See <http://ares.opengeo.org/jenkins/job/geoserver-master/621/>
[...truncated 5440 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 9e7040f
[INFO] [GitCommitIdMojo] build.commit.id = 9e7040f5244753f08549b93ddcb3ea4750309f30
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-6528 Change master password using REST API
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sec-jdbc ---
[INFO] Copying 2 resources
[INFO] Copying 15 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-sec-jdbc ---
[INFO] Compiling 13 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/security/jdbc/target/classes>
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.109 sec
Running org.geoserver.wfs.v2_0.GetFeaturePagingTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-jdbc ---
[INFO] Copying 0 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-jdbc ---
[INFO] Compiling 29 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/security/jdbc/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-jdbc ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/security/jdbc/target/surefire-reports>
T E S T S
Running org.geoserver.security.jdbc.DB2RoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.923 sec
Running org.geoserver.security.jdbc.DB2UserDetailsServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 3, Time elapsed: 0.014 sec
Running org.geoserver.security.jdbc.DB2UserGroupServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 8, Time elapsed: 0.018 sec
Running org.geoserver.security.jdbc.H2JNDIRoleServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.132 sec
Running org.geoserver.wfs.v2_0.GetFeatureTest
Tests run: 46, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.793 sec
Running org.geoserver.wfs.v2_0.GetFeatureWithLockTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.386 sec
Running org.geoserver.wfs.v2_0.GetPropertyValueTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.432 sec
Running org.geoserver.wfs.v2_0.LockFeatureTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.032 sec
Running org.geoserver.security.jdbc.H2JNDIUserDetailsServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.592 sec
Running org.geoserver.wfs.v2_0.SrsNameRequestTest
Tests run: 25, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.503 sec
Running org.geoserver.wfs.v2_0.SrsNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.434 sec
Running org.geoserver.wfs.v2_0.StoredQueryTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.524 sec
Running org.geoserver.wfs.v2_0.TransactionTest
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.493 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.304 sec
Running org.geoserver.security.jdbc.H2JNDIUserGroupServiceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.953 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.005 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.581 sec
Running org.geoserver.wfs.xml.v1_1.XMLParsingTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.019 sec
Results :
Failed tests: testBBox1(org.geoserver.wfs.v1_1.BoundingBox3DTest): expected:<1> but was:<0>
testBBox2(org.geoserver.wfs.v1_1.BoundingBox3DTest): expected:<1> but was:<0>
testBBox1(org.geoserver.wfs.v2_0.BoundingBox3DTest): expected:<[http://www.opengis.net/wfs/2.0\]> but was:<>
testBBox2(org.geoserver.wfs.v2_0.BoundingBox3DTest): expected:<[http://www.opengis.net/wfs/2.0\]> but was:<>
Tests run: 483, Failures: 4, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
[INFO]
[INFO] Skipping Security UI Modules
[INFO]
[INFO] Skipping Printing Module
[INFO]
[INFO] Skipping HTTP Proxy Extension
[INFO]
[INFO] Skipping ArcSDE DataStore Extension
[INFO]
[INFO] Skipping H2 DataStore Extension
[INFO]
[INFO] Skipping Teradata DataStore Extension
[INFO]
[INFO] Skipping GeoServer CSS Styling
[INFO]
[INFO] Skipping Catalog Services for the Web interfaces
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.149 sec
Running org.geoserver.security.jdbc.H2RoleServiceTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.775s]
[INFO] Core Platform Module .............................. SUCCESS [14.517s]
[INFO] Open Web Service Module ........................... SUCCESS [15.245s]
[INFO] Main Module ....................................... SUCCESS [2:57.570s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.956s]
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SUCCESS [5.298s]
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ FAILURE [4:36.961s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [43.217s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.346s]
[INFO] Core UI Module .................................... SUCCESS [2:25.604s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.231s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.278s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.173s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.173s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.627s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.408s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.425s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.536s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.590s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [5.461s]
[INFO] Chart external graphics support ................... SUCCESS [1.738s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.250s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.808s]
[INFO] OWS request flow controller ....................... SUCCESS [24.913s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.277s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.264s]
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.237s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.199s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8:21.068s (Wall Clock)
[INFO] Finished at: Thu Jul 10 13:53:00 UTC 2014
[INFO] Final Memory: 46M/382M
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.372 sec
Running org.geoserver.security.jdbc.H2UserDetailsServiceTest
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
