See <https://build.geoserver.org/job/geoserver-master/6175/display/redirect?page=changes>
Changes:
[Ian Turton] eclipse m2 compatibility, code format updates (#3038)
[...truncated 11.51 MB...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
27 Aug 05:59:43 ERROR [geoserver.rest] - Unable to create import
org.geoserver.rest.RestException 500 INTERNAL_SERVER_ERROR: Unable to create import
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:242)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:75)
at sun.reflect.GeneratedMethodAccessor286.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:160)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:127)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:203)
Caused by: java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:1012)
at org.geoserver.importer.ImportContext.lockUploadFolder(ImportContext.java:324)
at org.geoserver.importer.ImportContext.updateState(ImportContext.java:258)
at org.geoserver.importer.ImportContext.updated(ImportContext.java:381)
at org.geoserver.importer.Importer.changed(Importer.java:942)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:230)
... 60 more
Aug 27, 2018 5:59:43 AM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.373 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Aug 27, 2018 5:59:44 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Aug 27, 2018 5:59:44 AM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.874 sec
Results :
Tests run: 75, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 30 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.830 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.105 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.281 s]
[INFO] Main Module ........................................ SUCCESS [01:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.049 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:21 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.599 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.096 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.249 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.163 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 20.194 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 44.592 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:03 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.670 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.150 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:21 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:25 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 19.231 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.944 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.857 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.052 s]
[INFO] Core UI Module ..................................... SUCCESS [01:18 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.898 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.090 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.956 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.444 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:37 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:08 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 19.071 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.686 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.048 s]
[INFO] Printing Module .................................... SUCCESS [ 11.937 s]
[INFO] Community Space .................................... SUCCESS [ 0.076 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:27 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.105 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.748 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.944 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.898 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.391 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.202 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.198 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.740 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.299 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.276 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.032 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.013 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.956 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.035 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:10 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.530 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.228 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.469 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.395 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.531 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.562 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.907 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 24.164 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.774 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.082 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.048 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.203 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.062 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.193 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.372 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.920 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.054 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.709 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.656 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 33.738 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.675 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.044 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 12.127 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.765 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.059 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.968 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.329 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.845 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.042 s]
[INFO] Importer Core Module ............................... SUCCESS [ 51.796 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 42.207 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.458 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.897 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.855 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.449 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 50.876 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 14.643 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.932 s]
[INFO] REST SLD service ................................... SUCCESS [ 19.896 s]
[INFO] BUILD FAILURE
[INFO] Total time: 17:33 min (Wall Clock)
[INFO] Finished at: 2018-08-27T05:59:44+00:00
[INFO] Final Memory: 147M/1427M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
