See <https://build.geoserver.org/job/geoserver-master/6272/display/redirect>
[...truncated 1.05 MB...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
Oct 07, 2018 3:08:40 PM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:227)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:75)
at sun.reflect.GeneratedMethodAccessor286.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:160)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:127)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:203)
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.364 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.765 sec
Results :
Tests run: 75, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 30 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.581 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.409 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.643 s]
[INFO] Main Module ........................................ SUCCESS [01:03 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.062 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:13 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.458 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.623 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.153 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.230 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.750 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.887 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:33 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:00 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.970 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.095 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:50 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:26 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.651 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.885 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.533 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.049 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.921 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.076 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.799 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 19.535 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.106 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:31 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:03 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.797 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.724 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.039 s]
[INFO] Printing Module .................................... SUCCESS [ 14.970 s]
[INFO] Community Space .................................... SUCCESS [ 0.074 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:36 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.061 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.610 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.925 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.963 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.383 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.221 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.214 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.793 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.529 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.286 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.039 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.010 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.057 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.029 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:05 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.046 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.953 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.457 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.268 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.542 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.778 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.049 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 24.998 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.876 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.947 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.083 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.265 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.119 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.606 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.941 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.106 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.212 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.452 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.833 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.234 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.062 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.582 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.946 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.059 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.240 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.914 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.964 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.081 s]
[INFO] Importer Core Module ............................... SUCCESS [ 49.960 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 41.428 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 15.502 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.500 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.564 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 17.418 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 54.341 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.702 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.887 s]
[INFO] REST SLD service ................................... SUCCESS [ 21.673 s]
[INFO] BUILD FAILURE
[INFO] Total time: 17:37 min (Wall Clock)
[INFO] Finished at: 2018-10-07T15:08:41+00:00
[INFO] Final Memory: 145M/1416M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
