See <https://build.geoserver.org/job/geoserver-master/6090/display/redirect?page=changes>
Changes:
[jdeolive] GEOS-8871: adding missing return to proxy url lookup
[...truncated 5.81 MB...]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.14-SNAPSHOT/gs-csw-core-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.14-SNAPSHOT/gs-csw-core-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.14-SNAPSHOT/gs-csw-core-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building CSW UI Module 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-csw ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Aug 02, 2018 6:54:43 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerConfigurationLock', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ResourcePool', but ApplicationContext is unset.
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
Aug 02, 2018 6:54:43 PM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Aug 02, 2018 6:54:44 PM org.geoserver.platform.GeoServerExtensions checkContext
Aug 02, 2018 6:54:45 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.433 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[debug] Using AOSP style
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.092 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.219 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.223 s]
[INFO] Main Module ........................................ SUCCESS [01:45 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.119 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:26 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.314 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 24.810 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.467 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.736 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 32.037 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.852 s]
[INFO] Web Feature Service Module ......................... FAILURE [02:04 min]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 20.904 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:30 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 18.139 s]
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.109 s]
[INFO] Core UI Module ..................................... SUCCESS [01:32 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.086 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SUCCESS [ 12.784 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.066 s]
[INFO] Printing Module .................................... SUCCESS [ 16.426 s]
[INFO] Community Space .................................... SUCCESS [ 0.063 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.038 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.763 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.054 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.918 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.389 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.218 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.198 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.419 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.280 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.040 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.738 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.058 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.495 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.141 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.481 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 19.126 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.918 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.093 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.767 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.260 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 35.308 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.811 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.063 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.056 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 16.335 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.796 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.762 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.993 s]
[INFO] BUILD FAILURE
[INFO] Total time: 09:05 min (Wall Clock)
[INFO] Finished at: 2018-08-02T18:54:47+00:00
[INFO] Final Memory: 128M/1599M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wfs: Found 2 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
Not sending mail to unregistered user jdeolive@anonymised.com
