[Geoserver-devel] Build failed in Jenkins: geoserver-master #6168
See <https://build.geoserver.org/job/geoserver-master/6168/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Updating master to 2.15-SNAPSHOT and updating gt and gwc deps
[...truncated 12.32 MB...]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-oseo ---
[debug] Using AOSP style
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Task Manager S3 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 36 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-oseo-rest ---
[INFO] Processed 17 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Community Release Module 2.15-SNAPSHOT
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/gs-script-py-2.15-SNAPSHOT.pom
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/gs-script-py-2.15-SNAPSHOT.pom
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/gs-script-py-2.15-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.script:gs-script-py:jar:2.15-SNAPSHOT is missing, no dependency information available
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/gs-script-js-2.15-SNAPSHOT.pom
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/gs-script-js-2.15-SNAPSHOT.pom
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/gs-script-js-2.15-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.script:gs-script-js:jar:2.15-SNAPSHOT is missing, no dependency information available
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/gs-script-groovy-2.15-SNAPSHOT.pom
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/gs-script-groovy-2.15-SNAPSHOT.pom
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/gs-script-groovy-2.15-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.script:gs-script-groovy:jar:2.15-SNAPSHOT is missing, no dependency information available
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/gs-monitor-hibernate-2.15-SNAPSHOT.pom
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/gs-monitor-hibernate-2.15-SNAPSHOT.pom
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/gs-monitor-hibernate-2.15-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.extension:gs-monitor-hibernate:jar:2.15-SNAPSHOT is missing, no dependency information available
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/gs-script-py-2.15-SNAPSHOT.jar
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/gs-script-js-2.15-SNAPSHOT.jar
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/gs-monitor-hibernate-2.15-SNAPSHOT.jar
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/gs-script-groovy-2.15-SNAPSHOT.jar
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/gs-script-py-2.15-SNAPSHOT.jar
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/gs-script-js-2.15-SNAPSHOT.jar
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/gs-monitor-hibernate-2.15-SNAPSHOT.jar
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/gs-script-groovy-2.15-SNAPSHOT.jar
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-py/2.15-SNAPSHOT/gs-script-py-2.15-SNAPSHOT.jar
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-js/2.15-SNAPSHOT/gs-script-js-2.15-SNAPSHOT.jar
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/script/gs-script-groovy/2.15-SNAPSHOT/gs-script-groovy-2.15-SNAPSHOT.jar
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/extension/gs-monitor-hibernate/2.15-SNAPSHOT/gs-monitor-hibernate-2.15-SNAPSHOT.jar
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.884 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 17.326 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 17.206 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.666 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 10.095 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.929 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.912 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 14.318 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.411 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.013 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.609 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.110 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.335 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.046 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.225 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.730 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.898 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 10.930 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.514 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.419 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 11.575 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.639 s]
[INFO] REST SLD service ................................... SUCCESS [ 8.959 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 8.660 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 9.909 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.240 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.372 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.975 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.225 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.021 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.222 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.394 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.410 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.644 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 28.584 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.483 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 9.930 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.742 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.798 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.871 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.316 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.016 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 6.786 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.501 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.819 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.777 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 6.388 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.898 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.239 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.849 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 5.497 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 3.306 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.020 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 10.208 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 6.374 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 8.678 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.837 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 5.825 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.014 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 3.061 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 8.912 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 8.069 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 8.453 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.043 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 14.265 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 6.674 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 3.203 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.225 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 6.878 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.503 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.737 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:03 min (Wall Clock)
[INFO] Finished at: 2018-08-21T14:18:09+00:00
[INFO] Final Memory: 143M/1542M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.15-SNAPSHOT: The following artifacts could not be resolved: org.geoserver.script:gs-script-py:jar:2.15-SNAPSHOT, org.geoserver.script:gs-script-js:jar:2.15-SNAPSHOT, org.geoserver.script:gs-script-groovy:jar:2.15-SNAPSHOT, org.geoserver.extension:gs-monitor-hibernate:jar:2.15-SNAPSHOT: Could not find artifact org.geoserver.script:gs-script-py:jar:2.15-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
See <https://build.geoserver.org/job/geoserver-master/6169/display/redirect?page=changes&gt;
