[Geoserver-devel] Build failed in Jenkins: geoserver-master #5748
See <https://build.geoserver.org/job/geoserver-master/5748/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-8718] Remove weird logs during wps animation generation, when
[...truncated 9.25 MB...]
Apr 24, 2018 4:50:21 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTTING_DOWN
Apr 24, 2018 4:50:21 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Master Address[127.0.0.1]:5009 left the cluster. Assigning new master Member [127.0.0.1]:5010 this
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Removing Member [127.0.0.1]:5009
Members [1] {
Apr 24, 2018 4:50:21 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Destroying node initializer.
Apr 24, 2018 4:50:21 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Hazelcast Shutdown is completed in 13 ms.
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTDOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 8 ms.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Apr 24, 2018 4:50:21 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
Apr 24, 2018 4:50:21 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Apr 24, 2018 4:50:21 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
  Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Members [2] {
  Member [127.0.0.1]:5012 this
Members [2] {
Apr 24, 2018 4:50:22 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Apr 24, 2018 4:50:22 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Apr 24, 2018 4:50:22 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Apr 24, 2018 4:50:22 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Apr 24, 2018 4:50:22 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Apr 24, 2018 4:50:22 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 13 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 8 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.742 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.229 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.031 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.595 s]
[INFO] Main Module ........................................ SUCCESS [01:16 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.094 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:19 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.691 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 23.651 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.284 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 19.496 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 23.070 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.241 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:57 min]
[INFO] Web Map Service Module ............................. FAILURE [02:02 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 19.021 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:39 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 18.981 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.030 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.062 s]
[INFO] Core UI Module ..................................... SUCCESS [01:23 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.335 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.041 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:36 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:04 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.042 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.535 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Printing Module .................................... SUCCESS [ 18.071 s]
[INFO] Community Space .................................... SUCCESS [ 0.076 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.057 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.660 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.623 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.969 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.946 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.376 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.206 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.223 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.837 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.287 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.039 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.228 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.746 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.054 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:07 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.456 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.061 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.476 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.488 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.478 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 16.547 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 25.942 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.583 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.056 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.036 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.773 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.021 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.686 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.319 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.062 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.903 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.275 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 30.504 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.189 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.025 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.375 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.949 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.027 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.980 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.503 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.057 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:22 min (Wall Clock)
[INFO] Finished at: 2018-04-24T16:50:22+00:00
[INFO] Final Memory: 131M/1022M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Fix incoming
On Tue, Apr 24, 2018 at 6:50 PM, <monitor@anonymised.com> wrote:
See <https://build.geoserver.org/job/geoserver-master/5748/display/redirect?page=changes>
Changes:
[…truncated 9.25 MB…]
Members [1] {
Members [1] {
Members [2] {
Members [2] {
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement…
Members [1] {
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer … SUCCESS [ 5.229 s]
[INFO] Core Platform Module … SUCCESS [ 14.031 s]
[INFO] Open Web Service Module … SUCCESS [ 11.595 s]
[INFO] Main Module … SUCCESS [01:16 min]
[INFO] GeoServer Security Modules … SUCCESS [ 0.094 s]
[INFO] GeoServer Security Tests Module … SUCCESS [01:19 min]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 35.691 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [ 23.651 s]
[INFO] Web Coverage Service Module … SUCCESS [ 4.284 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 19.496 s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [ 23.070 s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [ 37.241 s]
[INFO] Web Feature Service Module … SUCCESS [01:57 min]
[INFO] Web Map Service Module … FAILURE [02:02 min]
[INFO] KML support for GeoServer … SKIPPED
[INFO] gs-rest … SUCCESS [ 19.021 s]
[INFO] GeoWebCache (GWC) Module … SKIPPED
[INFO] gs-restconfig … SUCCESS [01:39 min]
[INFO] gs-restconfig-wcs … SUCCESS [ 18.981 s]
[INFO] gs-restconfig-wfs … SUCCESS [ 18.030 s]
[INFO] gs-restconfig-wms … SKIPPED
[INFO] GeoServer Web Modules … SUCCESS [ 0.062 s]
[INFO] Core UI Module … SUCCESS [01:23 min]
[INFO] WMS UI Module … SKIPPED
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SUCCESS [ 10.335 s]
[INFO] Demos Module … SKIPPED
[INFO] WCS UI Module … SKIPPED
[INFO] Security UI Modules … SUCCESS [ 0.041 s]
[INFO] Security UI Core Module … SUCCESS [01:36 min]
[INFO] Security UI JDBC Module … SUCCESS [01:04 min]
[INFO] Security UI LDAP Module … SUCCESS [ 18.042 s]
[INFO] REST UI Module … SUCCESS [ 10.535 s]
[INFO] GeoServer Extensions … SUCCESS [ 0.054 s]
[INFO] Printing Module … SUCCESS [ 18.071 s]
[INFO] GeoServer Web Application … SKIPPED
[INFO] Community Space … SUCCESS [ 0.076 s]
[INFO] Application Schema Support … SUCCESS [ 0.057 s]
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SUCCESS [ 9.660 s]
[INFO] ArcSDE DataStore Extension … SUCCESS [ 13.623 s]
[INFO] H2 DataStore Extension … SUCCESS [ 10.969 s]
[INFO] SQL Server DataStore Extension … SUCCESS [ 0.946 s]
[INFO] Oracle DataStore Extension … SUCCESS [ 0.376 s]
[INFO] MySQL DataStore Extension … SUCCESS [ 0.206 s]
[INFO] DB2 DataStore Extension … SUCCESS [ 0.223 s]
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [ 4.837 s]
[INFO] JP2K Coverage Extension … SUCCESS [ 0.287 s]
[INFO] OGR parent … SUCCESS [ 0.039 s]
[INFO] OGR CORE … SUCCESS [ 2.228 s]
[INFO] OGR WFS … SUCCESS [ 8.746 s]
[INFO] Web Processing Service parent … SUCCESS [ 0.054 s]
[INFO] Web Processing Service Module … SUCCESS [01:07 min]
[INFO] OGR WPS … SUCCESS [ 8.456 s]
[INFO] Excel Output Format … SUCCESS [ 12.061 s]
[INFO] Chart external graphics support … SUCCESS [ 0.476 s]
[INFO] Feature Generalization Extension … SUCCESS [ 2.488 s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [ 0.478 s]
[INFO] OWS request flow controller … SUCCESS [ 16.547 s]
[INFO] Web process status sharing with Hazelcast … SUCCESS [ 25.942 s]
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SUCCESS [ 13.583 s]
[INFO] Teradata DataStore Extension … SUCCESS [ 3.056 s]
[INFO] GeoServer Monitor Extensions … SUCCESS [ 0.036 s]
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module … SUCCESS [ 4.773 s]
[INFO] GeoServer Security Extension Web Modules … SUCCESS [ 0.021 s]
[INFO] GeoServer CAS Security Web Module … SUCCESS [ 1.686 s]
[INFO] XLST based WFS output format … SUCCESS [ 17.319 s]
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SUCCESS [ 0.062 s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [ 8.903 s]
[INFO] Catalog Services for the Web core module … SUCCESS [ 30.504 s]
[INFO] CSW UI Module … SUCCESS [ 9.189 s]
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [ 0.025 s]
[INFO] DXF WFS output format … SUCCESS [ 11.375 s]
[INFO] DXF WPS PPIO … SUCCESS [ 6.949 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [ 0.027 s]
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] Importer REST Api Module-ng … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[INFO] GRIB Coverage Format … SUCCESS [ 19.057 s]
[INFO] NetCDF Coverage format … SKIPPED
[INFO] WCS NetCDF output Module … SKIPPED
[INFO] Vector Tiles … SKIPPED
[INFO] Ysld GeoServer Plugin … SKIPPED
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-wms
Build step ‘Invoke top-level Maven targets’ marked build as failure
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
See <https://build.geoserver.org/job/geoserver-master/5749/display/redirect?page=changes&gt;
