[Geoserver-devel] Build failed in Jenkins: geoserver-master #5981
See <https://build.geoserver.org/job/geoserver-master/5981/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-8811] Upgrade Spring to 4.3.18.RELEASE
[...truncated 11.88 MB...]
[debug] Using AOSP style
[INFO] Processed 11 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-oauth2-geonode ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-oseo ---
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Task Manager S3 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 28 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-oseo-rest ---
[INFO] Processed 17 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-taskmanager-s3 ---
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.007 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 16.996 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 16.653 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.445 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 10.019 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.085 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.336 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.850 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 7.320 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.997 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.276 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 8.218 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.724 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.255 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.218 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.376 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 10.898 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.991 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.917 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.105 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.934 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.912 s]
[INFO] DownloadProcess .................................... SUCCESS [ 10.242 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.194 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.737 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 4.309 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 10.681 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.913 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.202 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 9.819 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.464 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.520 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 9.210 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.387 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 7.202 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.843 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.620 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.027 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.617 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.357 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.198 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.916 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 27.121 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.454 s]
[INFO] GeoServer Config Backup And Restore Core Module .... FAILURE [ 0.732 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.262 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.025 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 5.971 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.908 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 6.002 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.750 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.073 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.677 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 3.504 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 6.569 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 3.039 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.039 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 10.685 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 6.563 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 8.016 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.213 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 5.232 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.051 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 2.782 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 9.389 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 7.805 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 7.491 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.059 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 13.722 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 5.261 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 5.503 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 6.988 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 3.042 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.536 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:07 min (Wall Clock)
[INFO] Finished at: 2018-06-29T17:34:29+00:00
[INFO] Final Memory: 157M/1463M
[ERROR] Failed to execute goal on project gs-backup-restore-core: Could not resolve dependencies for project org.geoserver.community.backuprestore:gs-backup-restore-core:jar:2.14-SNAPSHOT: Could not find artifact org.springframework.integration:spring-integration-core:jar:4.3.18.RELEASE in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-backup-restore-core
See <https://build.geoserver.org/job/geoserver-master/5982/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Pinning spring-integration-core to 4.3.17 as the jar for 4.3.18 is not
[...truncated 11.24 MB...]
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Jun 29, 2018 5:52:27 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Jun 29, 2018 5:52:28 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.161 sec
Running org.geoserver.filters.GZIPResponseStreamTest
Results :
Failed tests: testDirectWrongFile(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<INIT[_ERROR]> but was:<INIT>
Tests run: 75, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.069 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.215 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [287 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-app ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/java’> does not exist, ignoring.
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.war
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.716 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.912 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.779 s]
[INFO] Main Module ........................................ SUCCESS [01:01 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.063 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:14 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.053 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.092 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.428 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.055 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.592 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 38.205 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:34 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:55 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 27.312 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.234 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:21 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:24 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 19.538 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.131 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 14.125 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.050 s]
[INFO] Core UI Module ..................................... SUCCESS [01:08 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.670 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 53.255 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.361 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.049 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.247 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.095 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:33 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:00 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.720 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.529 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.053 s]
[INFO] Printing Module .................................... SUCCESS [ 14.327 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.821 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.021 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:30 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.371 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.696 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.716 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.917 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.392 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.214 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.214 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.766 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.490 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.251 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.032 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.208 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.792 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.042 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:07 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.948 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.034 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.478 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.103 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.475 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.254 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.744 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 24.205 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.745 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.117 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.046 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.281 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.200 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.039 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.668 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.447 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 34.616 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 18.510 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.043 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.127 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.117 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 36.799 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.775 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.031 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.317 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.648 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.035 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.797 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.444 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.586 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.035 s]
[INFO] Importer Core Module ............................... SUCCESS [ 48.768 s]
[INFO] Importer REST Api Module-ng ........................ FAILURE [ 43.457 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.490 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.494 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.650 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.563 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 54.037 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.805 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 12.764 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.005 s]
[INFO] Total time: 17:59 min (Wall Clock)
[INFO] Finished at: 2018-06-29T17:52:32+00:00
[INFO] Final Memory: 154M/1379M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-rest: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-rest
Hmm… does not happen locally:
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 16, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 15.007 sec <<< FAILURE!
testDirectWrongFile(org.geoserver.importer.rest.ImporterIntegrationTest)  Time elapsed: 81 sec  <<< FAILURE!
org.junit.ComparisonFailure: expected:<INIT[_ERROR]> but was:<INIT[]>
	at org.junit.Assert.assertEquals(Assert.java:115)
	at org.junit.Assert.assertEquals(Assert.java:144)
	at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongFile(ImporterIntegrationTest.java:151)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.lang.reflect.Method.invoke(Method.java:498)
Wondering if it’s a spurious failure?
On Fri, Jun 29, 2018 at 7:52 PM, <monitor@anonymised.com> wrote:
See <https://build.geoserver.org/job/geoserver-master/5982/display/redirect?page=changes>
Changes:
[…truncated 11.24 MB…]
WARNING: Extension lookup ‘GeoServerSecurityProvider’, but ApplicationContext is unset.
WARNING: Extension lookup ‘ExtensionFilter’, but ApplicationContext is unset.
WARNING: Extension lookup ‘ExtensionProvider’, but ApplicationContext is unset.
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app —
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/surefire-reports>
T E S T S
Results :
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec-cas —
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-cas —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-sec-cas —
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-app —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app —
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app —
main:
[echo] Copying data dir from …/…/…/data/minimal
[copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO]
[INFO] — maven-war-plugin:2.3:war (default) @ gs-web-app —
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver]>
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp]>
[INFO] Building war: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] — build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app —
[INFO]
[INFO] — fmt-maven-plugin:2.4.0:check (default) @ gs-web-app —
[warn] Source directory ‘<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/java’> does not exist, ignoring.
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-app —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.war
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-cas —
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-cas —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec-cas —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO]
[INFO] — fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas —
[warn] Test source directory ‘<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-sec-cas —
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer … SUCCESS [ 5.716 s]
[INFO] Core Platform Module … SUCCESS [ 12.912 s]
[INFO] Open Web Service Module … SUCCESS [ 11.779 s]
[INFO] Main Module … SUCCESS [01:01 min]
[INFO] GeoServer Security Modules … SUCCESS [ 0.063 s]
[INFO] GeoServer Security Tests Module … SUCCESS [01:14 min]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 35.053 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [ 21.092 s]
[INFO] Web Coverage Service Module … SUCCESS [ 4.428 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 16.055 s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [ 18.592 s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [ 38.205 s]
[INFO] Web Feature Service Module … SUCCESS [01:34 min]
[INFO] Web Map Service Module … SUCCESS [01:55 min]
[INFO] KML support for GeoServer … SUCCESS [ 27.312 s]
[INFO] gs-rest … SUCCESS [ 16.234 s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [02:21 min]
[INFO] gs-restconfig … SUCCESS [01:24 min]
[INFO] gs-restconfig-wcs … SUCCESS [ 19.538 s]
[INFO] gs-restconfig-wfs … SUCCESS [ 18.131 s]
[INFO] gs-restconfig-wms … SUCCESS [ 14.125 s]
[INFO] GeoServer Web Modules … SUCCESS [ 0.050 s]
[INFO] Core UI Module … SUCCESS [01:08 min]
[INFO] WMS UI Module … SUCCESS [ 31.670 s]
[INFO] GWC UI Module … SUCCESS [ 53.255 s]
[INFO] WFS UI Module … SUCCESS [ 10.361 s]
[INFO] Demos Module … SUCCESS [ 17.049 s]
[INFO] WCS UI Module … SUCCESS [ 13.247 s]
[INFO] Security UI Modules … SUCCESS [ 0.095 s]
[INFO] Security UI Core Module … SUCCESS [01:33 min]
[INFO] Security UI JDBC Module … SUCCESS [01:00 min]
[INFO] Security UI LDAP Module … SUCCESS [ 17.720 s]
[INFO] REST UI Module … SUCCESS [ 10.529 s]
[INFO] GeoServer Extensions … SUCCESS [ 0.053 s]
[INFO] Printing Module … SUCCESS [ 14.327 s]
[INFO] GeoServer Web Application … SUCCESS [ 6.821 s]
[INFO] Community Space … SUCCESS [ 0.028 s]
[INFO] Application Schema Support … SUCCESS [ 0.021 s]
[INFO] Application Schema Integration Test … SUCCESS [02:30 min]
[INFO] Sample DataAccess Integration Test … SUCCESS [ 10.371 s]
[INFO] ArcSDE DataStore Extension … SUCCESS [ 10.696 s]
[INFO] H2 DataStore Extension … SUCCESS [ 10.716 s]
[INFO] SQL Server DataStore Extension … SUCCESS [ 0.917 s]
[INFO] Oracle DataStore Extension … SUCCESS [ 0.392 s]
[INFO] MySQL DataStore Extension … SUCCESS [ 0.214 s]
[INFO] DB2 DataStore Extension … SUCCESS [ 0.214 s]
[INFO] ImageMap Output Format … SUCCESS [ 7.766 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [ 4.490 s]
[INFO] JP2K Coverage Extension … SUCCESS [ 0.251 s]
[INFO] OGR parent … SUCCESS [ 0.032 s]
[INFO] OGR CORE … SUCCESS [ 2.208 s]
[INFO] OGR WFS … SUCCESS [ 8.792 s]
[INFO] Web Processing Service parent … SUCCESS [ 0.042 s]
[INFO] Web Processing Service Module … SUCCESS [01:07 min]
[INFO] OGR WPS … SUCCESS [ 9.948 s]
[INFO] Excel Output Format … SUCCESS [ 12.034 s]
[INFO] Chart external graphics support … SUCCESS [ 0.478 s]
[INFO] Feature Generalization Extension … SUCCESS [ 3.103 s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [ 0.475 s]
[INFO] OWS request flow controller … SUCCESS [ 17.254 s]
[INFO] Web process status sharing with Hazelcast … SUCCESS [ 18.744 s]
[INFO] Web Processing Service GUI … SUCCESS [ 24.205 s]
[INFO] GeoServer Layer Querying filter functions … SUCCESS [ 13.745 s]
[INFO] Teradata DataStore Extension … SUCCESS [ 2.117 s]
[INFO] GeoServer Monitor Extensions … SUCCESS [ 0.046 s]
[INFO] Core Monitor Extension … SUCCESS [ 24.281 s]
[INFO] GeoServer Security Extension Modules … SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Module … SUCCESS [ 7.200 s]
[INFO] GeoServer Security Extension Web Modules … SUCCESS [ 0.039 s]
[INFO] GeoServer CAS Security Web Module … SUCCESS [ 3.668 s]
[INFO] XLST based WFS output format … SUCCESS [ 17.447 s]
[INFO] GeoServer INSPIRE Extensions … SUCCESS [ 34.616 s]
[INFO] GeoServer CSS Styling … SUCCESS [ 18.510 s]
[INFO] Catalog Services for the Web parent … SUCCESS [ 0.043 s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [ 12.127 s]
[INFO] Catalog Services for the Web core module … SUCCESS [ 36.799 s]
[INFO] CSW UI Module … SUCCESS [ 8.775 s]
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [ 0.031 s]
[INFO] DXF WFS output format … SUCCESS [ 11.317 s]
[INFO] DXF WPS PPIO … SUCCESS [ 9.648 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [ 0.035 s]
[INFO] GeoServer libjpeg-turbo Module … SUCCESS [ 8.586 s]
[INFO] GeoServer Data Importer … SUCCESS [ 0.035 s]
[INFO] Importer Core Module … SUCCESS [ 48.768 s]
[INFO] Importer REST Api Module-ng … FAILURE [ 43.457 s]
[INFO] Importer Berkley DB Persistence Module … SUCCESS [ 14.490 s]
[INFO] Importer Web UI Module … SUCCESS [ 13.494 s]
[INFO] GRIB Coverage Format … SUCCESS [ 14.650 s]
[INFO] NetCDF Coverage format … SUCCESS [ 15.563 s]
[INFO] WCS NetCDF output Module … SUCCESS [ 54.037 s]
[INFO] Vector Tiles … SUCCESS [ 13.805 s]
[INFO] Ysld GeoServer Plugin … SUCCESS [ 12.764 s]
[INFO] MongoDB Data Store … SUCCESS [ 2.005 s]
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-importer-rest
Build step ‘Invoke top-level Maven targets’ marked build as failure
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Might be spurious, although likely related to https://github.com/geoserver/geoserver/pull/2936
Perhaps some maven weirdness (e.g. the rest tests using an out-of-date importer-core artifact)?
I also cannot reproduce locally
Torben
On Fri, Jun 29, 2018 at 11:11 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Changes:
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5983/display/redirect&gt;
I reran the master build on Jenkins and it worked the second time around. This issue appears to be either spurious or inconsistent.
Torben
On Fri, Jun 29, 2018 at 12:04 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
	at [org.geoserver.importer.rest.Im](http://org.geoserver.importer.rest.Im)porterIntegrationTest.testDirectWrongFile(ImporterIntegrationTest.java:151)
Geoserver-devel@anonymised.comrge.net
Changes:
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
