See <https://build.geoserver.org/job/geoserver-master/6067/display/redirect?page=changes>
Changes:
[Jody Garnett] Set the EntityResolver in the WPS Request Builder when building the
[...truncated 7.71 MB...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
21 Jul 20:19:01 ERROR [geoserver.rest] - Unable to create import
org.geoserver.rest.RestException 500 INTERNAL_SERVER_ERROR: Unable to create import
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:242)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:75)
at sun.reflect.GeneratedMethodAccessor286.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:160)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:127)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:202)
Caused by: java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:1012)
at org.geoserver.importer.ImportContext.lockUploadFolder(ImportContext.java:324)
at org.geoserver.importer.ImportContext.updateState(ImportContext.java:258)
at org.geoserver.importer.ImportContext.updated(ImportContext.java:381)
at org.geoserver.importer.Importer.changed(Importer.java:942)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:230)
... 60 more
Jul 21, 2018 8:19:01 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.22 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Jul 21, 2018 8:19:01 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Jul 21, 2018 8:19:02 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.77 sec
Results :
Tests run: 75, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 30 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.209 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.226 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.043 s]
[INFO] Main Module ........................................ SUCCESS [01:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.066 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:14 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 33.954 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.334 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.223 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.020 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.341 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 39.664 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:36 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:55 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.086 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.905 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:16 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:21 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.657 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 20.636 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.779 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.124 s]
[INFO] Core UI Module ..................................... FAILURE [01:09 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.062 s]
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.076 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.141 s]
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.898 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.579 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.408 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.245 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.755 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.273 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.467 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.045 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.514 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.094 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.047 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:03 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.093 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.116 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.742 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.257 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.566 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.561 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.028 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.478 s]
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.007 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.051 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.834 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.909 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 34.616 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.043 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.016 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.137 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.047 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.114 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.097 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.062 s]
[INFO] Importer Core Module ............................... SUCCESS [ 37.774 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 39.276 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.651 s]
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SUCCESS [ 14.384 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 15.218 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.514 s]
[INFO] BUILD FAILURE
[INFO] Total time: 11:50 min (Wall Clock)
[INFO] Finished at: 2018-07-21T20:19:02+00:00
[INFO] Final Memory: 134M/1581M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-web-core: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:check failed. ArrayIndexOutOfBoundsException: 16 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
