[Geoserver-devel] Build failed in Jenkins: geoserver-master #6403
See <https://build.geoserver.org/job/geoserver-master/6403/display/redirect?page=changes&gt;
Changes:
[tbarsballe] split packages: Move ArcSDE factories to org.geotools.arcsde.data
[tbarsballe] split packages: Move ComplexFeatureConstants to
[tbarsballe] Java 11 runtime considerations
[...truncated 1.17 MB...]
[debug] Using AOSP style
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/test-classes&gt;
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT [96/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/surefire-reports&gt;
T E S T S
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.379 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[INFO] Processed 34 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.750 s]
[INFO] Core Platform Module ............................... SUCCESS [ 19.308 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 19.464 s]
[INFO] Main Module ........................................ SUCCESS [01:56 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.155 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:07 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.568 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.720 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 7.033 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.932 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.323 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 42.368 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:57 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.665 s]
[INFO] gs-rest ............................................ SUCCESS [ 25.275 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:33 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.089 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 16.806 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.326 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.082 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.511 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 58.968 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.352 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.769 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.816 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.094 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:25 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:02 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.149 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.492 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.134 s]
[INFO] Printing Module .................................... SUCCESS [ 11.962 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.318 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.039 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:22 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.717 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.900 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.761 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.929 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.679 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.286 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.268 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.340 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 7.555 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.400 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.087 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.498 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.813 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.080 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:08 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.720 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.739 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.613 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.420 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.693 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.490 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.892 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 25.149 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.674 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.030 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.104 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 27.068 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.050 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.062 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.086 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.003 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 33.455 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.146 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.081 s]
[INFO] Catalog Services for the Web interfaces ............ FAILURE [ 2.799 s]
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.088 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.757 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.700 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.074 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.458 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.990 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.412 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.088 s]
[INFO] Importer Core Module ............................... SUCCESS [ 32.260 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 44.534 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 16.942 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 14.162 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.538 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.455 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 51.105 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 17.292 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.385 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.882 s]
[INFO] REST SLD service ................................... SUCCESS [ 25.491 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 20.830 s]
[INFO] GeoFence Server .................................... SUCCESS [ 35.668 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:51 min (Wall Clock)
[INFO] Finished at: 2018-11-27T19:15:34Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-csw-api: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MDQueryableFilterVisitor.java&gt;:\[8,39\] error: package org.geotools.data.complex.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[20,39\] error: package org.geotools.data.complex.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[21,39\] error: package org.geotools.data.complex.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[21,39\] error: package org.geotools.data.complex.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[22,39\] error: package org.geotools.data.complex.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MDQueryableFilterVisitor.java&gt;:\[37,17\] error: package XPathUtil does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MDQueryableFilterVisitor.java&gt;:\[38,16\] error: cannot find symbol
[ERROR] class MDQueryableFilterVisitor
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[76,8\] error: cannot find symbol
[ERROR] class MetaDataDescriptor
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[76,41\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[89,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[90,20\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[142,8\] error: cannot find symbol
[ERROR] class CSWRecordDescriptor
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[142,41\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[152,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[153,20\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-api
Not sending mail to unregistered user tbarsballe@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/6404/display/redirect&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.438 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.223 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.255 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.363 s]
[INFO] Main Module ........................................ SUCCESS [01:16 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.092 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:20 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.799 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 8.005 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.449 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 19.512 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 23.364 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 41.857 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:51 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:07 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.904 s]
[INFO] gs-rest ............................................ SUCCESS [ 18.545 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:32 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:37 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.550 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 16.760 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.024 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.075 s]
[INFO] Core UI Module ..................................... SUCCESS [01:23 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 32.055 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 58.998 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 14.607 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.539 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.279 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.100 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:26 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:03 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.333 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.336 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.088 s]
[INFO] Printing Module .................................... SUCCESS [ 14.346 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.644 s]
[INFO] Community Space .................................... SUCCESS [ 0.035 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.038 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:19 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.622 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.275 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.341 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.749 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.641 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.206 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.235 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.632 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.884 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.283 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.072 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.804 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.874 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.082 s]
[INFO] OGR WPS ............................................ SUCCESS [ 8.585 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.433 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.629 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.835 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.627 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.851 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.833 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.014 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.534 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.825 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.137 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 27.579 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.999 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.750 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.486 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 32.690 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.261 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.154 s]
[INFO] Catalog Services for the Web interfaces ............ FAILURE [ 2.855 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.165 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.442 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.099 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.129 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.571 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.273 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.834 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.086 s]
[INFO] Importer Core Module ............................... SUCCESS [ 32.618 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 39.740 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.503 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 14.233 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.018 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.707 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 49.689 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 17.341 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 17.138 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.575 s]
[INFO] REST SLD service ................................... SUCCESS [ 25.350 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 20.779 s]
[INFO] GeoFence Server .................................... SUCCESS [ 36.155 s]
[INFO] Total time: 18:35 min (Wall Clock)
[INFO] Finished at: 2018-11-27T20:32:55Z
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/6405/display/redirect?page=changes&gt;
