[Geoserver-devel] Build failed in Jenkins: geoserver-master #5985
See <https://build.geoserver.org/job/geoserver-master/5985/display/redirect&gt;
[...truncated 11.77 MB...]
[INFO] Compiling 9 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-oauth2-github ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-oauth2-github ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-oauth2-github ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-oauth2-github ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-oauth2-github ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-oauth2-github ---
[debug] Using AOSP style
[INFO] Processed 11 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-oauth2-github ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-github/target/gs-sec-oauth2-github-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-github/2.14-SNAPSHOT/gs-sec-oauth2-github-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping OpenSearch for EO web UI
[INFO]
[INFO] Skipping OpenSearch for EO REST configuration API
[INFO]
[INFO] Building GeoServer Task Manager S3 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-oauth2-geonode ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-oauth2-geonode ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-oauth2-geonode ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-oauth2-geonode ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-oauth2-geonode ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-oauth2-geonode ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-oauth2-geonode ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-oauth2-geonode ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-oauth2-geonode ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/oauth2-geonode/target/gs-sec-oauth2-geonode-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-sec-oauth2-geonode/2.14-SNAPSHOT/gs-sec-oauth2-geonode-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-taskmanager-s3 ---
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 5.596 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 16.955 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 16.735 s]
[INFO] SpatiaLite Extension ............................... FAILURE [ 6.929 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.489 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.721 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.289 s]
[INFO] Core Scripting Extension ........................... FAILURE [ 8.296 s]
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] Groovy Scripting Extension ......................... SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SUCCESS [ 7.400 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.422 s]
[INFO] GeoServer mbtiles Extension ........................ FAILURE [ 11.426 s]
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.016 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.143 s]
[INFO] GPX PPIO for WPS ................................... FAILURE [ 5.764 s]
[INFO] KML PPIO for WPS ................................... FAILURE [ 5.741 s]
[INFO] DownloadProcess .................................... FAILURE [ 9.795 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.229 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.788 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.580 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 11.453 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.467 s]
[INFO] Solr Module ........................................ FAILURE [ 6.264 s]
[INFO] GeoFence security integration ...................... FAILURE [ 5.304 s]
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Parameters Extractor ............................... SUCCESS [ 4.943 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 12.180 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.079 s]
[INFO] ncWMS compatibility extension ...................... FAILURE [ 6.834 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.149 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.772 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.027 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.496 s]
[INFO] GDAL translate WPS ................................. FAILURE [ 5.270 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.678 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.708 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 20.432 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.465 s]
[INFO] GeoServer Config Backup And Restore Core Module .... FAILURE [ 8.348 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. FAILURE [ 5.357 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.015 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 6.303 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.904 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.935 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 6.273 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.567 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.979 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.931 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... FAILURE [ 4.199 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 3.290 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.035 s]
[INFO] OpenSearch for EO .................................. FAILURE [ 9.864 s]
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 5.702 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 6.072 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.023 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 3.018 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 8.683 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 7.915 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 7.006 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.025 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 14.901 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 5.835 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.562 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.896 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.603 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.915 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:21 min (Wall Clock)
[INFO] Finished at: 2018-06-29T20:26:12+00:00
[INFO] Final Memory: 136M/1433M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-spatialite: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-mbtiles: Found 2 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-gpxppio: Found 2 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-kmlppio: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wps-download: Found 10 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-web-solr: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geofence: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRule.java&gt;:\[57,56\] error: incompatible types: org.locationtech.jts.geom.MultiPolygon cannot be converted to com.vividsolutions.jts.geom.MultiPolygon
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRule.java&gt;:\[224,32\] error: incompatible types: org.locationtech.jts.geom.MultiPolygon cannot be converted to com.vividsolutions.jts.geom.MultiPolygon
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRule.java&gt;:\[295,69\] error: incompatible types: com.vividsolutions.jts.geom.MultiPolygon cannot be converted to org.locationtech.jts.geom.MultiPolygon
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/geofence/src/main/java/org/geoserver/geofence/rest/xml/JaxbRule.java&gt;:\[300,70\] error: incompatible types: com.vividsolutions.jts.geom.MultiPolygon cannot be converted to org.locationtech.jts.geom.MultiPolygon
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wmts-multi-dimensional: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-ows-simulate: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geogig: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/GrowableCoordinateSequence.java&gt;:\[21,0\] error: GrowableCoordinateSequence is not abstract and does not override abstract method copy() in CoordinateSequence
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/GrowableCoordinateSequence.java&gt;:\[133,19\] error: SubSequence is not abstract and does not override abstract method copy() in CoordinateSequence
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBoundsConsumer.java&gt;:\[92,49\] error: incompatible types: com.vividsolutions.jts.geom.Envelope cannot be converted to org.locationtech.jts.geom.Envelope
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-script-core: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-ncwms: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-backup-restore-core: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-oseo-core: Found 7 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-gdal-wps: Found 1 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-spatialite
See <https://build.geoserver.org/job/geoserver-master/5986/display/redirect?page=changes&gt;
Changes:
[github] upgrade communityRelease extensions (#2950)
[...truncated 11.25 MB...]
  at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
  at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
  at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
  at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
  at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:160)
  at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:127)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
  at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:207)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Caused by: java.io.IOException: No such file or directory
  at java.io.UnixFileSystem.createFileExclusively(Native Method)
  at java.io.File.createNewFile(File.java:1012)
  at org.geoserver.importer.ImportContext.lockUploadFolder(ImportContext.java:324)
  at org.geoserver.importer.ImportContext.updateState(ImportContext.java:258)
  at org.geoserver.importer.ImportContext.updated(ImportContext.java:381)
  at org.geoserver.importer.Importer.changed(Importer.java:942)
  at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:230)
  ... 60 more
Jun 29, 2018 10:07:24 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 16, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 15.537 sec <<< FAILURE!
testDirectWrongFile(org.geoserver.importer.rest.ImporterIntegrationTest) Time elapsed: 148 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<INIT[_ERROR]> but was:<INIT>
  at org.junit.Assert.assertEquals(Assert.java:115)
  at org.junit.Assert.assertEquals(Assert.java:144)
  at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongFile(ImporterIntegrationTest.java:151)
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Jun 29, 2018 10:07:24 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Jun 29, 2018 10:07:24 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.867 sec
Results :
Failed tests: testDirectWrongFile(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<INIT[_ERROR]> but was:<INIT>
Tests run: 75, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.077 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.041 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.152 s]
[INFO] Main Module ........................................ SUCCESS [01:07 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.052 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:15 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.868 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 18.945 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.821 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.733 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.296 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 38.750 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:36 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:54 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.681 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.361 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:19 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:23 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 19.457 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.831 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.987 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.049 s]
[INFO] Core UI Module ..................................... SUCCESS [01:08 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.256 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 55.674 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.315 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.251 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 11.818 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:35 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:06 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.891 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.356 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.039 s]
[INFO] Printing Module .................................... SUCCESS [ 12.984 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.463 s]
[INFO] Community Space .................................... SUCCESS [ 0.041 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:27 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.364 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.688 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.028 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.914 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.368 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.217 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.209 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.659 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.655 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.278 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.039 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.105 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.782 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.048 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:11 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.977 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.066 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.464 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.235 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.567 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.660 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 28.200 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 20.443 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.767 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.157 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.049 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.103 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.671 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.035 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.424 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.421 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 37.535 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.632 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.086 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.281 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.061 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.678 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.162 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.047 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.841 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.686 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.035 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 16.117 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.796 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.436 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 51.656 s]
[INFO] Importer REST Api Module-ng ........................ FAILURE [ 43.355 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 15.026 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.487 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.622 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.068 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 52.845 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 14.374 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 14.151 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.911 s]
[INFO] Total time: 18:12 min (Wall Clock)
[INFO] Finished at: 2018-06-29T22:07:25+00:00
[INFO] Final Memory: 151M/1338M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-rest: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-rest
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/5987/display/redirect&gt;
