[Geoserver-devel] Build failed in Jenkins: geoserver-master #600
See <http://ares.opengeo.org/jenkins/job/geoserver-master/600/changes&gt;
Changes:
[Ben.Caradoc-Davies] Fix ResourcePoolTest failure in path with spaces [GEOS-6551]
[Ben.Caradoc-Davies] Fix GeoServerPersisterTest failure in path with spaces [GEOS-6551]
[Ben.Caradoc-Davies] Fix support for dynamic symbolizer CQL templates [GEOS-6551]
[...truncated 3591 lines...]
Running org.geoserver.security.GroupAdminServiceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.016 sec
Running org.geoserver.security.KeyStoreProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.56 sec
Running org.geoserver.security.MigrateFrom_2_2_Test
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.008 sec
Running org.geoserver.security.auth.AuthenticationCacheFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.793 sec
Running org.geoserver.security.auth.AuthenticationFilterTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.739 sec
Running org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.167 sec
Running org.geoserver.security.auth.LRUAuthenticationCacheTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.528 sec
Running org.geoserver.security.decorators.DecoratingWMSLayerInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.108 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.039 sec
Running org.geoserver.security.impl.AdvertisedCatalogTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.114 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.417 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.867 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.863 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.093 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.268 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.766 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.615 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.364 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.479 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.039 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.security.validation.PasswordValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.039 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.344 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.494 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.66 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.157 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.275 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.564 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.301 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.054 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.783 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.672 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.363 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.883 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.149 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.779 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.123 sec
Results :
Failed tests: testModifyStyleWithResourcesAbsoluteChangeWorkspace(org.geoserver.config.GeoServerPersisterTest): (..)
  testModifyStyleWithResourcesRemoteChangeWorkspace(org.geoserver.config.GeoServerPersisterTest): (..)
  testModifyStyleWithResourcesInParentDirChangeWorkspace(org.geoserver.config.GeoServerPersisterTest): (..)
Tests run: 578, Failures: 3, Errors: 0, Skipped: 1
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.789s]
[INFO] Core Platform Module .............................. SUCCESS [20.037s]
[INFO] Open Web Service Module ........................... SUCCESS [21.908s]
[INFO] Main Module ....................................... FAILURE [3:21.351s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.370s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.335s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.374s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.296s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.954s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.436s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.691s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.633s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.170s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.709s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.668s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.084s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.541s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.425s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.426s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 4:19.429s (Wall Clock)
[INFO] Finished at: Wed Jun 25 03:32:46 UTC 2014
[INFO] Final Memory: 39M/379M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
Can anyone reproduce this failure? It passes everywhere I have tried, with Oracle JDK 7 and OpenJDK 7. Looks like a leaky fixture, but I cannot see why, nor why my fix would break three tests.
-------- Forwarded Message --------
Subject: Build failed in Jenkins: geoserver-master #600
Date: Wed, 25 Jun 2014 03:32:47 +0000
Reply-To: Jenkins <monitor@anonymised.com>
To: geoserver-devel@lists.sourceforge.net, Ben.Caradoc-Davies@anonymised.com
Changes:
Results :
[INFO]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
See <http://ares.opengeo.org/jenkins/job/geoserver-master/601/&gt;
[...truncated 3586 lines...]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.033 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.892 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.655 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.8 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.855 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.165 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.524 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.053 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.242 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.724 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.942 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.068 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.036 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.742 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.618 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.192 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.471 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.282 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.11 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.304 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.482 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.019 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.321 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.35 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.05 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.349 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.75 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.988 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.798 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.016 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.993 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.166 sec
Results :
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.662s]
[INFO] Core Platform Module .............................. SUCCESS [15.725s]
[INFO] Open Web Service Module ........................... SUCCESS [18.344s]
[INFO] Main Module ....................................... FAILURE [3:01.508s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.438s]
[INFO] Community Space ................................... SUCCESS [0.216s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.343s]
[INFO] Application Schema Support ........................ SUCCESS [0.272s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.486s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.072s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.471s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.378s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.509s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.574s]
[INFO] Chart external graphics support ................... SUCCESS [2.016s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.032s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.304s]
[INFO] DXF output format ................................. SUCCESS [0.327s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.597s]
[INFO] Total time: 3:49.890s (Wall Clock)
[INFO] Finished at: Wed Jun 25 05:03:19 UTC 2014
[INFO] Final Memory: 40M/379M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Can anyone help reproduce this failure? Jody? Justin?
These changes fix failures in a path with spaces:
https://jira.codehaus.org/browse/GEOS-6551
With these changes on master the build passes on this Jenkins instance:
https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/2207/
It also passes locally for me in Maven and Eclipse.
The only failure I see is on geoserver-master on Boundless Jenkins. I kicked the build and it still failed.
I could not make it fail using any of the three FixMethodOrder annotations (we are using JUnit 4.11):
http://randomallsorts.blogspot.com.au/2012/12/junit-411-whats-new-test-execution-order.html
I am using -Dtest=GeoServerPersisterTest but I do not expect test case order to be a factor since we set runOrder to alphabetical.
Someone with command line access on the Boundless build slave could try remote debugging:
http://maven.apache.org/surefire/maven-surefire-plugin/examples/debugging.html
Any other ideas?
Kind regards,
Ben.
Changes:
[GEOS-6551]
spaces [GEOS-6551]
[GEOS-6551]
Running
Results :
Failed tests:
[INFO]
[INFO]
[3:21.351s]
   SKIPPED
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
-e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
Software Engineer
Not sure Ben. That server has been known to misbehave at times. I’ll try bouncing it to see if that helps.
On Wed, Jun 25, 2014 at 2:34 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Any other ideas?
Kind regards,
Ben.
To: geoserver-devel@anonymised.comsourceforge.net, Ben.Caradoc-Davies@anonymised.com
See <http://ares.opengeo.org/jenkins/job/geoserver-master/600/changes>
Changes:
[GEOS-6551]
spaces [GEOS-6551]
[GEOS-6551]
[…truncated 3591 lines…]
Running
Results :
Failed tests:
[INFO]
[INFO]
[INFO] GeoServer … SUCCESS [10.789s]
[INFO] Core Platform Module … SUCCESS [20.037s]
[INFO] Open Web Service Module … SUCCESS [21.908s]
[INFO] Main Module … FAILURE
[3:21.351s]
[INFO] GeoServer Security Modules … SKIPPED
[INFO] GeoServer JDBC Security Module … SKIPPED
[INFO] GeoServer LDAP Security Module … SKIPPED
[INFO] Web Coverage Service Module … SKIPPED
[INFO] Web Coverage Service 1.0 Module … SKIPPED
[INFO] Web Coverage Service 1.1 Module … SKIPPED
[INFO] Web Coverage Service 2.0 Module … SKIPPED
[INFO] Web Feature Service Module … SKIPPED
[INFO] Web Map Service Module … SKIPPED
[INFO] KML support for GeoServer … SKIPPED
[INFO] GeoWebCache (GWC) Module … SKIPPED
[INFO] REST Support Module … SKIPPED
[INFO] REST Configuration Service Module … SKIPPED
[INFO] GeoServer Web Modules … SUCCESS [0.370s]
[INFO] Core UI Module … SKIPPED
[INFO] WMS UI Module … SKIPPED
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SKIPPED
[INFO] Demoes Module … SKIPPED
[INFO] WCS UI Module … SKIPPED
[INFO] Security UI Modules … SKIPPED
[INFO] Security UI Core Module … SKIPPED
[INFO] Security UI JDBC Module … SKIPPED
[INFO] Security UI LDAP Module … SKIPPED
[INFO] REST UI Module … SKIPPED
[INFO] Community Space … SUCCESS [0.335s]
[INFO] HTTP Proxy Extension … SKIPPED
[INFO] GeoServer Web Application … SKIPPED
[INFO] GeoServer Extensions … SUCCESS [0.374s]
[INFO] Printing Module … SKIPPED
[INFO] Application Schema Support … SUCCESS [0.296s]
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SKIPPED
[INFO] ArcSDE DataStore Extension … SKIPPED
[INFO] GeoSearch Index Module … SKIPPED
[INFO] H2 DataStore Extension … SKIPPED
[INFO] SQL Server DataStore Extension … SUCCESS [1.954s]
[INFO] Oracle DataStore Extension … SUCCESS [1.436s]
[INFO] MySQL DataStore Extension … SUCCESS [0.691s]
[INFO] DB2 DataStore Extension … SUCCESS [0.633s]
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [1.170s]
[INFO] JP2K Coverage Extension … SUCCESS [0.709s]
[INFO] ogr2ogr Output Format … SKIPPED
[INFO] Excel Output Format … SKIPPED
[INFO] Validation Module … SKIPPED
[INFO] Chart external graphics support … SUCCESS [2.668s]
[INFO] Feature Generalization Extension … SKIPPED
[INFO] Image Mosaic JDBC Extension … SUCCESS [1.084s]
[INFO] OWS request flow controller … SKIPPED
[INFO] Web Processing Service parent … SUCCESS [0.541s]
[INFO] Web Processing Service Module … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SKIPPED
[INFO] Teradata DataStore Extension … SKIPPED
[INFO] GeoServer Monitor Extensions … SKIPPED
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer Security Extension Web Modules … SKIPPED
[INFO] GeoServer CAS Security Web Module … SKIPPED
[INFO] XLST based WFS output format … SKIPPED
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SKIPPED
[INFO] Catalog Services for the Web interfaces … SKIPPED
SKIPPED
[INFO] Catalog Services for the Web core module … SKIPPED
[INFO] CSW UI Module … SKIPPED
[INFO] DXF output format … SUCCESS [0.425s]
[INFO] DXF output format … SKIPPED
[INFO] DXF WPS PPIO … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [0.426s]
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] Importer REST Api Module … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[INFO]
[INFO]
[INFO]
[ERROR]
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports>
[ERROR] → [Help 1]
[ERROR]
-e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
[ERROR] mvn -rf :gs-main
Build step ‘Invoke top-level Maven targets’ marked build as failure
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
I’m getting the failures on my machine. The issue in all three cases is that it is copying images that shouldn’t be copied since they aren’t under the directory that contains the style being moved. I think the old code was copying these files and I eliminated the unnecessary copying while making my changes, so breaking that shouldn’t be any worse than the behaviour before I made the ResourceStore transition. Given that, adding @Ignore to those test cases should be OK if nothing else works. It’d be nice to not have extra files cluttering up the style directories but there are other things causing that already.
Open source business process management suite built on Java and Eclipse
Turn processes into business applications with Bonita BPM Community Edition
Quickly connect people, data, and systems into organized workflows
Winner of BOSSIE, CODIE, OW2 and Gartner awards
http://p.sf.net/sfu/Bonitasoft
Geoserver-devel mailing list
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
Any other ideas?
Kind regards,
Ben.
Changes:
[GEOS-6551]
spaces [GEOS-6551]
[GEOS-6551]
Running
Results :
Failed tests:
[INFO]
[INFO]
[3:21.351s]
SKIPPED
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
-e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
Software Engineer
Justin Deoliveira
@j_deolive
Kevin,
what is your platform? What do you get for "mvn -version"?
Kevin, I think your tests are useful and cover good new behaviour, so I am reluctant to @Ignore them. What perplexes me is that they pass on my intended-to-break-things path-with-spaces environment yet fail on your platform and on Boundless Jenkins! I would like to get to the bottom of this.
Kind regards,
Ben.
On 26/06/14 07:00, Kevin Smith wrote:
I'm getting the failures on my machine. The issue in all three cases is
that it is copying images that shouldn't be copied since they aren't
copying while making my changes, so breaking that shouldn't be any worse
works. It'd be nice to not have extra files cluttering up the style
<mailto:jdeolive@anonymised.com>> wrote:
    Not sure Ben. That server has been known to misbehave at times. I'll
    <Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>>
        https://jira.codehaus.org/__browse/GEOS-6551
        <https://jira.codehaus.org/browse/GEOS-6551&gt;
        instance:
        https://cgsrv8.arrc.csiro.au/__jenkins/view/geoserver-master/__job/geoserver-master/2207/
        <https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/2207/&gt;
        http://randomallsorts.__blogspot.com.au/2012/12/junit-__411-whats-new-test-execution-__order.html
        <http://randomallsorts.blogspot.com.au/2012/12/junit-411-whats-new-test-execution-order.html&gt;
        alphabetical.
        http://maven.apache.org/__surefire/maven-surefire-__plugin/examples/debugging.html
        <http://maven.apache.org/surefire/maven-surefire-plugin/examples/debugging.html&gt;
        Any other ideas?
        Kind regards,
        Ben.
            have tried,
            but I
            From: monitor@anonymised.com <mailto:monitor@anonymised.com>
            <mailto:monitor@anonymised.com>>
            <mailto:geoserver-devel@lists.sourceforge.net>,
            See
            <http://ares.opengeo.org/__jenkins/job/geoserver-master/__600/changes
            <http://ares.opengeo.org/jenkins/job/geoserver-master/600/changes&gt;&gt;
            Changes:
            with spaces
            [GEOS-6551]
            path with
            spaces [GEOS-6551]
            templates
            [GEOS-6551]
            ------------------------------__------------
            Running org.geoserver.security.__GroupAdminServiceTest
            elapsed: 2.016 sec
            Running org.geoserver.security.__KeyStoreProviderTest
            elapsed: 1.56 sec
            Running org.geoserver.security.__MigrateFrom_2_2_Test
            elapsed: 2.008 sec
            Running
            org.geoserver.security.auth.__AuthenticationCacheFilterTest
            elapsed: 4.793 sec
            Running org.geoserver.security.auth.__AuthenticationFilterTest
            elapsed: 7.739 sec
            Running
            org.geoserver.security.auth.__GeoServerRootAuthenticationPro__viderTest
            elapsed: 1.167 sec
            Running org.geoserver.security.auth.__LRUAuthenticationCacheTest
            elapsed: 1.528 sec
            Running
            org.geoserver.security.__decorators.__DecoratingWMSLayerInfoTest
            elapsed: 0 sec
            Running
            org.geoserver.security.__decorators.__ReadOnlyDataAccessTest
            elapsed: 0.018 sec
            Running
            org.geoserver.security.__decorators.__ReadOnlyDataStoreTest
            elapsed: 0.014 sec
            Running
            org.geoserver.security.__decorators.__ReadSecuredCatalogDecoratorsTe__st
            elapsed: 0.022 sec
            Running
            org.geoserver.security.__decorators.__SecuredFeatureCollectionTest
            elapsed: 0.034 sec
            Running
            org.geoserver.security.__decorators.__SecuredFeatureSourceTest
            elapsed: 0.032 sec
            Running
            org.geoserver.security.__decorators.__SecuredGetMapRequestTest
            elapsed: 0.034 sec
            Running org.geoserver.security.file.__FileTest
            elapsed: 0.108 sec
            Running
            org.geoserver.security.filter.__GeoServerBasicAuthenticationFi__lterTest
            elapsed: 0.039 sec
            Running org.geoserver.security.impl.__AdvertisedCatalogTest
            elapsed: 0.013 sec
            Running org.geoserver.security.impl.__DataAccessRuleDAOTest
            elapsed: 0.009 sec
            Running org.geoserver.security.impl.__DataAccessRuleTest
            elapsed: 0.003 sec
            Running
            org.geoserver.security.impl.__DefaultDataAccessManagerAuthTe__st
            elapsed: 0.024 sec
            Running
            org.geoserver.security.impl.__DefaultDataAccessManagerTreeTe__st
            elapsed: 0.002 sec
            Running
            org.geoserver.security.impl.__GeoServerJ2eeRoleServiceTest
            elapsed: 1.114 sec
            Running
            org.geoserver.security.impl.__GeoServerRoleConverterImplTest
            elapsed: 0.002 sec
            Running org.geoserver.security.impl.__GeoServerUserDaoTest
            elapsed: 0.011 sec
            Running org.geoserver.security.impl.__MemoryRoleServiceTest
            elapsed: 1.417 sec
            Running
            org.geoserver.security.impl.__MemoryUserDetailsServiceTest
            elapsed: 5.867 sec
            Running org.geoserver.security.impl.__MemoryUserGroupServiceTest
            elapsed: 1.863 sec
            Running org.geoserver.security.impl.__RoleHierarchyHelperTest
            elapsed: 0.003 sec
            Running
            org.geoserver.security.impl.__SecureCatalogImplFilterTest
            elapsed: 0.024 sec
            Running org.geoserver.security.impl.__SecureCatalogImplTest
            elapsed: 0.093 sec
            Running
            org.geoserver.security.impl.__SecureCatalogIntegrationTest
            elapsed: 1.268 sec
            Running org.geoserver.security.impl.__SecureTreeNodeTest
            elapsed: 0.002 sec
            Running
            org.geoserver.security.__password.__GeoserverPasswordEncoderTest
            elapsed: 2.766 sec
            Running
            org.geoserver.security.__password.__MasterPasswordChangeTest
            elapsed: 1.615 sec
            Running
            org.geoserver.security.__password.__URLMasterPasswordProviderTest
            elapsed: 1.364 sec
            Running org.geoserver.security.__rememberme.RememberMeTest
            elapsed: 1.479 sec
            Running
            org.geoserver.security.__validation.__FilterConfigValidatorTest
            elapsed: 0.039 sec
            Running
            org.geoserver.security.__validation.__MasterPasswordChangeValidatorT__est
            elapsed: 0.019 sec
            Running
            org.geoserver.security.__validation.__PasswordValidatorTest
            elapsed: 0.008 sec
            Running
            org.geoserver.security.__validation.__RoleStoreValidationWrapperTest
            elapsed: 0.039 sec
            Running
            org.geoserver.security.__validation.__SecurityConfigValidatorTest
            elapsed: 1.344 sec
            Running
            org.geoserver.security.__validation.__UserGroupStoreValidationWrappe__rTest
            elapsed: 1.494 sec
            Running org.geoserver.security.xml.__XMLRoleServiceTest
            elapsed: 2.66 sec
            Running
            org.geoserver.security.xml.__XMLSecurityConfigValidatorTest
            elapsed: 1.157 sec
            Running org.geoserver.security.xml.__XMLUserDetailsServiceTest
            elapsed: 4.275 sec
            Running org.geoserver.security.xml.__XMLUserGroupServiceTest
            elapsed: 15.564 sec
            Running org.geoserver.template.__DirectFeatureWrapperTest
            elapsed: 0.301 sec
            Running org.geoserver.template.__FeatureWrapperTest
            elapsed: 0.022 sec
            Running org.geoserver.template.__GeoServerTemplateLoader2Test
            elapsed: 0.054 sec
            Running
            org.geoserver.threadlocals.__AdminRequestThreadLocalTransfe__rTest
            elapsed: 0.002 sec
            Running
            org.geoserver.threadlocals.__AuthenticationThreadLocalTrans__ferTest
            elapsed: 0 sec
            Running
            org.geoserver.threadlocals.__LocalLayerThreadLocalTransferT__est
            elapsed: 0.001 sec
            Running
            org.geoserver.threadlocals.__LocalWorkspaceThreadLocalTrans__ferTest
            elapsed: 0.001 sec
            Running
            org.geoserver.threadlocals.__PublicThreadLocalTransferTest
            elapsed: 0 sec
            Running org.geoserver.threadlocals.__ThreadLocalsTransferTest
            elapsed: 1.783 sec
            Running org.geoserver.util.__PartialBufferOutputStream2Test
            elapsed: 0 sec
            elapsed: 0.024 sec
            Running org.geoserver.vfny.global.__TolerantStartupTest
            elapsed: 1.672 sec
            Running org.vfny.geoserver.__ProjectionPolicyTest
            elapsed: 2.363 sec
            Running org.vfny.geoserver.crs.__OverrideCRSTest
            elapsed: 0.883 sec
            Running org.vfny.geoserver.crs.__OvverideTransformationsTest
            elapsed: 1.149 sec
            Running org.vfny.geoserver.global.__GeoserverDataDirectoryTest
            elapsed: 0.779 sec
            Running org.vfny.geoserver.global.xml.__WriterHelperTest
            elapsed: 0.001 sec
            Running org.vfny.geoserver.util.__ResponseUtilsTest
            elapsed: 0 sec
            Running org.vfny.geoserver.util.__SLDValidatorTest
            elapsed: 0.123 sec
            Results :
            Failed tests:
            testModifyStyleWithResourcesAb__soluteChangeWorkspace(org.__geoserver.config.__GeoServerPersisterTest):
            testModifyStyleWithResourcesRe__moteChangeWorkspace(org.__geoserver.config.__GeoServerPersisterTest):
            testModifyStyleWithResourcesIn__ParentDirChangeWorkspace(org.__geoserver.config.__GeoServerPersisterTest):
            [INFO]
            ------------------------------__------------------------------__------------
            [INFO]
            [INFO] GeoServer ..............................__...........
            SUCCESS [10.789s]
            SUCCESS [20.037s]
            SUCCESS [21.908s]
            [INFO] Main Module ..............................__.........
            FAILURE
            [3:21.351s]
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            [INFO] REST Support Module ..............................__.
            SKIPPED
            SKIPPED
            SUCCESS [0.370s]
            [INFO] Core UI Module ..............................__......
            SKIPPED
            [INFO] WMS UI Module ..............................__.......
            SKIPPED
            [INFO] GWC UI Module ..............................__.......
            SKIPPED
            [INFO] WFS UI Module ..............................__.......
            SKIPPED
            [INFO] Demoes Module ..............................__.......
            SKIPPED
            [INFO] WCS UI Module ..............................__.......
            SKIPPED
            [INFO] Security UI Modules ..............................__.
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            [INFO] REST UI Module ..............................__......
            SKIPPED
            [INFO] Community Space ..............................__.....
            SUCCESS [0.335s]
            SKIPPED
            SKIPPED
            SUCCESS [0.374s]
            [INFO] Printing Module ..............................__.....
            SKIPPED
            SUCCESS [0.296s]
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SUCCESS [1.954s]
            SUCCESS [1.436s]
            SUCCESS [0.691s]
            SUCCESS [0.633s]
            SKIPPED
            SUCCESS [1.170s]
            SUCCESS [0.709s]
            SKIPPED
            [INFO] Excel Output Format ..............................__.
            SKIPPED
            [INFO] Validation Module ..............................__...
            SKIPPED
            SUCCESS [2.668s]
            SKIPPED
            SUCCESS [1.084s]
            SKIPPED
            SUCCESS [0.541s]
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            implementation
                SKIPPED
            SKIPPED
            [INFO] CSW UI Module ..............................__.......
            SKIPPED
            [INFO] DXF output format ..............................__...
            SUCCESS [0.425s]
            SKIPPED
            [INFO] DXF WPS PPIO ..............................__........
            SKIPPED
            SUCCESS [0.426s]
              SKIPPED
            extension SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            SKIPPED
            [INFO]
            [INFO]
            [INFO]
            org.apache.maven.plugins:__maven-surefire-plugin:2.12.3:__test
            [ERROR]
            <http://ares.opengeo.org/__jenkins/job/geoserver-master/__ws/src/main/target/surefire-__reports
            <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt;&gt;
            [ERROR] -> [Help 1]
            [ERROR]
            Maven with the
            -e switch.
            debug logging.
            [ERROR]
            solutions,
            [ERROR] [Help 1]
            http://cwiki.apache.org/__confluence/display/MAVEN/__MojoFailureException
            <http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException&gt;
            [ERROR]
            build with the
            command
            failure
        Software Engineer
    *Justin Deoliveira*
    jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
    @j_deolive <https://twitter.com/j_deolive&gt;
    Edition
    <mailto:Geoserver-devel@lists.sourceforge.net>
Kevin Smith
ksmith@anonymised.com <mailto:ksmith@anonymised.com>
+1-778-785-7459
@boundlessgeo <https://twitter.com/boundlessgeo&gt;
Software Engineer
I’m running Ubuntu 12.04 64.
smithkm@anonymised.com:~/og-proj/geoserver/src$ mvn -v
Apache Maven 3.0.4
Maven home: /usr/share/maven
Java version: 1.7.0_60, vendor: Oracle Corporation
Java home: /usr/lib/jvm/java-7-oracle/jre
Default locale: en_CA, platform encoding: UTF-8
OS name: “linux”, version: “3.8.0-32-generic”, arch: “amd64”, family: “unix”
On 25 June 2014 20:03, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com…254…> wrote:
Kevin,
what is your platform? What do you get for “mvn -version”?
Kind regards,
Ben.
<Ben.Caradoc-Davies@anonymised.com mailto:[Ben.Caradoc-Davies@csiro.au](mailto:Ben.Caradoc-Davies@anonymised.com)>
<https://jira.codehaus.org/browse/GEOS-6551>
instance:
<https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/2207/>
<http://randomallsorts.blogspot.com.au/2012/12/junit-411-whats-new-test-execution-order.html>
alphabetical.
<http://maven.apache.org/surefire/maven-surefire-plugin/examples/debugging.html>
Any other ideas?
Kind regards,
Ben.
have tried,
but I
From: monitor@anonymised.com mailto:[monitor@anonymised.comcom](mailto:monitor@anonymised.com)
mailto:[monitor@anonymised.comcom](mailto:monitor@anonymised.com)>
mailto:[geoserver-devel@anonymised.com...sourceforge.net](mailto:geoserver-devel@lists.sourceforge.net),
See
<http://ares.opengeo.org/jenkins/job/geoserver-master/600/changes>>
Changes:
with spaces
[GEOS-6551]
path with
spaces [GEOS-6551]
templates
[GEOS-6551]
elapsed: 2.016 sec
elapsed: 1.56 sec
elapsed: 2.008 sec
Running
elapsed: 4.793 sec
elapsed: 7.739 sec
Running
elapsed: 1.167 sec
elapsed: 1.528 sec
Running
elapsed: 0 sec
Running
elapsed: 0.018 sec
Running
elapsed: 0.014 sec
Running
elapsed: 0.022 sec
Running
elapsed: 0.034 sec
Running
elapsed: 0.032 sec
Running
elapsed: 0.034 sec
elapsed: 0.108 sec
Running
elapsed: 0.039 sec
elapsed: 0.013 sec
elapsed: 0.009 sec
elapsed: 0.003 sec
Running
elapsed: 0.024 sec
Running
elapsed: 0.002 sec
Running
elapsed: 1.114 sec
Running
elapsed: 0.002 sec
elapsed: 0.011 sec
elapsed: 1.417 sec
Running
elapsed: 5.867 sec
elapsed: 1.863 sec
elapsed: 0.003 sec
Running
elapsed: 0.024 sec
elapsed: 0.093 sec
Running
elapsed: 1.268 sec
elapsed: 0.002 sec
Running
elapsed: 2.766 sec
Running
elapsed: 1.615 sec
Running
elapsed: 1.364 sec
elapsed: 1.479 sec
Running
elapsed: 0.039 sec
Running
elapsed: 0.019 sec
Running
elapsed: 0.008 sec
Running
elapsed: 0.039 sec
Running
elapsed: 1.344 sec
Running
elapsed: 1.494 sec
elapsed: 2.66 sec
Running
elapsed: 1.157 sec
elapsed: 4.275 sec
elapsed: 15.564 sec
elapsed: 0.301 sec
elapsed: 0.022 sec
elapsed: 0.054 sec
Running
elapsed: 0.002 sec
Running
elapsed: 0 sec
Running
elapsed: 0.001 sec
Running
elapsed: 0.001 sec
Running
elapsed: 0 sec
elapsed: 1.783 sec
elapsed: 0 sec
elapsed: 0.024 sec
elapsed: 1.672 sec
elapsed: 2.363 sec
elapsed: 0.883 sec
elapsed: 1.149 sec
elapsed: 0.779 sec
elapsed: 0.001 sec
elapsed: 0 sec
elapsed: 0.123 sec
Results :
Failed tests:
[INFO]
[INFO]
[INFO] GeoServer …__…
SUCCESS [10.789s]
SUCCESS [20.037s]
SUCCESS [21.908s]
[INFO] Main Module …__…
FAILURE
[3:21.351s]
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
[INFO] REST Support Module …__.
SKIPPED
SKIPPED
SUCCESS [0.370s]
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
[INFO] Security UI Modules …__.
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SUCCESS [0.335s]
SKIPPED
SKIPPED
SUCCESS [0.374s]
[INFO] Printing Module …__…
SKIPPED
SUCCESS [0.296s]
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SUCCESS [1.954s]
SUCCESS [1.436s]
SUCCESS [0.691s]
SUCCESS [0.633s]
SKIPPED
SUCCESS [1.170s]
SUCCESS [0.709s]
SKIPPED
[INFO] Excel Output Format ….
SKIPPED
SKIPPED
SUCCESS [2.668s]
SKIPPED
SUCCESS [1.084s]
SKIPPED
SUCCESS [0.541s]
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
implementation
SKIPPED
SKIPPED
SKIPPED
SUCCESS [0.425s]
SKIPPED
SKIPPED
SUCCESS [0.426s]
SKIPPED
extension SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
SKIPPED
[INFO]
[INFO]
[INFO]
[ERROR]
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports>>
[ERROR] → [Help 1]
[ERROR]
Maven with the
-e switch.
debug logging.
[ERROR]
solutions,
[ERROR] [Help 1]
<http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException>
[ERROR]
build with the
command
failure
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com4…>
Software Engineer
Justin Deoliveira
jdeolive@anonymised.com mailto:[jdeolive@anonymised.comcom](mailto:jdeolive@anonymised.com)
@j_deolive <https://twitter.com/j_deolive>
Edition
Geoserver-devel@anonymised.comsourceforge.net
mailto:[Geoserver-devel@anonymised.comsourceforge.net](mailto:Geoserver-devel@anonymised.come.net)
Kevin Smith
ksmith@anonymised.com… mailto:[ksmith@anonymised.comcom](mailto:ksmith@anonymised.com)
+1-778-785-7459
@boundlessgeo <https://twitter.com/boundlessgeo>
Software Engineer
Kevin Smith
+1-778-785-7459
@boundlessgeo
I have now reproduced this failure. All I have to do is copy my workspace to a path without spaces and the failure is reproduced. I am officially astonished.
Now that I can reproduce, a fix should not be far away.
On 27/06/14 00:00, Kevin Smith wrote:
I'm running Ubuntu 12.04 64.
Apache Maven 3.0.4
OS name: "linux", version: "3.8.0-32-generic", arch: "amd64", family: "unix"
<mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
    Kevin,
    Kind regards,
    Ben.
        cases is
        think the
        any worse
          Given
        else
        <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
        times. I'll
        <mailto:Ben.Caradoc-Davies@anonymised.com>>>
        https://jira.codehaus.org/____browse/GEOS-6551
        <https://jira.codehaus.org/__browse/GEOS-6551&gt;
        <https://jira.codehaus.org/browse/GEOS-6551&gt;&gt;
        Jenkins
                 instance:
        https://cgsrv8.arrc.csiro.au/____jenkins/view/geoserver-__master/__job/geoserver-master/__2207/
        <https://cgsrv8.arrc.csiro.au/__jenkins/view/geoserver-master/__job/geoserver-master/2207/&gt;
        <https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/2207/&gt;&gt;
        FixMethodOrder
        http://randomallsorts.__blogsp__ot.com.au/2012/12/junit-__411-__whats-new-test-execution-____order.html
        <http://blogspot.com.au/2012/12/junit-__411-whats-new-test-execution-__order.html&gt;
        <http://randomallsorts.__blogspot.com.au/2012/12/junit-__411-whats-new-test-execution-__order.html
        <http://randomallsorts.blogspot.com.au/2012/12/junit-411-whats-new-test-execution-order.html&gt;&gt;
        expect
                 alphabetical.
        slave
        http://maven.apache.org/____surefire/maven-surefire-____plugin/examples/debugging.html
        <http://maven.apache.org/__surefire/maven-surefire-__plugin/examples/debugging.html&gt;
        <http://maven.apache.org/surefire/maven-surefire-plugin/examples/debugging.html&gt;\_\_&gt;
                 Any other ideas?
                 Kind regards,
                 Ben.
        everywhere I
                     have tried,
        fixture,
                     but I
        <mailto:monitor@anonymised.com>>>
        <http://sourceforge.net>
                     <mailto:geoserver-devel@anonymised.com
        <mailto:geoserver-devel@lists.sourceforge.net>>,
                     See
        <http://ares.opengeo.org/____jenkins/job/geoserver-master/____600/changes
        <http://ares.opengeo.org/__jenkins/job/geoserver-master/__600/changes&gt;
        <http://ares.opengeo.org/jenkins/job/geoserver-master/600/changes&gt;&gt;&gt;
                     Changes:
        in path
                     with spaces
                     [GEOS-6551]
        failure in
                     path with
                     spaces [GEOS-6551]
        symbolizer CQL
                     templates
                     [GEOS-6551]
                     ------------------------------____------------
                     Running
        org.geoserver.security.____GroupAdminServiceTest
                     elapsed: 2.016 sec
                     Running org.geoserver.security.____KeyStoreProviderTest
                     elapsed: 1.56 sec
                     Running org.geoserver.security.____MigrateFrom_2_2_Test
                     elapsed: 2.008 sec
                     Running
        org.geoserver.security.auth.____AuthenticationCacheFilterTest
                     elapsed: 4.793 sec
                     Running
        org.geoserver.security.auth.____AuthenticationFilterTest
                     elapsed: 7.739 sec
                     Running
        org.geoserver.security.auth.____GeoServerRootAuthenticationPro____viderTest
                     elapsed: 1.167 sec
                     Running
        org.geoserver.security.auth.____LRUAuthenticationCacheTest
                     elapsed: 1.528 sec
                     Running
        org.geoserver.security.____decorators.____DecoratingWMSLayerInfoTest
                     elapsed: 0 sec
                     Running
        org.geoserver.security.____decorators.____ReadOnlyDataAccessTest
                     elapsed: 0.018 sec
                     Running
        org.geoserver.security.____decorators.____ReadOnlyDataStoreTest
                     elapsed: 0.014 sec
                     Running
        org.geoserver.security.____decorators.____ReadSecuredCatalogDecoratorsTe____st
                     elapsed: 0.022 sec
                     Running
        org.geoserver.security.____decorators.____SecuredFeatureCollectionTest
                     elapsed: 0.034 sec
                     Running
        org.geoserver.security.____decorators.____SecuredFeatureSourceTest
                     elapsed: 0.032 sec
                     Running
        org.geoserver.security.____decorators.____SecuredGetMapRequestTest
                     elapsed: 0.034 sec
                     Running org.geoserver.security.file.____FileTest
                     elapsed: 0.108 sec
                     Running
        org.geoserver.security.filter.______GeoServerBasicAuthenticationFi____lterTest
                     elapsed: 0.039 sec
                     Running
        org.geoserver.security.impl.____AdvertisedCatalogTest
                     elapsed: 0.013 sec
                     Running
        org.geoserver.security.impl.____DataAccessRuleDAOTest
                     elapsed: 0.009 sec
                     Running
        org.geoserver.security.impl.____DataAccessRuleTest
                     elapsed: 0.003 sec
                     Running
        org.geoserver.security.impl.____DefaultDataAccessManagerAuthTe____st
                     elapsed: 0.024 sec
                     Running
        org.geoserver.security.impl.____DefaultDataAccessManagerTreeTe____st
                     elapsed: 0.002 sec
                     Running
        org.geoserver.security.impl.____GeoServerJ2eeRoleServiceTest
                     elapsed: 1.114 sec
                     Running
        org.geoserver.security.impl.____GeoServerRoleConverterImplTest
                     elapsed: 0.002 sec
                     Running
        org.geoserver.security.impl.____GeoServerUserDaoTest
                     elapsed: 0.011 sec
                     Running
        org.geoserver.security.impl.____MemoryRoleServiceTest
                     elapsed: 1.417 sec
                     Running
        org.geoserver.security.impl.____MemoryUserDetailsServiceTest
                     elapsed: 5.867 sec
                     Running
        org.geoserver.security.impl.____MemoryUserGroupServiceTest
                     elapsed: 1.863 sec
                     Running
        org.geoserver.security.impl.____RoleHierarchyHelperTest
                     elapsed: 0.003 sec
                     Running
        org.geoserver.security.impl.____SecureCatalogImplFilterTest
                     elapsed: 0.024 sec
                     Running
        org.geoserver.security.impl.____SecureCatalogImplTest
                     elapsed: 0.093 sec
                     Running
        org.geoserver.security.impl.____SecureCatalogIntegrationTest
                     elapsed: 1.268 sec
                     Running
        org.geoserver.security.impl.____SecureTreeNodeTest
                     elapsed: 0.002 sec
                     Running
        org.geoserver.security.____password.____GeoserverPasswordEncoderTest
                     elapsed: 2.766 sec
                     Running
        org.geoserver.security.____password.____MasterPasswordChangeTest
                     elapsed: 1.615 sec
                     Running
        org.geoserver.security.____password.____URLMasterPasswordProviderTest
                     elapsed: 1.364 sec
                     Running
        org.geoserver.security.____rememberme.RememberMeTest
                     elapsed: 1.479 sec
                     Running
        org.geoserver.security.____validation.____FilterConfigValidatorTest
                     elapsed: 0.039 sec
                     Running
        org.geoserver.security.____validation.____MasterPasswordChangeValidatorT____est
                     elapsed: 0.019 sec
                     Running
        org.geoserver.security.____validation.____PasswordValidatorTest
                     elapsed: 0.008 sec
                     Running
        org.geoserver.security.____validation.____RoleStoreValidationWrapperTest
                     elapsed: 0.039 sec
                     Running
        org.geoserver.security.____validation.____SecurityConfigValidatorTest
                     elapsed: 1.344 sec
                     Running
        org.geoserver.security.____validation.____UserGroupStoreValidationWrappe____rTest
                     elapsed: 1.494 sec
                     Running
        org.geoserver.security.xml.____XMLRoleServiceTest
                     elapsed: 2.66 sec
                     Running
        org.geoserver.security.xml.____XMLSecurityConfigValidatorTest
                     elapsed: 1.157 sec
                     Running
        org.geoserver.security.xml.____XMLUserDetailsServiceTest
                     elapsed: 4.275 sec
                     Running
        org.geoserver.security.xml.____XMLUserGroupServiceTest
                     elapsed: 15.564 sec
                     Running
        org.geoserver.template.____DirectFeatureWrapperTest
                     elapsed: 0.301 sec
                     Running org.geoserver.template.____FeatureWrapperTest
                     elapsed: 0.022 sec
                     Running
        org.geoserver.template.____GeoServerTemplateLoader2Test
                     elapsed: 0.054 sec
                     Running
        org.geoserver.threadlocals.____AdminRequestThreadLocalTransfe____rTest
                     elapsed: 0.002 sec
                     Running
        org.geoserver.threadlocals.____AuthenticationThreadLocalTrans____ferTest
                     elapsed: 0 sec
                     Running
        org.geoserver.threadlocals.____LocalLayerThreadLocalTransferT____est
                     elapsed: 0.001 sec
                     Running
        org.geoserver.threadlocals.____LocalWorkspaceThreadLocalTrans____ferTest
                     elapsed: 0.001 sec
                     Running
        org.geoserver.threadlocals.____PublicThreadLocalTransferTest
                     elapsed: 0 sec
                     Running
        org.geoserver.threadlocals.____ThreadLocalsTransferTest
                     elapsed: 1.783 sec
                     Running
        org.geoserver.util.____PartialBufferOutputStream2Test
                     elapsed: 0 sec
                     elapsed: 0.024 sec
                     Running
        org.geoserver.vfny.global.____TolerantStartupTest
                     elapsed: 1.672 sec
                     Running org.vfny.geoserver.____ProjectionPolicyTest
                     elapsed: 2.363 sec
                     Running org.vfny.geoserver.crs.____OverrideCRSTest
                     elapsed: 0.883 sec
                     Running
        org.vfny.geoserver.crs.____OvverideTransformationsTest
                     elapsed: 1.149 sec
                     Running
        org.vfny.geoserver.global.____GeoserverDataDirectoryTest
                     elapsed: 0.779 sec
                     Running
        org.vfny.geoserver.global.xml.____WriterHelperTest
                     elapsed: 0.001 sec
                     Running org.vfny.geoserver.util.____ResponseUtilsTest
                     elapsed: 0 sec
                     Running org.vfny.geoserver.util.____SLDValidatorTest
                     elapsed: 0.123 sec
                     Results :
                     Failed tests:
        testModifyStyleWithResourcesAb____soluteChangeWorkspace(org.____geoserver.config.____GeoServerPersisterTest):
        testModifyStyleWithResourcesRe____moteChangeWorkspace(org.____geoserver.config.____GeoServerPersisterTest):
        testModifyStyleWithResourcesIn____ParentDirChangeWorkspace(__org.__geoserver.config.____GeoServerPersisterTest):
                     [INFO]
        ------------------------------____----------------------------__--__------------
                     [INFO]
                     [INFO] GeoServer
        ..............................____...........
                     SUCCESS [10.789s]
                     SUCCESS [20.037s]
                     SUCCESS [21.908s]
                     [INFO] Main Module
                     FAILURE
                     [3:21.351s]
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SUCCESS [0.370s]
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SUCCESS [0.335s]
                     SKIPPED
                     SKIPPED
                     SUCCESS [0.374s]
                     SKIPPED
                     SUCCESS [0.296s]
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SUCCESS [1.954s]
                     SUCCESS [1.436s]
                     SUCCESS [0.691s]
                     SUCCESS [0.633s]
                     SKIPPED
                     SUCCESS [1.170s]
                     SUCCESS [0.709s]
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SUCCESS [2.668s]
                     SKIPPED
                     SUCCESS [1.084s]
                     SKIPPED
                     SUCCESS [0.541s]
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
        CatalogStore
                     implementation
                         SKIPPED
                     SKIPPED
                     SKIPPED
                     SUCCESS [0.425s]
                     SKIPPED
                     [INFO] DXF WPS PPIO
                     SKIPPED
        Extensions ....
                     SUCCESS [0.426s]
        extensions
                       SKIPPED
                     extension SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     SKIPPED
                     [INFO]
                     [INFO]
                     [INFO]
        org.apache.maven.plugins:____maven-surefire-plugin:2.12.3:____test
        failures.
                     [ERROR]
        <http://ares.opengeo.org/____jenkins/job/geoserver-master/____ws/src/main/target/surefire-____reports
        <http://ares.opengeo.org/__jenkins/job/geoserver-master/__ws/src/main/target/surefire-__reports&gt;
        <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt;&gt;&gt;
                     [ERROR] -> [Help 1]
                     [ERROR]
        re-run
                     Maven with the
                     -e switch.
                     debug logging.
                     [ERROR]
        possible
                     solutions,
                     [ERROR] [Help 1]
        http://cwiki.apache.org/____confluence/display/MAVEN/____MojoFailureException
        <http://cwiki.apache.org/__confluence/display/MAVEN/__MojoFailureException&gt;
        <http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException&gt;&gt;
                     [ERROR]
        resume the
                     build with the
                     command
        build as
                     failure
                 Software Engineer
             *Justin Deoliveira*
             @j_deolive <https://twitter.com/j_deolive__&gt;
        ------------------------------__------------------------------__------------------
        and Eclipse
             Edition
        workflows
             _________________________________________________
             <mailto:Geoserver-devel@anonymised.com
        <mailto:Geoserver-devel@lists.sourceforge.net>>
        https://lists.sourceforge.net/__lists/listinfo/geoserver-devel
        <https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;
        Kevin Smith
        +1-778-785-7459 <tel:%2B1-778-785-7459>
        @boundlessgeo <https://twitter.com/__boundlessgeo
        <https://twitter.com/boundlessgeo&gt;&gt;
    Software Engineer
Kevin Smith
+1-778-785-7459
Software Engineer
See <http://ares.opengeo.org/jenkins/job/geoserver-master/602/changes&gt;
Changes:
[Ben.Caradoc-Davies] Fix bad URL to File conversion
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.292 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.081 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.535 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.616 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.089 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.34 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.526 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.115 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.528 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.201 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.797 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.527 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.057 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.746 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.713 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.383 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.765 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.125 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.037 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.863 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.952 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.86 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.903 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.523 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.61 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.044 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.001 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.091 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.465 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.178 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.157 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.008 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.093 sec
Results :
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.421s]
[INFO] Core Platform Module .............................. SUCCESS [15.570s]
[INFO] Open Web Service Module ........................... SUCCESS [18.848s]
[INFO] Main Module ....................................... FAILURE [3:01.605s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.376s]
[INFO] Community Space ................................... SUCCESS [0.397s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.269s]
[INFO] Application Schema Support ........................ SUCCESS [0.216s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.717s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.839s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.637s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.439s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.506s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.657s]
[INFO] Chart external graphics support ................... SUCCESS [2.310s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.808s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.322s]
[INFO] DXF output format ................................. SUCCESS [0.252s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.227s]
[INFO] Total time: 3:53.209s (Wall Clock)
[INFO] Finished at: Fri Jun 27 06:22:23 UTC 2014
[INFO] Final Memory: 41M/380M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Kevin,
I have pushed a fix that makes the failure portable. I am still trying to follow the logic of the failing test.
Kevin, if you have time, please review GeoServerPersisterTest.testModifyStyleWithResourcesAbsoluteChangeWorkspace; it appears that this failure triggers the others (which pass when run alone in Eclipse). @Ignoreing this one method makes everything pass. Is the persister smart enough to find burg03.svg and copy it even via an absolute file: reference? Could this reference instead be changed to something like "http://doesnotexist.example.org/burg03.svg&quot;? I am not sure what you are testing here.
Kind regards,
Ben.
Software Engineer
For example, the attached change makes the test pass. But Kevin, does it make sense to you?
Kind regards,
Ben.
On 27/06/14 14:30, Ben Caradoc-Davies wrote:
Kevin,
Kind regards,
Ben.
Software Engineer
(attachments)
GeoServerPersisterTest.patch (990 Bytes)
And here it is as a pull request:
https://github.com/geoserver/geoserver/pull/628
make sense to you?
Kind regards,
Ben.
Kevin,
Kind regards,
Ben.
Software Engineer
See <http://ares.opengeo.org/jenkins/job/geoserver-master/603/changes&gt;
Changes:
[ksmith] Allow workspace to be specified as a parameter in GWC
[ksmith] Unit test for GWC Workspace parameter
[smithkm] Document WORKSPACE parameter
[...truncated 3640 lines...]
Running org.geoserver.security.GroupAdminServiceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.285 sec
Running org.geoserver.security.KeyStoreProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.139 sec
Running org.geoserver.security.MigrateFrom_2_2_Test
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.605 sec
Running org.geoserver.security.auth.AuthenticationCacheFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.65 sec
Running org.geoserver.security.auth.AuthenticationFilterTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.466 sec
Running org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.453 sec
Running org.geoserver.security.auth.LRUAuthenticationCacheTest
Running org.geoserver.security.decorators.DecoratingWMSLayerInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.205 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.geoserver.security.impl.AdvertisedCatalogTest
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.08 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.957 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.293 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.763 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.059 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.885 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.784 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.49 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.937 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.368 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.security.validation.PasswordValidatorTest
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.048 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.306 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.964 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.083 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.039 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.079 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.754 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.255 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.196 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.388 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.656 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.816 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.974 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.8 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.106 sec
Results :
Failed tests: testModifyStyleWithResourcesAbsoluteChangeWorkspace(org.geoserver.config.GeoServerPersisterTest): (..)
  testModifyStyleWithResourcesRemoteChangeWorkspace(org.geoserver.config.GeoServerPersisterTest): (..)
  testModifyStyleWithResourcesInParentDirChangeWorkspace(org.geoserver.config.GeoServerPersisterTest): (..)
Tests run: 578, Failures: 3, Errors: 0, Skipped: 1
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.561s]
[INFO] Core Platform Module .............................. SUCCESS [16.791s]
[INFO] Open Web Service Module ........................... SUCCESS [16.989s]
[INFO] Main Module ....................................... FAILURE [2:55.567s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.512s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.303s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.262s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.237s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.397s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.650s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.399s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.424s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.211s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.588s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.011s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.020s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.258s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.294s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.276s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:41.057s (Wall Clock)
[INFO] Finished at: Sat Jun 28 00:17:05 UTC 2014
[INFO] Final Memory: 39M/290M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-master/604/changes&gt;
