See <https://build.geoserver.org/job/geoserver-master/5874/display/redirect?page=changes>
Changes:
[Andrea Aime] Upgrading to Spring 4.3.17 to avoid potential CVE-2018-1275. GeoServer
[...truncated 11.80 MB...]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-oauth2-github ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-oauth2-geonode ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-oauth2-geonode ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-oauth2-github ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-oauth2-github ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-oauth2-github ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-oauth2-github ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-oauth2-github ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-oauth2-github ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO web UI 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-oauth2-geonode ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-oauth2-geonode ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-oauth2-geonode ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-oauth2-geonode ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-oauth2-geonode ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-oauth2-geonode ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 28 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.174 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.332 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.736 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.016 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.923 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.644 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.461 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 4.171 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.799 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.648 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 19.292 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 8.452 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.592 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.274 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.751 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.100 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.682 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.852 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.935 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.623 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.366 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.283 s]
[INFO] DownloadProcess .................................... SUCCESS [ 8.719 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.223 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.764 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 4.238 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 10.199 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.555 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.982 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 9.435 s]
[INFO] GeoFence Server .................................... SUCCESS [ 8.475 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.587 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.351 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.891 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 3.805 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.455 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.658 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.015 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.312 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.981 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 3.940 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.329 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 26.238 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.731 s]
[INFO] GeoServer Config Backup And Restore Core Module .... FAILURE [ 1.707 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 4.964 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.010 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 4.753 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.877 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.863 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.874 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.551 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.962 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.734 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.808 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.849 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.025 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 9.013 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.962 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 7.041 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.400 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 5.342 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 16.262 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 11.212 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 7.983 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 7.264 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.133 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 6.159 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.766 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 30.627 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 5.378 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:51 min (Wall Clock)
[INFO] Finished at: 2018-06-03T09:27:31+00:00
[INFO] Final Memory: 160M/1104M
[ERROR] Failed to execute goal on project gs-backup-restore-core: Could not resolve dependencies for project org.geoserver.community.backuprestore:gs-backup-restore-core:jar:2.14-SNAPSHOT: Could not find artifact org.springframework.integration:spring-integration-core:jar:4.3.17.RELEASE in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-backup-restore-core
