See <https://build.geoserver.org/job/geoserver-master/6100/display/redirect?page=changes>
Changes:
[Andrea Aime] Specifying the right rel for landing page links
[...truncated 12.24 MB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-notification ---
[debug] Using AOSP style
[INFO] Processed 20 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.14-SNAPSHOT/gs-notification-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-oseo ---
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.14-SNAPSHOT/gs-web-oseo-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Task Manager S3 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 36 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-oseo-rest ---
[INFO] Processed 17 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.14-SNAPSHOT/gs-oseo-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.14-SNAPSHOT/gs-taskmanager-s3-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.474 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 16.660 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 16.433 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.382 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 10.343 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.430 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.621 s]
[INFO] ColorMap ........................................... SUCCESS [ 7.411 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 13.538 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.350 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.895 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.440 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.237 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.944 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.067 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.286 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.955 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.653 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 11.042 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 9.125 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.350 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 10.003 s]
[INFO] GeoFence Server .................................... SUCCESS [ 10.574 s]
[INFO] REST SLD service ................................... SUCCESS [ 8.119 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.683 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 9.566 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.149 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.817 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.990 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.810 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.017 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.065 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.505 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 4.081 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.577 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 27.798 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.522 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 10.290 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.030 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.893 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.661 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.346 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.015 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 6.448 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.946 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 6.063 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.672 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 5.702 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.559 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.218 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 3.059 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 6.693 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.829 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.035 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 9.751 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.930 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 8.392 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.926 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 5.738 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.021 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 2.831 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 8.942 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 7.883 s]
[INFO] WFS 3 prototype .................................... FAILURE [ 9.475 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.041 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 14.548 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 5.450 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.044 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 6.100 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.838 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 11.491 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:59 min (Wall Clock)
[INFO] Finished at: 2018-08-06T16:09:48+00:00
[INFO] Final Memory: 139M/1413M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wfs3: Found 2 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs3
