[Geoserver-devel] Build failed in Jenkins: geoserver-master #6221
See <https://build.geoserver.org/job/geoserver-master/6221/display/redirect?page=changes&gt;
Changes:
[Alessio Fabiani] [WPS-Remote Community Plugin] - minor checks on uploaded data paths
[github] [GEOS-8042] Fix adding ImagePyramids with spaces in their name (#3116)
[...truncated 12.39 MB...]
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-notification ---
[debug] Using AOSP style
[INFO] Processed 20 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-oseo ---
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Task Manager S3 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 36 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-oseo-rest ---
[INFO] Processed 17 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.464 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 18.046 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 17.861 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.157 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 10.115 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.921 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.971 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 14.358 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.967 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.961 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.112 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.427 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.703 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.622 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.242 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.700 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.870 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 11.766 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.808 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.385 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.068 s]
[INFO] Web Processing Service - Remote processes invocation FAILURE [ 9.972 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.288 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 7.373 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.983 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.384 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.037 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 7.077 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.123 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.158 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.254 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 29.973 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.500 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 9.273 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.378 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.553 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.419 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.781 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.020 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 6.629 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.019 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.824 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 6.099 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 6.098 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 6.578 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.188 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.136 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.861 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 4.825 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 3.395 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.033 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 10.914 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.704 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 8.446 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.871 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 5.675 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.023 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 3.084 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 8.605 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 8.664 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 8.641 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.247 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.784 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.669 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.035 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 15.002 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 6.264 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 10.085 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SUCCESS [ 6.364 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:54 min (Wall Clock)
[INFO] Finished at: 2018-09-24T17:00:18+00:00
[INFO] Final Memory: 136M/1539M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wps-remote: Found 1 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-remote
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/6222/display/redirect?page=changes&gt;
Changes:
[alessio.fabiani] [Keycloack Security Community Plugin] - Adapt to latest keycloack server
[...truncated 12.36 MB...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-keycloak ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/keycloak/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-keycloak ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/keycloak/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-keycloak ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-keycloak ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/keycloak/target/gs-sec-keycloak-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-keycloak ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/keycloak/target/gs-sec-keycloak-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-keycloak ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/keycloak/target/gs-sec-keycloak-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-keycloak ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/keycloak/target/gs-sec-keycloak-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-keycloak ---
[INFO] Processed 9 files (1 non-complying).
[ERROR] Found 1 non-complying files, failing build
[ERROR] To fix formatting errors, run "mvn fmt:format"
[ERROR] Non complying file: <https://build.geoserver.org/job/geoserver-master/ws/src/community/security/keycloak/src/main/java/org/geoserver/security/keycloak/GeoServerKeycloakFilter.java&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.853 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 18.179 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 17.978 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.933 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 10.622 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.966 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.983 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 14.809 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.708 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.826 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.600 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.588 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.416 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.257 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.237 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.136 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.805 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.016 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 9.109 s]
[INFO] Solr Module ........................................ SUCCESS [ 7.284 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.574 s]
[INFO] Web Processing Service - Remote processes invocation FAILURE [ 10.633 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.782 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 7.377 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.081 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.260 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.024 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.188 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.354 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 8.133 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.855 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 30.671 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.462 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 9.749 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.369 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.209 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 5.153 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.147 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.019 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 6.971 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.451 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.725 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.891 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 4.755 s]
[INFO] GeoServer Keycloak Security Plugin ................. FAILURE [ 14.250 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.997 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.161 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.914 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.326 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.303 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.038 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 10.533 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 4.322 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 8.760 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 7.021 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 6.226 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.029 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 2.798 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 9.565 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 8.553 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 8.145 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.429 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.668 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.097 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.080 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 15.400 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 6.269 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 9.524 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 3.656 s]
[INFO] Total time: 04:00 min (Wall Clock)
[INFO] Finished at: 2018-09-24T19:23:48+00:00
[INFO] Final Memory: 140M/1543M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-sec-keycloak: Found 1 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user alessio.fabiani@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/6223/display/redirect&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.731 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 18.140 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 18.025 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.676 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.883 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.972 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.951 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 13.554 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.093 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.901 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.969 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.187 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.952 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.086 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.234 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.811 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.508 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 11.667 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.713 s]
[INFO] Solr Module ........................................ SUCCESS [ 7.193 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.974 s]
[INFO] Web Processing Service - Remote processes invocation FAILURE [ 10.225 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.440 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.890 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.928 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.688 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.040 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.994 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.777 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.186 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.788 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 29.867 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.405 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 10.330 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.418 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.041 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.092 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.887 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.017 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 6.715 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.279 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.872 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.916 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 6.440 s]
[INFO] GeoServer Keycloak Security Plugin ................. FAILURE [ 6.584 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.966 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.103 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.912 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 4.020 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.788 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.041 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 10.183 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 6.242 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 8.337 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.705 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 5.733 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.042 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 2.775 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 8.625 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 8.384 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 8.409 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.651 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.609 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.638 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.060 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 13.568 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 5.284 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 9.459 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.993 s]
[INFO] Total time: 03:53 min (Wall Clock)
[INFO] Finished at: 2018-09-25T08:22:03+00:00
[INFO] Final Memory: 138M/1543M
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/6224/display/redirect?page=changes&gt;
