[Geoserver-devel] Build failed in Jenkins: geoserver-master #6326
See <https://build.geoserver.org/job/geoserver-master/6326/display/redirect&gt;
[...truncated 560.71 KB...]
SEVERE: Could not locate service of type interface org.geoserver.csw.CSWInfo, local workspace is null
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.csw.GetRepositoryItemTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.166 sec
Running org.geoserver.csw.ServiceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.095 sec
Running org.geoserver.csw.records.iso.GetDomainTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.486 sec
Running org.geoserver.csw.records.iso.GetRecordByIdTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.24 sec
Running org.geoserver.csw.records.iso.GetRecordsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.457 sec
Running org.geoserver.csw.store.internal.DescribeRecordTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.625 sec
Running org.geoserver.csw.store.internal.GeoServerInternalCatalogStoreTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.21 sec
Running org.geoserver.csw.store.internal.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.542 sec
Running org.geoserver.csw.store.internal.GetDomainTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.212 sec
Running org.geoserver.csw.store.internal.GetRecordByIdTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.csw.store.internal.GetRecordsTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.659 sec
Running org.geoserver.csw.store.internal.LayerGroupTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.418 sec
Running org.geoserver.csw.store.internal.ResourceAccessManagerCSWTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.536 sec
Results :
Tests run: 108, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-csw-core ---
[debug] Using AOSP style
[INFO] Processed 93 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-csw-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.15-SNAPSHOT/gs-csw-core-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.15-SNAPSHOT/gs-csw-core-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.15-SNAPSHOT/gs-csw-core-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.15-SNAPSHOT/gs-csw-core-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.15-SNAPSHOT/gs-csw-core-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building CSW UI Module 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-csw ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.542 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.203 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.586 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.841 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:19 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.098 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.229 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.073 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.187 s]
[INFO] Web Coverage Service 1.1 Module .................... FAILURE [ 3.852 s]
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... FAILURE [ 8.718 s]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 17.757 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:15 min]
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.061 s]
[INFO] Core UI Module ..................................... SUCCESS [01:08 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.048 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SUCCESS [ 9.712 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Printing Module .................................... SUCCESS [ 11.783 s]
[INFO] Community Space .................................... SUCCESS [ 0.089 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.700 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.453 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.955 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.397 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.219 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.279 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.610 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.256 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.062 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.575 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.071 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.555 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.274 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.566 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.726 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.040 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.055 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.563 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.247 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 27.034 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.054 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.058 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.039 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.078 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.805 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 05:37 min (Wall Clock)
[INFO] Finished at: 2018-10-26T16:29:12+00:00
[INFO] Final Memory: 131M/1560M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wfs: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/wfs/src/main/java/org/geoserver/wfs/response/ShapeZipOutputFormat.java&gt;:\[305,51\] error: cannot find symbol
[ERROR] package org.geotools.wfs.v1_0
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/wfs/src/main/java/org/geoserver/wfs/GetGmlObject.java&gt;:\[49,47\] error: incompatible types: Object cannot be converted to GmlObjectId
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/wfs/src/main/java/org/geoserver/wfs/xml/v1_0_0/GetCapabilitiesTypeBinding.java&gt;:\[80,56\] error: no suitable method found for add(Object)
[ERROR] method Collection.add(String) is not applicable
[ERROR] (argument mismatch; Object cannot be converted to String)
[ERROR] method List.add(String) is not applicable
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/wfs/src/main/java/org/geoserver/wfs/xml/GML2OutputFormat2.java&gt;:\[103,54\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wcs1_1: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/response/WCSCapsTransformer.java&gt;:\[173,59\] error: incompatible types: String cannot be converted to List<String>
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <https://build.geoserver.org/job/geoserver-master/6327/display/redirect&gt;
[...truncated 560.28 KB...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.165 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.089 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.434 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.233 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.451 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.642 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.515 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.64 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.397 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.527 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.564 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.946 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.172 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.149 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.080 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:12 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.418 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 5.161 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.552 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.516 s]
[INFO] Web Coverage Service 1.1 Module .................... FAILURE [ 3.285 s]
[INFO] Web Feature Service Module ......................... FAILURE [ 8.574 s]
[INFO] gs-rest ............................................ SUCCESS [ 17.833 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.066 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.032 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.049 s]
[INFO] Printing Module .................................... SUCCESS [ 11.847 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.382 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.919 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.933 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.378 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.207 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.201 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.756 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.296 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.018 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.828 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.465 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.257 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.536 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.448 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.082 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.064 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.133 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.934 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 27.603 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.018 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.042 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.045 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.326 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.884 s]
[INFO] Total time: 05:32 min (Wall Clock)
[INFO] Finished at: 2018-10-26T17:51:25+00:00
[INFO] Final Memory: 132M/1580M
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/6328/display/redirect&gt;
[...truncated 581.15 KB...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.098 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.436 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.465 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.634 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.206 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.512 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.241 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.646 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.407 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.546 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.631 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.546 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.208 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.327 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.077 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:13 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.362 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 5.037 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.307 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.713 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 20.082 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 3.931 s]
[INFO] Web Feature Service Module ......................... FAILURE [ 8.867 s]
[INFO] gs-rest ............................................ SUCCESS [ 17.718 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:18 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.812 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.065 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] Security UI Modules ................................ SUCCESS [ 0.052 s]
[INFO] REST UI Module ..................................... SUCCESS [ 12.336 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.061 s]
[INFO] Printing Module .................................... SUCCESS [ 11.898 s]
[INFO] Community Space .................................... SUCCESS [ 0.032 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.100 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.499 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.913 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.381 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.228 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.207 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.545 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.269 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.030 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.103 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.046 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.496 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.429 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.531 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.566 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.158 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.048 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.226 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.467 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 28.610 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.004 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.062 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.049 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.161 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.976 s]
[INFO] Total time: 05:55 min (Wall Clock)
[INFO] Finished at: 2018-10-26T21:17:17+00:00
[INFO] Final Memory: 132M/1594M
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wcs2_0: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/wcs2_0/src/main/java/org/geoserver/wcs2_0/exception/OWS20ServiceExceptionHandler.java&gt;:\[203,9\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/6329/display/redirect?page=changes&gt;
Changes:
[Ian Turton] first pass at EMF upgrade
[Ian Turton] minor fix to OwsUtil
[Ian Turton] last fix
[...truncated 1.04 MB...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-cas ---
[INFO] Processed 14 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.071 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.131 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [327 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-app ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/java’> does not exist, ignoring.
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.war
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.509 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.221 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.754 s]
[INFO] Main Module ........................................ SUCCESS [ 59.991 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.071 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:16 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.875 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.469 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.637 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 17.449 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.161 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 44.584 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:32 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:52 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.265 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.298 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:02 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:13 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.262 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 19.419 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 13.039 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.063 s]
[INFO] Core UI Module ..................................... SUCCESS [01:11 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 32.402 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 51.478 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.890 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.330 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.260 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.054 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:27 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:04 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.701 s]
[INFO] REST UI Module ..................................... SUCCESS [ 12.157 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.056 s]
[INFO] Printing Module .................................... SUCCESS [ 13.228 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.116 s]
[INFO] Community Space .................................... SUCCESS [ 0.031 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:13 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.054 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.847 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.791 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.876 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.363 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.212 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.203 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.009 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.310 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.240 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.066 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.631 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.424 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.036 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:00 min]
[INFO] Excel Output Format ................................ SUCCESS [ 12.715 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.488 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.173 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.505 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 19.173 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.816 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.396 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.055 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 26.118 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.128 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.301 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.336 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 34.217 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.805 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.100 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.723 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.259 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.919 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.342 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.813 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.037 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.720 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.861 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.277 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.099 s]
[INFO] Importer Core Module ............................... FAILURE [ 5.923 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.601 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 18.803 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 58.548 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 18.882 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.766 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.885 s]
[INFO] REST SLD service ................................... SUCCESS [ 20.171 s]
[INFO] Total time: 16:27 min (Wall Clock)
[INFO] Finished at: 2018-10-26T21:53:36+00:00
[INFO] Final Memory: 158M/1429M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wps-core: Found 4 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-importer-core: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/GMLFileFormat.java&gt;:\[46,28\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/GMLFileFormat.java&gt;:\[96,17\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <https://build.geoserver.org/job/geoserver-master/6330/display/redirect?page=changes&gt;
Changes:
[tbarsballe] Fix importer compile failure
[...truncated 1.08 MB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.124 sec
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.261 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO] Webapp assembled in [525 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.224 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.396 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.434 s]
[INFO] Main Module ........................................ SUCCESS [ 59.883 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.086 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:18 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.342 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.317 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.321 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.873 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.539 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.091 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:31 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:59 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.897 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.129 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:03 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.270 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.017 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.349 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.050 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.447 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 56.749 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.705 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.214 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.264 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:29 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:02 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.670 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.836 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.064 s]
[INFO] Printing Module .................................... SUCCESS [ 11.999 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.647 s]
[INFO] Community Space .................................... SUCCESS [ 0.035 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:18 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.990 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.011 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.441 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.881 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.383 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.214 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.177 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.119 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.338 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.046 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.474 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.781 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.040 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:09 min]
[INFO] Excel Output Format ................................ SUCCESS [ 12.945 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.521 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.853 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.526 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.080 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 14.063 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.024 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.078 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 26.864 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.052 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.664 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.163 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.376 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 35.196 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 18.278 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.102 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.176 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.098 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 29.969 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.720 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.059 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 12.125 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.073 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.903 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 9.240 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.854 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.065 s]
[INFO] Importer Core Module ............................... SUCCESS [ 48.716 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 40.625 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.009 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.734 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.965 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 19.946 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 52.716 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 18.895 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 14.573 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.891 s]
[INFO] REST SLD service ................................... SUCCESS [ 18.002 s]
[INFO] Total time: 17:21 min (Wall Clock)
[INFO] Finished at: 2018-10-27T01:03:25+00:00
[INFO] Final Memory: 157M/1370M
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user tbarsballe@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/6331/display/redirect&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.103 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.173 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO] Webapp assembled in [337 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.236 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.997 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.608 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.076 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.627 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 5.723 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.346 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 17.119 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.024 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 45.665 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:30 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.173 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.269 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:00 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:19 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.338 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.024 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.520 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 32.564 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 50.555 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.891 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.793 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.645 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.060 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:28 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.463 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.936 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.057 s]
[INFO] Printing Module .................................... SUCCESS [ 12.023 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.701 s]
[INFO] Community Space .................................... SUCCESS [ 0.034 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:14 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.029 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.186 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.494 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.939 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.372 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.211 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.195 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.014 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.242 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.301 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.033 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.606 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.135 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:11 min]
[INFO] Excel Output Format ................................ SUCCESS [ 12.506 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.484 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.921 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.490 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.818 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 14.483 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.948 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.054 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.360 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.106 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.568 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.994 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 35.635 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.589 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.042 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.998 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.100 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 30.100 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.829 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.035 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 12.053 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.894 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.497 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.444 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.066 s]
[INFO] Importer Core Module ............................... SUCCESS [ 49.913 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 41.880 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.791 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.690 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.902 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 19.307 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 54.859 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 19.753 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 14.709 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.860 s]
[INFO] REST SLD service ................................... SUCCESS [ 17.634 s]
[INFO] Total time: 17:15 min (Wall Clock)
[INFO] Finished at: 2018-10-27T05:04:02+00:00
[INFO] Final Memory: 159M/1549M
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/6332/display/redirect?page=changes&gt;
