[Geoserver-devel] Build failed in Jenkins: geoserver-master #595
See <http://ares.opengeo.org/jenkins/job/geoserver-master/595/&gt;
[...truncated 22782 lines...]
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[WARNING] *****************************************************************
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-csw-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-csw-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-csw-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Storing intermediate jjtree artifactes outside of generates-sources.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 20.06.2014 @ 13:05:44 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 23-Jun-2014 22:24
[INFO] [GitCommitIdMojo] build.build.time = 23.06.2014 @ 22:53:54 UTC
[INFO] [GitCommitIdMojo] build.branch = c303ca363d60849f502e9d6f43b628319f350c48
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c303ca3
[INFO] [GitCommitIdMojo] build.commit.id = c303ca363d60849f502e9d6f43b628319f350c48
[INFO] [GitCommitIdMojo] build.commit.message.full = Storing intermediate jjtree artifactes outside of generates-sources.
Fixes issues with IDEs that automatically load all maven generated sources.
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-csw-core ---
[INFO] Copying 1 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-csw-core ---
[INFO] Compiling 56 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/classes&gt;
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.263 sec
Running org.geoserver.security.web.user.UserListPageTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-csw-core ---
[INFO] Copying 0 resource
[INFO] Copying 23 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-csw-core ---
[INFO] Compiling 23 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-csw-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/surefire-reports&gt;
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.383 sec
Running org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest
Running org.geoserver.csw.CSWRecordResponseTest
Jun 23, 2014 10:54:09 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Jun 23, 2014 10:54:11 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.193 sec
Results :
Failed tests: testRemove(org.geoserver.security.web.role.RoleListPageTest)
Tests run: 92, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
Jun 23, 2014 10:54:15 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'CSWRecordDescriptor', but ApplicationContext is unset.
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.876s]
[INFO] Core Platform Module .............................. SUCCESS [14.640s]
[INFO] Open Web Service Module ........................... SUCCESS [15.832s]
[INFO] Main Module ....................................... SUCCESS [3:12.846s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.112s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:16.916s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [49.738s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.985s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.437s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.645s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.410s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:53.106s]
[INFO] Web Map Service Module ............................ SUCCESS [5:02.423s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:28.312s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:29.670s]
[INFO] REST Support Module ............................... SUCCESS [59.828s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:11.206s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.373s]
[INFO] Core UI Module .................................... SUCCESS [3:22.601s]
[INFO] WMS UI Module ..................................... SUCCESS [1:07.420s]
[INFO] WFS UI Module ..................................... SUCCESS [45.002s]
[INFO] Demoes Module ..................................... SUCCESS [1:03.966s]
[INFO] Security UI Modules ............................... SUCCESS [0.375s]
[INFO] Security UI Core Module ........................... FAILURE [3:50.507s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.221s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.512s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.240s]
[INFO] Printing Module ................................... SUCCESS [40.572s]
[INFO] Application Schema Support ........................ SUCCESS [0.211s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.528s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.927s]
[INFO] H2 DataStore Extension ............................ SUCCESS [18.988s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.231s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.683s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.362s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.613s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.478s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.972s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.839s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.966s]
[INFO] Excel Output Format ............................... SUCCESS [39.929s]
[INFO] Validation Module ................................. SUCCESS [6.989s]
[INFO] Chart external graphics support ................... SUCCESS [1.933s]
[INFO] Feature Generalization Extension .................. SUCCESS [7.623s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.958s]
[INFO] OWS request flow controller ....................... SUCCESS [33.033s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.267s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:33.873s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [47.655s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.902s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.448s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.901s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:03.837s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [51.861s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.279s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.861s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.652s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.166s]
[INFO] DXF output format ................................. SUCCESS [38.337s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.165s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [49.445s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [34.791s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.373s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 29:55.166s (Wall Clock)
[INFO] Finished at: Mon Jun 23 22:54:17 UTC 2014
[INFO] Final Memory: 67M/290M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-sec-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/596/changes&gt;
