See <https://build.geoserver.org/job/geoserver-master/5880/display/redirect?page=changes> ;
Changes:
[niels] TaskManager Community Module (part 4, with docs)
[...truncated 11.97 MB...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target> ;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes> ;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Task Manager S3 2.14-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.5.1/geoserver-manager-1.5.1.pom
[INFO] Downloaded: https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.5.1/geoserver-manager-1.5.1.pom (10 KB at 848.9 KB/sec)
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-core:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-core:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd\ ): Not authorized , ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools:gt-jdbc:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-jdbc:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd\ ): Not authorized , ReasonPhrase:Unauthorized.
[INFO] Downloading: https://www.milieuinfo.be/artifactory/acd/org/geotools/gt-s3-geotiff/20-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-s3-geotiff:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd ): Not authorized , ReasonPhrase:Unauthorized.
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes> ;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 28 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes> ;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes> ;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Community Release Module 2.14-SNAPSHOT
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml (2 KB at 139.0 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.pom
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.pom
[INFO] Downloading: http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.pom
[WARNING] The POM for it.geosolutions:geoserver-manager:jar:1.8-dov-0.3-SNAPSHOT is missing, no dependency information available
[WARNING] Failure to transfer org.geotools.jdbc:gt-jdbc-postgis:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.jdbc:gt-jdbc-postgis:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd\ ): Not authorized , ReasonPhrase:Unauthorized.
[INFO] Downloading: https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.jar
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.jar
[INFO] Downloading: http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.jar
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.105 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.589 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.127 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.311 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.528 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.729 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.387 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.656 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 3.627 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.492 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 18.937 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.159 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.158 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.646 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.299 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.071 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.863 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.100 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.137 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 7.458 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.818 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.984 s]
[INFO] DownloadProcess .................................... SUCCESS [ 8.432 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.272 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.333 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.464 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 10.078 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.482 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.406 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 9.271 s]
[INFO] GeoFence Server .................................... SUCCESS [ 8.809 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.811 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.597 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.285 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 7.055 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.560 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.876 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.016 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.581 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 6.442 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.103 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.387 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 27.225 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.762 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 9.288 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.355 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.488 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.627 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.130 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.011 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 5.992 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.708 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.576 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 6.679 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.595 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.057 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 3.077 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 5.309 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 3.028 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.023 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 5.343 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.760 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 7.859 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.098 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 3.723 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 16.742 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 10.274 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 12.021 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 4.029 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 5.203 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 30.146 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 6.233 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 1.124 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 5.779 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 6.476 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.730 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.109 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:12 min (Wall Clock)
[INFO] Finished at: 2018-06-05T14:18:25+00:00
[INFO] Final Memory: 169M/1098M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.14-SNAPSHOT: Could not find artifact it.geosolutions:geoserver-manager:jar:1.8-dov-0.3-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/ ) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
Not sending mail to unregistered user niels@anonymised.com
Hi Niels,
the build failed with:
On Tue, Jun 5, 2018 at 4:18 PM, <monitor@anonymised.com > wrote:
See <https://build.geoserver.org/job/geoserver-master/5880/display/redirect?page=changes >
Changes:
[…truncated 11.97 MB…]
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-notification —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest —
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target >
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest —
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes >
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar >
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-oseo —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar
[INFO]
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-core:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-core:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd ): Not authorized , ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools:gt-jdbc:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-jdbc:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd ): Not authorized , ReasonPhrase:Unauthorized.
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 —
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 —
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources >
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 —
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes >
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest —
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes >
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 —
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes >
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar >
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar >
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar
[INFO]
[WARNING] Failure to transfer org.geotools.jdbc:gt-jdbc-postgis:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.jdbc:gt-jdbc-postgis:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd ): Not authorized , ReasonPhrase:Unauthorized.
[INFO]
[INFO] Community Space … SUCCESS [ 6.105 s]
[INFO] Authentication by unique url key … SUCCESS [ 7.589 s]
[INFO] WorldWind Format Module … SUCCESS [ 7.127 s]
[INFO] SpatiaLite Extension … SUCCESS [ 6.311 s]
[INFO] GeoServer JDBC KV Catalog … SUCCESS [ 9.528 s]
[INFO] Aggregating Data Store … SUCCESS [ 3.729 s]
[INFO] GeoServer Scripting Extensions … SUCCESS [ 2.387 s]
[INFO] Core Scripting Extension … SUCCESS [ 7.656 s]
[INFO] Web UI Scripting Extension … SUCCESS [ 3.627 s]
[INFO] BeanShell Scripting Extension … SUCCESS [ 3.492 s]
[INFO] Groovy Scripting Extension … SUCCESS [ 18.937 s]
[INFO] Python Scripting Extension … SUCCESS [ 10.159 s]
[INFO] JavaScript Scripting Extension … SUCCESS [ 7.158 s]
[INFO] Ruby Scripting Extension … SUCCESS [ 4.646 s]
[INFO] WMS-EO … SUCCESS [ 6.299 s]
[INFO] ColorMap … SUCCESS [ 6.071 s]
[INFO] GeoServer mbtiles Extension … SUCCESS [ 6.863 s]
[INFO] GeoServer GeoPackage Extension … SUCCESS [ 7.100 s]
[INFO] Dynamic WMS dimension value defaults … SUCCESS [ 7.458 s]
[INFO] GPX PPIO for WPS … SUCCESS [ 5.818 s]
[INFO] KML PPIO for WPS … SUCCESS [ 5.984 s]
[INFO] DownloadProcess … SUCCESS [ 8.432 s]
[INFO] GeoServer JMS based clustering modules … SUCCESS [ 0.272 s]
[INFO] ActiveMQ … SUCCESS [ 4.333 s]
[INFO] GeoServer JMS clustering Commons module … SUCCESS [ 2.464 s]
[INFO] GeoServer JMS clustering module … SUCCESS [ 10.078 s]
[INFO] GeoServer Hazelcast Clustering Module … SUCCESS [ 8.482 s]
[INFO] Solr Module … SUCCESS [ 6.406 s]
[INFO] GeoFence security integration … SUCCESS [ 9.271 s]
[INFO] GeoFence Server … SUCCESS [ 8.809 s]
[INFO] Parameters Extractor … SUCCESS [ 6.811 s]
[INFO] WPS cluster on jdbc datastores … SUCCESS [ 6.285 s]
[INFO] ncWMS compatibility extension … SUCCESS [ 7.055 s]
[INFO] GWC Distributed Caching Plugin … SUCCESS [ 2.560 s]
[INFO] GeoWebCache S3 … SUCCESS [ 4.876 s]
[INFO] GDAL translate parent … SUCCESS [ 0.016 s]
[INFO] GDAL translate WCS … SUCCESS [ 6.581 s]
[INFO] GDAL translate WPS … SUCCESS [ 6.442 s]
[INFO] GeoServer JDBC Configuration Resource Store … SUCCESS [ 7.103 s]
[INFO] GeoWebCache SQLite … SUCCESS [ 5.387 s]
[INFO] GeoGig GeoServer integration … SUCCESS [ 27.225 s]
[INFO] GeoServer Config Backup And Restore … SUCCESS [ 0.762 s]
[INFO] GeoServer Config Backup And Restore Core Module … SUCCESS [ 9.288 s]
[INFO] GeoServer Config Backup And Restore REST Module … SUCCESS [ 6.355 s]
[INFO] GeoServer Config Backup And Restore Extensions … SUCCESS [ 2.488 s]
[INFO] GeoServer Config Backup And Restore Web UI Module … SUCCESS [ 4.627 s]
[INFO] WMTS Multi Dimensional … SUCCESS [ 5.130 s]
[INFO] GeoServer Security Community Modules … SUCCESS [ 0.011 s]
[INFO] GeoServer OAuth2 Connect Security Module … SUCCESS [ 5.992 s]
[INFO] GeoServer OneLogin Module … SUCCESS [ 3.595 s]
[INFO] gs-notification-common … SUCCESS [ 1.057 s]
[INFO] OWS Dispatcher Simulate Plugin … SUCCESS [ 5.309 s]
[INFO] JDBC Metrics Plugin … SUCCESS [ 3.028 s]
[INFO] OpenSearch EO parent … SUCCESS [ 0.023 s]
[INFO] OpenSearch for EO … SUCCESS [ 5.343 s]
[INFO] OpenSearch for EO web UI … SUCCESS [ 5.760 s]
[INFO] OpenSearch for EO REST configuration API … SUCCESS [ 7.859 s]
[INFO] GeoServer Mapbox Styling … SUCCESS [ 6.098 s]
[INFO] GeoServer Status Monitoring Module … SUCCESS [ 3.723 s]
[INFO] NSG WMTS 1.0 Profile … SUCCESS [ 16.742 s]
[INFO] NSG WFS 2.0 Profile … SUCCESS [ 10.274 s]
[INFO] NetCDF GHRSST encoder … SUCCESS [ 12.021 s]
[INFO] WFS 3 prototype … SUCCESS [ 4.029 s]
[INFO] GeoServer Task Manager … SUCCESS [ 5.203 s]
[INFO] GeoServer Task Manager Core … SUCCESS [ 30.146 s]
[INFO] GeoServer Task Manager S3 … SUCCESS [ 6.233 s]
[INFO] GeoServer Community Release Module … FAILURE [ 1.124 s]
[INFO] GeoServer Resource Browser … SUCCESS [ 5.779 s]
[INFO] GeoServer notification event system … SUCCESS [ 6.476 s]
[INFO] S3 Geotiff Support … SUCCESS [ 2.730 s]
[INFO] Monitor Hibernate Extension … SUCCESS [ 7.109 s]
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.14-SNAPSHOT: Could not find artifact it.geosolutions:geoserver-manager:jar:1.8-dov-0.3-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/ ) → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-release
Build step ‘Invoke top-level Maven targets’ marked build as failure
engaging tech sites, Slashdot.org ! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Niels,
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.14-SNAPSHOT: Could not find artifact it.geosolutions:geoserver-manager:jar:1.8-dov-0.3-SNAPSHOT in boundless ([https://repo.boundlessgeo.com/main/](https://repo.boundlessgeo.com/main/)) -> [Help 1]
Grepping the code, it seems only the task-manager module uses geoserver-manager (a bit of a strange dependency, it’s normally used
to talk to the GeoServer REST API, but a module running inside GeoServer should not need it, unless it’s talking to other GeoServers).
On Tue, Jun 5, 2018 at 4:28 PM, Andrea Aime <andrea.aime@anonymised.com > wrote:
Hi Niels,
Changes:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR]
[ERROR]
Geoserver-devel@anonymised.comrge.net
It is indeed used to talk to other geoservers.
I also had to let it depend on a forked geoserver-manager, because I needed to fix bugs and add some additional features, and the official geoserver-manager project is inactive (I have not been able to get any response on proposed bug patches in about a year, via github or email).
Am I allowed to add a repository to the community release pom to download the forked geoserver-manager from?
Regards
Niels
On 05-06-18 16:29, Andrea Aime wrote:
Hi Niels,
Grepping the code, it seems only the task-manager module uses geoserver-manager (a bit of a strange dependency, it's normally used
to talk to the GeoServer REST API, but a module running inside GeoServer should not need it, unless it's talking to other GeoServers).
On Tue, Jun 5, 2018 at 4:28 PM, Andrea Aime <andrea.aime@anonymised.com <mailto:andrea.aime@anonymised.com>> wrote:
Hi Niels,
<mailto:monitor@anonymised.com>> wrote:
See
<https://build.geoserver.org/job/geoserver-master/5880/display/redirect?page=changes>> ;
Changes:
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar>> ;
[INFO]
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar>> ;
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml>> ;
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar>> ;
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar>> ;
to
[INFO] Installing
to
[INFO]
2.14-SNAPSHOT
[INFO]
[INFO]
gs-oseo-rest ---
[INFO] Deleting
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target>> ;
[INFO]
gs-oseo-rest ---
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes>> ;
[INFO]
gs-web-oseo ---
[INFO]
gs-web-oseo ---
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar>> ;
[INFO]
gs-web-oseo ---
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar>> ;
[INFO]
@ gs-web-oseo ---
[INFO] Installing
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml>> ;
to
[INFO] Installing
to
[INFO] Installing
to
[INFO] Installing
to
[INFO]
[INFO]
[INFO] Downloading:
<https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.5.1/geoserver-manager-1.5.1.pom> ;
[INFO] Downloaded:
<https://www.milieuinfo.be/artifactory/acd> ; was cached in the
<https://www.milieuinfo.be/artifactory/acd>\ ): Not authorized ,
[INFO] Downloading:
<https://www.milieuinfo.be/artifactory/acd/org/geotools/gt-s3-geotiff/20-SNAPSHOT/maven-metadata.xml> ;
[INFO]
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes>> ;
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes>> ;
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes>> ;
[INFO]
gs-oseo-rest ---
[INFO]
gs-oseo-rest ---
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar>> ;
[INFO]
gs-oseo-rest ---
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar>> ;
[INFO]
@ gs-oseo-rest ---
[INFO] Installing
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml>> ;
to
[INFO] Installing
to
[INFO] Installing
to
[INFO] Installing
to
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar>> ;
[INFO]
[INFO] Installing
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml>> ;
to
[INFO] Installing
to
[INFO] Installing
to
[INFO] Installing
to
[INFO]
[INFO]
[INFO] Downloading:
<http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloading:
<https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloading:
<http://maven.geo-solutions.it/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloaded:
[INFO] Downloading:
<https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloading:
<http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloading:
<http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloading:
<https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.pom> ;
[INFO] Downloading:
<http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.pom> ;
[INFO] Downloading:
<http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.pom> ;
[INFO] Downloading:
<https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.jar> ;
[INFO] Downloading:
<http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.jar> ;
[INFO] Downloading:
<http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3-SNAPSHOT/geoserver-manager-1.8-dov-0.3-SNAPSHOT.jar> ;
[INFO]
[INFO]
SUCCESS [ 6.105 s]
SUCCESS [ 7.589 s]
SUCCESS [ 7.127 s]
SUCCESS [ 6.311 s]
SUCCESS [ 9.528 s]
SUCCESS [ 3.729 s]
SUCCESS [ 2.387 s]
SUCCESS [ 7.656 s]
SUCCESS [ 3.627 s]
SUCCESS [ 3.492 s]
SUCCESS [ 18.937 s]
SUCCESS [ 10.159 s]
SUCCESS [ 7.158 s]
SUCCESS [ 4.646 s]
SUCCESS [ 6.299 s]
SUCCESS [ 6.071 s]
SUCCESS [ 6.863 s]
SUCCESS [ 7.100 s]
SUCCESS [ 7.458 s]
SUCCESS [ 5.818 s]
SUCCESS [ 5.984 s]
SUCCESS [ 8.432 s]
SUCCESS [ 0.272 s]
SUCCESS [ 4.333 s]
SUCCESS [ 2.464 s]
SUCCESS [ 10.078 s]
SUCCESS [ 8.482 s]
SUCCESS [ 6.406 s]
SUCCESS [ 9.271 s]
SUCCESS [ 8.809 s]
SUCCESS [ 6.811 s]
SUCCESS [ 8.597 s]
SUCCESS [ 6.285 s]
SUCCESS [ 7.055 s]
SUCCESS [ 2.560 s]
SUCCESS [ 4.876 s]
SUCCESS [ 0.016 s]
SUCCESS [ 6.581 s]
SUCCESS [ 6.442 s]
SUCCESS [ 7.103 s]
SUCCESS [ 5.387 s]
SUCCESS [ 27.225 s]
SUCCESS [ 0.762 s]
SUCCESS [ 9.288 s]
SUCCESS [ 6.355 s]
SUCCESS [ 2.488 s]
SUCCESS [ 4.627 s]
SUCCESS [ 5.130 s]
SUCCESS [ 0.011 s]
SUCCESS [ 5.992 s]
SUCCESS [ 3.595 s]
SUCCESS [ 1.057 s]
SUCCESS [ 5.309 s]
SUCCESS [ 3.028 s]
SUCCESS [ 0.023 s]
SUCCESS [ 5.343 s]
SUCCESS [ 5.760 s]
SUCCESS [ 7.859 s]
SUCCESS [ 6.098 s]
SUCCESS [ 3.723 s]
SUCCESS [ 16.742 s]
SUCCESS [ 10.274 s]
SUCCESS [ 12.021 s]
SUCCESS [ 4.029 s]
SUCCESS [ 5.203 s]
SUCCESS [ 30.146 s]
SUCCESS [ 6.233 s]
FAILURE [ 1.124 s]
SUCCESS [ 5.779 s]
SUCCESS [ 6.476 s]
SUCCESS [ 2.730 s]
SUCCESS [ 7.109 s]
[INFO]
[INFO]
[INFO]
not find artifact
<https://repo.boundlessgeo.com/main/>\ ) -> [Help 1]
[ERROR]
logging.
[ERROR]
[ERROR] [Help 1]
<http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException> ;
[ERROR]
failure
<mailto:niels@anonymised.com>
Check out the vibrant tech community on one of the world's most
<mailto:Geoserver-devel@lists.sourceforge.net>
<https://lists.sourceforge.net/lists/listinfo/geoserver-devel> ;
<http://twitter.com/geosolutions_it> ;
------------------------------------------------------- /Con
e-mail./
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- /Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail./
The project is indeed, as far as I know, inactive.
Hmm... better not to, repositories should be either large/well
known/official ones, or under the control of the GeoServer PSC.
Maybe someone from Boundless can upload this forked jar to the repo? Would
be best not to depend on it at all, to be honest
(and if at all possible, make it not a snapshot).
------------------------------------------------------- *Con riferimento
telephone or e-mail.*
Right, that version is actually wrong, which may explain why maven couldn't find it. I did actually already add the custom repo to the community module itself, so normally maven should already have downloaded it by the time it is building release and it shouldn't have failed.
But, if that is okay, in the next coming weeks I will find a better solution for this fork and remove the custom repository from the community module. For now fixing the version should normally fix the build.
Regards
Niels
On 05-06-18 16:38, Andrea Aime wrote:
On Tue, Jun 5, 2018 at 4:34 PM, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
Hmm... better not to, repositories should be either large/well known/official ones, or under the control of the GeoServer PSC.
Maybe someone from Boundless can upload this forked jar to the repo? Would be best not to depend on it at all, to be honest
See <https://build.geoserver.org/job/geoserver-master/5881/display/redirect?page=changes> ;
Changes:
[Andrea Aime] [GEOS-8770] REST: listing granules in a structured coverage view fails
[Andrea Aime] [GEOS-8771] REST: cannot harvest files unless the input has file://
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target> ;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml (2 KB at 8.0 KB/sec)
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.803 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.900 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.108 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.517 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.313 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.070 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.357 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.541 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 3.760 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 2.639 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 18.031 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.924 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.895 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.800 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.593 s]
[INFO] ColorMap ........................................... SUCCESS [ 7.027 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.716 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.352 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.092 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.966 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.882 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.094 s]
[INFO] DownloadProcess .................................... SUCCESS [ 8.600 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.274 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.715 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.162 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 10.440 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.675 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.867 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 9.459 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.072 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 8.134 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.936 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.367 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.909 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.681 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.987 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.012 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.533 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 6.297 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.356 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.592 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 27.372 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.919 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 9.298 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.901 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.921 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.412 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 4.949 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 5.683 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.594 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.583 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 6.252 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.606 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.983 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 3.022 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.707 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.747 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.034 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 5.320 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.214 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 7.175 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.661 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 5.361 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 17.386 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 9.559 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 7.897 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 6.294 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 3.085 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 31.051 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 6.958 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 1.510 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 4.759 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.902 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.958 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.203 s]
[INFO] Finished at: 2018-06-05T15:04:41+00:00
[INFO] Final Memory: 169M/1132M
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5882/display/redirect?page=changes> ;
Changes:
[niels] taskmanager: fix gs-man dep version
[...truncated 11.96 MB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target> ;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes> ;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Task Manager S3 2.14-SNAPSHOT
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-core:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-core:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd\ ): Not authorized , ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools:gt-jdbc:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-jdbc:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd\ ): Not authorized , ReasonPhrase:Unauthorized.
[INFO] Downloading: https://www.milieuinfo.be/artifactory/acd/org/geotools/gt-s3-geotiff/20-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-s3-geotiff:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd ): Not authorized , ReasonPhrase:Unauthorized.
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes> ;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 28 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes> ;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes> ;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Community Release Module 2.14-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml (2 KB at 8.1 KB/sec)
[WARNING] Failure to transfer org.geotools.jdbc:gt-jdbc-postgis:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.jdbc:gt-jdbc-postgis:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd\ ): Not authorized , ReasonPhrase:Unauthorized.
[INFO] Downloading: https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar
[INFO] Downloading: http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar
[INFO] Downloading: https://repo.maven.apache.org/maven2/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 8.870 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.727 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.319 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.498 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.314 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.025 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.480 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.602 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 3.592 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 2.543 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 17.059 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.961 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.614 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.263 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.989 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.436 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.628 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.389 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.176 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 7.052 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.401 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.984 s]
[INFO] DownloadProcess .................................... SUCCESS [ 8.741 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.188 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.746 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.175 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 11.141 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.164 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.990 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 10.175 s]
[INFO] GeoFence Server .................................... SUCCESS [ 10.221 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 8.466 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 9.333 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.076 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.745 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.013 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.022 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.009 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 7.213 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 6.308 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.381 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.408 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 26.513 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.793 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 8.871 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.798 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.679 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.214 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.871 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.010 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 5.807 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.009 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.703 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.851 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.587 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.030 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.704 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 4.751 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 3.440 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.015 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 6.033 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.560 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 7.490 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.364 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 5.484 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 20.278 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 10.768 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 8.096 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 5.555 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 2.717 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 30.771 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 6.553 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 0.837 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.109 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 6.123 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.594 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.975 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:16 min (Wall Clock)
[INFO] Finished at: 2018-06-05T15:59:57+00:00
[INFO] Final Memory: 168M/1128M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.14-SNAPSHOT: Could not find artifact it.geosolutions:geoserver-manager:jar:1.8-dov-0.3 in boundless (https://repo.boundlessgeo.com/main/ ) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
Not sending mail to unregistered user niels@anonymised.com
Niels, still failing:
Does not look like a custom repo is being used.
On Tue, Jun 5, 2018 at 5:59 PM, <monitor@anonymised.com39… > wrote:
See <https://build.geoserver.org/job/geoserver-master/5882/display/redirect?page=changes >
Changes:
[…truncated 11.96 MB…]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar >
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-notification —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-notification —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest —
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target >
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest —
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes >
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar >
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-oseo —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar
[INFO]
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-core:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-core:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd ): Not authorized , ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools:gt-jdbc:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-jdbc:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd ): Not authorized , ReasonPhrase:Unauthorized.
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 —
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target >
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 —
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources >
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 —
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes >
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest —
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes >
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 —
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes >
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar >
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar >
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar >
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar > to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar
[INFO]
[WARNING] Failure to transfer org.geotools.jdbc:gt-jdbc-postgis:20-SNAPSHOT/maven-metadata.xml from https://www.milieuinfo.be/artifactory/acd was cached in the local repository, resolution will not be reattempted until the update interval of acd has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.jdbc:gt-jdbc-postgis:20-SNAPSHOT/maven-metadata.xml from/to acd (https://www.milieuinfo.be/artifactory/acd ): Not authorized , ReasonPhrase:Unauthorized.
[INFO]
[INFO] Community Space … SUCCESS [ 8.870 s]
[INFO] Authentication by unique url key … SUCCESS [ 7.727 s]
[INFO] WorldWind Format Module … SUCCESS [ 7.319 s]
[INFO] SpatiaLite Extension … SUCCESS [ 7.498 s]
[INFO] GeoServer JDBC KV Catalog … SUCCESS [ 9.314 s]
[INFO] Aggregating Data Store … SUCCESS [ 3.025 s]
[INFO] GeoServer Scripting Extensions … SUCCESS [ 2.480 s]
[INFO] Core Scripting Extension … SUCCESS [ 7.602 s]
[INFO] Web UI Scripting Extension … SUCCESS [ 3.592 s]
[INFO] BeanShell Scripting Extension … SUCCESS [ 2.543 s]
[INFO] Groovy Scripting Extension … SUCCESS [ 17.059 s]
[INFO] Python Scripting Extension … SUCCESS [ 9.961 s]
[INFO] JavaScript Scripting Extension … SUCCESS [ 7.614 s]
[INFO] Ruby Scripting Extension … SUCCESS [ 5.263 s]
[INFO] WMS-EO … SUCCESS [ 6.989 s]
[INFO] ColorMap … SUCCESS [ 6.436 s]
[INFO] GeoServer mbtiles Extension … SUCCESS [ 7.628 s]
[INFO] GeoServer GeoPackage Extension … SUCCESS [ 6.389 s]
[INFO] Dynamic WMS dimension value defaults … SUCCESS [ 7.052 s]
[INFO] GPX PPIO for WPS … SUCCESS [ 5.401 s]
[INFO] KML PPIO for WPS … SUCCESS [ 5.984 s]
[INFO] DownloadProcess … SUCCESS [ 8.741 s]
[INFO] GeoServer JMS based clustering modules … SUCCESS [ 0.188 s]
[INFO] ActiveMQ … SUCCESS [ 3.746 s]
[INFO] GeoServer JMS clustering Commons module … SUCCESS [ 2.175 s]
[INFO] GeoServer JMS clustering module … SUCCESS [ 11.141 s]
[INFO] GeoServer Hazelcast Clustering Module … SUCCESS [ 8.164 s]
[INFO] Solr Module … SUCCESS [ 5.990 s]
[INFO] GeoFence security integration … SUCCESS [ 10.175 s]
[INFO] GeoFence Server … SUCCESS [ 10.221 s]
[INFO] Parameters Extractor … SUCCESS [ 8.466 s]
[INFO] WPS cluster on jdbc datastores … SUCCESS [ 6.076 s]
[INFO] ncWMS compatibility extension … SUCCESS [ 6.745 s]
[INFO] GWC Distributed Caching Plugin … SUCCESS [ 3.013 s]
[INFO] GeoWebCache S3 … SUCCESS [ 5.022 s]
[INFO] GDAL translate parent … SUCCESS [ 0.009 s]
[INFO] GDAL translate WCS … SUCCESS [ 7.213 s]
[INFO] GDAL translate WPS … SUCCESS [ 6.308 s]
[INFO] GeoServer JDBC Configuration Resource Store … SUCCESS [ 7.381 s]
[INFO] GeoWebCache SQLite … SUCCESS [ 6.408 s]
[INFO] GeoGig GeoServer integration … SUCCESS [ 26.513 s]
[INFO] GeoServer Config Backup And Restore … SUCCESS [ 0.793 s]
[INFO] GeoServer Config Backup And Restore Core Module … SUCCESS [ 8.871 s]
[INFO] GeoServer Config Backup And Restore REST Module … SUCCESS [ 5.798 s]
[INFO] GeoServer Config Backup And Restore Extensions … SUCCESS [ 2.679 s]
[INFO] GeoServer Config Backup And Restore Web UI Module … SUCCESS [ 4.214 s]
[INFO] WMTS Multi Dimensional … SUCCESS [ 5.871 s]
[INFO] GeoServer Security Community Modules … SUCCESS [ 0.010 s]
[INFO] GeoServer OAuth2 Connect Security Module … SUCCESS [ 5.807 s]
[INFO] GeoServer OneLogin Module … SUCCESS [ 3.587 s]
[INFO] gs-notification-common … SUCCESS [ 1.030 s]
[INFO] OWS Dispatcher Simulate Plugin … SUCCESS [ 4.751 s]
[INFO] JDBC Metrics Plugin … SUCCESS [ 3.440 s]
[INFO] OpenSearch EO parent … SUCCESS [ 0.015 s]
[INFO] OpenSearch for EO … SUCCESS [ 6.033 s]
[INFO] OpenSearch for EO web UI … SUCCESS [ 5.560 s]
[INFO] OpenSearch for EO REST configuration API … SUCCESS [ 7.490 s]
[INFO] GeoServer Mapbox Styling … SUCCESS [ 6.364 s]
[INFO] GeoServer Status Monitoring Module … SUCCESS [ 5.484 s]
[INFO] NSG WMTS 1.0 Profile … SUCCESS [ 20.278 s]
[INFO] NSG WFS 2.0 Profile … SUCCESS [ 10.768 s]
[INFO] NetCDF GHRSST encoder … SUCCESS [ 8.096 s]
[INFO] WFS 3 prototype … SUCCESS [ 5.555 s]
[INFO] GeoServer Task Manager … SUCCESS [ 2.717 s]
[INFO] GeoServer Task Manager Core … SUCCESS [ 30.771 s]
[INFO] GeoServer Task Manager S3 … SUCCESS [ 6.553 s]
[INFO] GeoServer Community Release Module … FAILURE [ 0.837 s]
[INFO] GeoServer Resource Browser … SUCCESS [ 6.109 s]
[INFO] GeoServer notification event system … SUCCESS [ 6.123 s]
[INFO] S3 Geotiff Support … SUCCESS [ 2.594 s]
[INFO] Monitor Hibernate Extension … SUCCESS [ 7.975 s]
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.14-SNAPSHOT: Could not find artifact it.geosolutions:geoserver-manager:jar:1.8-dov-0.3 in boundless (https://repo.boundlessgeo.com/main/ ) → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-release
Build step ‘Invoke top-level Maven targets’ marked build as failure
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Okay, I am just going to comment the module and the extension out of the build for now, until the fork/repo issue has been resolved.
Regards
Niels
[INFO] Downloading:https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar
[INFO] Downloading:http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar
[INFO] Downloading:http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar
[INFO] Downloading:https://repo.maven.apache.org/maven2/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar
On Tue, Jun 5, 2018 at 5:59 PM, <monitor@anonymised.com <mailto:monitor@anonymised.com>> wrote:
See
<https://build.geoserver.org/job/geoserver-master/5882/display/redirect?page=changes>> ;
Changes:
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar>> ;
[INFO]
gs-notification ---
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar>> ;
[INFO]
gs-notification ---
[INFO] Installing
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml>> ;
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar>> ;
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar>> ;
to
[INFO] Installing
to
[INFO]
[INFO]
[INFO]
gs-oseo-rest ---
[INFO] Deleting
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target>> ;
[INFO]
gs-oseo-rest ---
[INFO]
[INFO]
gs-oseo-rest ---
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes>> ;
[INFO]
gs-web-oseo ---
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar>> ;
[INFO]
@ gs-web-oseo ---
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar>> ;
[INFO]
gs-web-oseo ---
[INFO] Installing
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml>> ;
to
[INFO] Installing
to
[INFO] Installing
to
[INFO] Installing
to
[INFO]
[INFO]
<https://www.milieuinfo.be/artifactory/acd> ; was cached in the
<https://www.milieuinfo.be/artifactory/acd>\ ): Not authorized ,
[INFO] Downloading:
<https://www.milieuinfo.be/artifactory/acd/org/geotools/gt-s3-geotiff/20-SNAPSHOT/maven-metadata.xml> ;
[INFO]
[INFO] Deleting
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target>> ;
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes>> ;
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes>> ;
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes>> ;
[INFO]
gs-oseo-rest ---
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar>> ;
[INFO]
@ gs-oseo-rest ---
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar>> ;
[INFO]
gs-oseo-rest ---
[INFO] Installing
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml>> ;
to
[INFO] Installing
to
[INFO] Installing
to
[INFO] Installing
to
[INFO]
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar>> ;
[INFO]
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar>> ;
[INFO]
[INFO] Installing
to
[INFO] Installing
<https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml>> ;
to
[INFO] Installing
to
[INFO] Installing
to
[INFO] Installing
to
[INFO]
[INFO]
[INFO] Downloading:
<https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloading:
<http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloading:
<http://maven.geo-solutions.it/org/geoserver/extension/gs-monitor-hibernate/2.14-SNAPSHOT/maven-metadata.xml> ;
[INFO] Downloaded:
[INFO] Downloading:
<https://repo.boundlessgeo.com/main/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar> ;
[INFO] Downloading:
<http://download.osgeo.org/webdav/geotools/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar> ;
[INFO] Downloading:
<http://maven.geo-solutions.it/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar> ;
[INFO] Downloading:
<https://repo.maven.apache.org/maven2/it/geosolutions/geoserver-manager/1.8-dov-0.3/geoserver-manager-1.8-dov-0.3.jar> ;
[INFO]
[INFO]
SUCCESS [ 8.870 s]
SUCCESS [ 7.727 s]
SUCCESS [ 7.319 s]
SUCCESS [ 7.498 s]
SUCCESS [ 9.314 s]
SUCCESS [ 3.025 s]
SUCCESS [ 2.480 s]
SUCCESS [ 7.602 s]
SUCCESS [ 3.592 s]
SUCCESS [ 2.543 s]
SUCCESS [ 17.059 s]
SUCCESS [ 9.961 s]
SUCCESS [ 7.614 s]
SUCCESS [ 5.263 s]
SUCCESS [ 6.989 s]
SUCCESS [ 6.436 s]
SUCCESS [ 7.628 s]
SUCCESS [ 6.389 s]
SUCCESS [ 3.176 s]
SUCCESS [ 7.052 s]
SUCCESS [ 5.401 s]
SUCCESS [ 5.984 s]
SUCCESS [ 8.741 s]
SUCCESS [ 0.188 s]
SUCCESS [ 3.746 s]
SUCCESS [ 2.175 s]
SUCCESS [ 11.141 s]
SUCCESS [ 8.164 s]
SUCCESS [ 5.990 s]
SUCCESS [ 10.175 s]
SUCCESS [ 10.221 s]
SUCCESS [ 8.466 s]
SUCCESS [ 9.333 s]
SUCCESS [ 6.076 s]
SUCCESS [ 6.745 s]
SUCCESS [ 3.013 s]
SUCCESS [ 5.022 s]
SUCCESS [ 0.009 s]
SUCCESS [ 7.213 s]
SUCCESS [ 6.308 s]
SUCCESS [ 7.381 s]
SUCCESS [ 6.408 s]
SUCCESS [ 26.513 s]
SUCCESS [ 0.793 s]
SUCCESS [ 8.871 s]
SUCCESS [ 5.798 s]
SUCCESS [ 2.679 s]
SUCCESS [ 4.214 s]
SUCCESS [ 5.871 s]
SUCCESS [ 0.010 s]
SUCCESS [ 5.807 s]
SUCCESS [ 3.587 s]
SUCCESS [ 1.030 s]
SUCCESS [ 2.704 s]
SUCCESS [ 4.751 s]
SUCCESS [ 3.440 s]
SUCCESS [ 0.015 s]
SUCCESS [ 6.033 s]
SUCCESS [ 5.560 s]
SUCCESS [ 7.490 s]
SUCCESS [ 6.364 s]
SUCCESS [ 5.484 s]
SUCCESS [ 20.278 s]
SUCCESS [ 10.768 s]
SUCCESS [ 8.096 s]
SUCCESS [ 5.555 s]
SUCCESS [ 2.717 s]
SUCCESS [ 30.771 s]
SUCCESS [ 6.553 s]
FAILURE [ 0.837 s]
SUCCESS [ 6.109 s]
SUCCESS [ 6.123 s]
SUCCESS [ 2.594 s]
SUCCESS [ 7.975 s]
[INFO]
[INFO]
[INFO]
[ERROR]
with the -e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
with the command
Hudson
June 5, 2018, 4:53pm
11
