See <https://build.geoserver.org/job/geoserver-master/5764/display/redirect?page=changes>
Changes:
[Ian Turton] Read/Write CSV in WPS (#2852)
[...truncated 9.25 MB...]
Apr 27, 2018 9:43:50 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTTING_DOWN
Apr 27, 2018 9:43:50 AM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Master Address[127.0.0.1]:5009 left the cluster. Assigning new master Member [127.0.0.1]:5010 this
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Removing Member [127.0.0.1]:5009
Members [1] {
Apr 27, 2018 9:43:50 AM com.hazelcast.initializer
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Destroying node initializer.
Apr 27, 2018 9:43:50 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Hazelcast Shutdown is completed in 18 ms.
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTDOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 11 ms.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Apr 27, 2018 9:43:50 AM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
Apr 27, 2018 9:43:50 AM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Apr 27, 2018 9:43:50 AM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Members [2] {
Member [127.0.0.1]:5012 this
Members [2] {
Apr 27, 2018 9:43:51 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Apr 27, 2018 9:43:51 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Apr 27, 2018 9:43:51 AM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Apr 27, 2018 9:43:57 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Apr 27, 2018 9:43:57 AM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Apr 27, 2018 9:43:57 AM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Apr 27, 2018 9:43:57 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 12 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 7 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.808 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.157 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.202 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.725 s]
[INFO] Main Module ........................................ SUCCESS [ 59.277 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.070 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:12 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.427 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.271 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.898 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.384 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.846 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 38.280 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:34 min]
[INFO] Web Map Service Module ............................. FAILURE [01:56 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 15.452 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:19 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.537 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.093 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.062 s]
[INFO] Core UI Module ..................................... SUCCESS [01:05 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 9.949 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.092 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:29 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:05 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.922 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.636 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] Printing Module .................................... SUCCESS [ 11.893 s]
[INFO] Community Space .................................... SUCCESS [ 0.067 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.092 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.637 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.049 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.889 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.373 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.222 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.208 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.419 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.297 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.936 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.566 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:08 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.635 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.456 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.434 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.335 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.591 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.384 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 27.370 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.190 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.961 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.058 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.773 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.645 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.932 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.121 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.568 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.178 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.310 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.975 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.050 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.645 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.454 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.039 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.026 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.539 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.989 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:11 min (Wall Clock)
[INFO] Finished at: 2018-04-27T09:43:57+00:00
[INFO] Final Memory: 131M/1053M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
