.920 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.390 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.214 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.211 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.221 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.026 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.278 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.027 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.786 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.387 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:05 min]
[INFO] Excel Output Format ................................ SUCCESS [ 12.427 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.528 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.221 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.515 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 14.801 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.036 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.949 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.043 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.412 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.673 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.624 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.052 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.160 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.999 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 36.234 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.719 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.030 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.888 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.270 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.531 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.609 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.077 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.426 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.049 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.348 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.669 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.948 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.061 s]
[INFO] Importer Core Module ............................... SUCCESS [ 46.632 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.465 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.561 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.922 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 13.974 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.629 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 33.571 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.329 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.020 s]
[INFO] BUILD FAILURE
[INFO] Total time: 17:04 min (Wall Clock)
[INFO] Finished at: 2018-04-21T15:25:08+00:00
[INFO] Final Memory: 141M/1144M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
On it
On Sat, Apr 21, 2018 at 5:25 PM, <monitor@anonymised.com> wrote:
See <https://build.geoserver.org/job/geoserver-master/5738/display/redirect>
[…truncated 11.17 MB…]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-sec-cas —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
at org.hibernate.impl.SessionFactoryImpl.(SessionFactoryImpl.java:365)
[stuff]
[things]
[widgets]
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-monitor-hibernate —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-monitor-hibernate —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-monitor-hibernate —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-monitor-hibernate —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-monitor-hibernate —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/gs-monitor-hibernate-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/gs-monitor-hibernate-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer … SUCCESS [ 5.578 s]
[INFO] Core Platform Module … SUCCESS [ 11.084 s]
[INFO] Open Web Service Module … SUCCESS [ 10.636 s]
[INFO] Main Module … SUCCESS [ 59.790 s]
[INFO] GeoServer Security Modules … SUCCESS [ 0.056 s]
[INFO] GeoServer Security Tests Module … SUCCESS [01:12 min]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 35.455 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [ 19.575 s]
[INFO] Web Coverage Service Module … SUCCESS [ 3.672 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 14.765 s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [ 19.238 s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [ 37.407 s]
[INFO] Web Feature Service Module … SUCCESS [01:33 min]
[INFO] Web Map Service Module … SUCCESS [01:57 min]
[INFO] KML support for GeoServer … SUCCESS [ 27.583 s]
[INFO] gs-rest … SUCCESS [ 15.317 s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [02:34 min]
[INFO] gs-restconfig … SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs … SUCCESS [ 16.411 s]
[INFO] gs-restconfig-wfs … SUCCESS [ 17.890 s]
[INFO] gs-restconfig-wms … SUCCESS [ 12.334 s]
[INFO] GeoServer Web Modules … SUCCESS [ 0.073 s]
[INFO] Core UI Module … SUCCESS [01:05 min]
[INFO] WMS UI Module … SUCCESS [ 30.213 s]
[INFO] GWC UI Module … SUCCESS [ 56.066 s]
[INFO] WFS UI Module … SUCCESS [ 11.058 s]
[INFO] Demos Module … SUCCESS [ 16.483 s]
[INFO] WCS UI Module … SUCCESS [ 11.573 s]
[INFO] Security UI Modules … SUCCESS [ 0.050 s]
[INFO] Security UI Core Module … SUCCESS [01:31 min]
[INFO] Security UI JDBC Module … SUCCESS [01:11 min]
[INFO] Security UI LDAP Module … SUCCESS [ 18.800 s]
[INFO] REST UI Module … SUCCESS [ 10.323 s]
[INFO] GeoServer Extensions … SUCCESS [ 0.047 s]
[INFO] Printing Module … SUCCESS [ 11.666 s]
[INFO] GeoServer Web Application … SUCCESS [ 6.357 s]
[INFO] Community Space … SUCCESS [ 0.060 s]
[INFO] Application Schema Support … SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test … SUCCESS [02:32 min]
[INFO] Sample DataAccess Integration Test … SUCCESS [ 9.749 s]
[INFO] ArcSDE DataStore Extension … SUCCESS [ 10.568 s]
[INFO] H2 DataStore Extension … SUCCESS [ 10.571 s]
[INFO] SQL Server DataStore Extension … SUCCESS [ 0.920 s]
[INFO] Oracle DataStore Extension … SUCCESS [ 0.390 s]
[INFO] MySQL DataStore Extension … SUCCESS [ 0.214 s]
[INFO] DB2 DataStore Extension … SUCCESS [ 0.211 s]
[INFO] ImageMap Output Format … SUCCESS [ 7.221 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [ 4.026 s]
[INFO] JP2K Coverage Extension … SUCCESS [ 0.278 s]
[INFO] OGR parent … SUCCESS [ 0.027 s]
[INFO] OGR CORE … SUCCESS [ 1.786 s]
[INFO] OGR WFS … SUCCESS [ 8.387 s]
[INFO] Web Processing Service parent … SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module … FAILURE [01:05 min]
[INFO] OGR WPS … SKIPPED
[INFO] Excel Output Format … SUCCESS [ 12.427 s]
[INFO] Chart external graphics support … SUCCESS [ 0.528 s]
[INFO] Feature Generalization Extension … SUCCESS [ 2.221 s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [ 0.515 s]
[INFO] OWS request flow controller … SUCCESS [ 14.801 s]
[INFO] Web process status sharing with Hazelcast … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SUCCESS [ 13.036 s]
[INFO] Teradata DataStore Extension … SUCCESS [ 1.949 s]
[INFO] GeoServer Monitor Extensions … SUCCESS [ 0.043 s]
[INFO] Core Monitor Extension … SUCCESS [ 24.412 s]
[INFO] Monitor Hibernate Extension … SUCCESS [ 7.673 s]
[INFO] GeoServer Security Extension Modules … SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Module … SUCCESS [ 7.624 s]
[INFO] GeoServer Security Extension Web Modules … SUCCESS [ 0.052 s]
[INFO] GeoServer CAS Security Web Module … SUCCESS [ 2.160 s]
[INFO] XLST based WFS output format … SUCCESS [ 16.999 s]
[INFO] GeoServer INSPIRE Extensions … SUCCESS [ 36.234 s]
[INFO] GeoServer CSS Styling … SUCCESS [ 15.719 s]
[INFO] Catalog Services for the Web parent … SUCCESS [ 0.030 s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [ 8.888 s]
[INFO] Catalog Services for the Web core module … SUCCESS [ 31.531 s]
[INFO] CSW UI Module … SUCCESS [ 9.609 s]
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [ 0.077 s]
[INFO] DXF WFS output format … SUCCESS [ 11.426 s]
[INFO] DXF WPS PPIO … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [ 0.049 s]
[INFO] GeoServer libjpeg-turbo Module … SUCCESS [ 8.948 s]
[INFO] GeoServer Data Importer … SUCCESS [ 0.061 s]
[INFO] Importer Core Module … SUCCESS [ 46.632 s]
[INFO] Importer REST Api Module-ng … SUCCESS [ 43.465 s]
[INFO] Importer Berkley DB Persistence Module … SUCCESS [ 13.561 s]
[INFO] Importer Web UI Module … SUCCESS [ 12.922 s]
[INFO] GRIB Coverage Format … SUCCESS [ 13.974 s]
[INFO] NetCDF Coverage format … SUCCESS [ 15.629 s]
[INFO] WCS NetCDF output Module … SUCCESS [ 33.571 s]
[INFO] Vector Tiles … SUCCESS [ 13.329 s]
[INFO] Ysld GeoServer Plugin … SUCCESS [ 13.020 s]
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-wps-core
Build step ‘Invoke top-level Maven targets’ marked build as failure
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
See <https://build.geoserver.org/job/geoserver-master/5739/display/redirect?page=changes&gt;
