See <https://build.geoserver.org/job/geoserver-master/6344/display/redirect?page=changes>
Changes:
[tbarsballe] Refactor geoserver for the gt-main and gt-data merge. Also removes a
[...truncated 1.14 MB...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 1.322 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.717 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-cas ---
[debug] Using AOSP style
[INFO] Processed 14 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT
[INFO] Webapp assembled in [917 msecs]
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO] Building war: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-app ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/java’> does not exist, ignoring.
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.war
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.861 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.753 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 22.240 s]
[INFO] Main Module ........................................ SUCCESS [02:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.160 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:58 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:04 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.085 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 7.087 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 37.661 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 44.490 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:26 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:54 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:34 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.827 s]
[INFO] gs-rest ............................................ SUCCESS [ 25.323 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:59 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:24 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 31.661 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 30.225 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 23.796 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.122 s]
[INFO] Core UI Module ..................................... SUCCESS [02:16 min]
[INFO] WMS UI Module ...................................... SUCCESS [01:00 min]
[INFO] GWC UI Module ...................................... SUCCESS [01:30 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 18.750 s]
[INFO] Demos Module ....................................... SUCCESS [ 29.134 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 22.847 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.127 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:27 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:04 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.895 s]
[INFO] REST UI Module ..................................... SUCCESS [ 19.594 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.104 s]
[INFO] Printing Module .................................... SUCCESS [ 25.287 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 12.305 s]
[INFO] Community Space .................................... SUCCESS [ 0.239 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.108 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:41 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 21.720 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 21.065 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.952 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.086 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.657 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.348 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.296 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.173 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.068 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.397 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.098 s]
[INFO] OGR CORE ........................................... SUCCESS [ 5.324 s]
[INFO] OGR WFS ............................................ SUCCESS [ 17.642 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.093 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:15 min]
[INFO] OGR WPS ............................................ SUCCESS [ 15.041 s]
[INFO] Excel Output Format ................................ SUCCESS [ 24.956 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.626 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.804 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.610 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 23.525 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 19.888 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 47.274 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 26.368 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 4.263 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.107 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 47.192 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.050 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 12.052 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.103 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.288 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.615 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [01:02 min]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 32.285 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.175 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 14.716 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.104 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 52.124 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 18.516 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.136 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 22.908 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 16.861 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.065 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 36.732 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 21.335 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 12.015 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.067 s]
[INFO] Importer Core Module ............................... FAILURE [01:19 min]
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 29.573 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 26.486 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:13 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 30.053 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 24.844 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.629 s]
[INFO] REST SLD service ................................... SUCCESS [ 37.170 s]
[INFO] BUILD FAILURE
[INFO] Total time: 29:58 min (Wall Clock)
[INFO] Finished at: 2018-10-30T19:56:45+00:00
[INFO] Final Memory: 158M/1603M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-importer-core: Found 1 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
Not sending mail to unregistered user tbarsballe@anonymised.com
