[Geoserver-devel] Build failed in Jenkins: geoserver-master #6324
See <https://build.geoserver.org/job/geoserver-master/6324/display/redirect&gt;
[...truncated 1.78 MB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-notification ---
[debug] Using AOSP style
[INFO] Processed 20 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-oseo ---
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.15-SNAPSHOT/gs-web-oseo-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Task Manager S3 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-taskmanager-s3 ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-taskmanager-s3 ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-taskmanager-s3 ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 36 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-oseo-rest ---
[INFO] Processed 17 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.15-SNAPSHOT/gs-oseo-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-taskmanager-s3 ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 5.949 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 17.055 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 16.855 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.674 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 10.042 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.813 s]
[INFO] ColorMap ........................................... SUCCESS [ 7.006 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 12.638 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.442 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.165 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.660 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.142 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.948 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.838 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.195 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.917 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.989 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.906 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 9.360 s]
[INFO] Solr Module ........................................ SUCCESS [ 7.049 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.965 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 10.392 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 7.746 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 7.627 s]
[INFO] GWC Distributed Caching Plugin ..................... FAILURE [ 2.866 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.920 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.044 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.899 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.926 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 8.164 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.278 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 31.548 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.404 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 9.598 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.649 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.915 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 5.066 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.909 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.012 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 6.920 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.615 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 6.419 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.945 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 6.328 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 6.685 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.191 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.045 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.864 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.290 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 1.526 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.014 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 10.423 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 6.311 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 8.512 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.283 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 7.285 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.020 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 2.621 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 9.486 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 8.586 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 9.177 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.603 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.986 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.509 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.055 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 17.171 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 7.085 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 9.417 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SUCCESS [ 6.193 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:59 min (Wall Clock)
[INFO] Finished at: 2018-10-26T10:06:53+00:00
[INFO] Final Memory: 140M/1450M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-gwc-distributed: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/gwc-distributed/src/test/java/org/geoserver/gwc/HazelcastTest.java&gt;:\[16,37\] error: cannot find symbol
[ERROR] class MapConfig
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/community/gwc-distributed/src/test/java/org/geoserver/gwc/HazelcastTest.java&gt;:\[114,36\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc-distributed
See <https://build.geoserver.org/job/geoserver-master/6325/display/redirect?page=changes&gt;
