See <https://build.geoserver.org/job/geoserver-master/5801/display/redirect>
[...truncated 11.19 MB...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
May 08, 2018 6:33:45 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 24
May 08, 2018 6:33:45 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
May 08, 2018 6:33:46 PM org.geoserver.catalog.ResourcePool getFeatureType
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-monitor-hibernate ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-monitor-hibernate ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/monitor/hibernate/target/test-classes>
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.662 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] Failure executing javac, but could not parse the error:
javac: file not found: /tmp/org.codehaus.plexus.compiler.javac.JavacCompiler4451453544450741514arguments (No such file or directory)
[INFO] 1 error
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
May 08, 2018 6:33:47 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
May 08, 2018 6:33:48 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.567 sec
Results :
Tests run: 72, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.812 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.972 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.512 s]
[INFO] Main Module ........................................ SUCCESS [ 59.061 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.060 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:17 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.118 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.351 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.753 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.792 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.215 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 39.195 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:34 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:59 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.166 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.637 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:33 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:18 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.851 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.946 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.502 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.055 s]
[INFO] Core UI Module ..................................... SUCCESS [01:07 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 30.875 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 55.917 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.261 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.678 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 18.971 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.145 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:30 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:03 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.235 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.651 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.046 s]
[INFO] Printing Module .................................... SUCCESS [ 12.168 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.521 s]
[INFO] Community Space .................................... SUCCESS [ 0.058 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:33 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.902 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.643 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.070 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.903 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.386 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.211 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.197 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.384 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.134 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.265 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.055 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.915 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.772 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:06 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.854 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.201 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.528 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.229 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.496 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.097 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 28.966 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.668 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.366 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.985 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.034 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.682 s]
[INFO] Monitor Hibernate Extension ........................ FAILURE [ 2.766 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.170 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.170 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.489 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 38.179 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.405 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.071 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.015 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.943 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.963 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.420 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.062 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.865 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.150 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.019 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.472 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.033 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.841 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.047 s]
[INFO] Importer Core Module ............................... SUCCESS [ 48.733 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 46.256 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.609 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.455 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.194 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.787 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 51.349 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.412 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.739 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.848 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:03 min (Wall Clock)
[INFO] Finished at: 2018-05-08T18:33:49+00:00
[INFO] Final Memory: 144M/1164M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-monitor-hibernate: Compilation failure
[ERROR] javac: file not found: /tmp/org.codehaus.plexus.compiler.javac.JavacCompiler4451453544450741514arguments (No such file or directory)
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-monitor-hibernate
