See <https://build.geoserver.org/job/geoserver-master/5973/display/redirect?page=changes>
Changes:
[Andrea Aime] Landing page for wfs3 in HTML
[...truncated 12.02 MB...]
[debug] Using AOSP style
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes>
[INFO] Processed 20 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-oseo ---
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Task Manager S3 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 28 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-oseo-rest ---
[INFO] Processed 17 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-taskmanager-s3 ---
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.795 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 16.894 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 16.636 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.555 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.689 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.994 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.458 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.593 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 7.077 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.467 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.580 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 8.248 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 8.015 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.119 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.404 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.672 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 11.449 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.840 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.129 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.390 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.468 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.130 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.154 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.209 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.692 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.532 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 10.685 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.959 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.605 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 9.326 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.996 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.317 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 9.002 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.181 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 7.188 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.846 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.420 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.031 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.200 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.485 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.149 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.676 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 29.173 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.472 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 9.689 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.572 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.834 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 5.384 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 4.982 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.018 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 6.294 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.705 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 6.215 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.731 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.723 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.134 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 3.133 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.968 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 3.194 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.045 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 10.708 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.326 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 7.738 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.156 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 6.724 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.043 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 3.155 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 9.108 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 8.101 s]
[INFO] WFS 3 prototype .................................... FAILURE [ 7.504 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.046 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 13.676 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 5.760 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.414 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 6.774 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.564 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.600 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:19 min (Wall Clock)
[INFO] Finished at: 2018-06-27T18:20:04+00:00
[INFO] Final Memory: 159M/1499M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wfs3: Found 4 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs3
