See <https://build.geoserver.org/job/geoserver-master/5753/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-8721] KML Module build gets stuck trying to reach to example.com
[...truncated 11.26 MB...]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.war
Apr 25, 2018 10:54:12 AM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
[INFO]
[INFO] Building Monitor Hibernate Extension 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-monitor-hibernate ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-monitor-hibernate ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-monitor-hibernate ---
[INFO] Copying 1 resource
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-monitor-hibernate ---
[INFO] Compiling 11 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/classes>
Apr 25, 2018 10:54:14 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 38
Apr 25, 2018 10:54:15 AM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 42
Apr 25, 2018 10:54:15 AM org.geoserver.catalog.ResourcePool getFeatureType
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-monitor-hibernate ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-monitor-hibernate ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/test-classes>
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.345 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
[ERROR] COMPILATION ERROR :
[ERROR] Failure executing javac, but could not parse the error:
javac: file not found: /tmp/org.codehaus.plexus.compiler.javac.JavacCompiler5591127708238695076arguments (No such file or directory)
[INFO] 1 error
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
Apr 25, 2018 10:54:17 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Apr 25, 2018 10:54:17 AM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.651 sec
Results :
Tests run: 70, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.991 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.086 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.012 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.064 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:13 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.380 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.062 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.740 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.865 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.438 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.702 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:33 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:57 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.369 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.515 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:34 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.819 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.730 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.291 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.055 s]
[INFO] Core UI Module ..................................... SUCCESS [01:06 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 30.659 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 53.898 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.969 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.286 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 17.722 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.063 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:30 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:01 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.442 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.432 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.060 s]
[INFO] Printing Module .................................... SUCCESS [ 13.563 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.755 s]
[INFO] Community Space .................................... SUCCESS [ 0.057 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:30 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.145 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.407 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.912 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.890 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.394 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.220 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.582 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 6.947 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.829 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.329 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.025 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.009 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.627 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:04 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.410 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.026 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.471 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.401 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.508 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.635 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.807 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 23.675 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.896 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.962 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.032 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.116 s]
[INFO] Monitor Hibernate Extension ........................ FAILURE [ 3.034 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.324 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.040 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.839 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.561 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 36.813 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.171 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.050 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.769 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.684 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.044 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.265 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.055 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.784 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.041 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.016 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.260 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.832 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.957 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.061 s]
[INFO] Importer Core Module ............................... SUCCESS [ 49.333 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 45.362 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.426 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.291 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.342 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.375 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 50.012 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.131 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.479 s]
[INFO] BUILD FAILURE
[INFO] Total time: 17:46 min (Wall Clock)
[INFO] Finished at: 2018-04-25T10:54:19+00:00
[INFO] Final Memory: 144M/1175M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-monitor-hibernate: Compilation failure
[ERROR] javac: file not found: /tmp/org.codehaus.plexus.compiler.javac.JavacCompiler5591127708238695076arguments (No such file or directory)
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-monitor-hibernate
