[Geoserver-devel] Build failed in Jenkins: geoserver-master #6409
See <https://build.geoserver.org/job/geoserver-master/6409/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Adding a test to verify implementation of reverse on raster
[tbarsballe] Add directions on building and running on windows (#3264)
[...truncated 1.20 MB...]
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [969 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-app ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.war
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT [99/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-geofence-server ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/surefire-reports&gt;
T E S T S
Running org.geoserver.geofence.internal.InternalServicesTest
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Skipping test in InternalServicesTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 22.637 sec
Running org.geoserver.geofence.internal.InternalUserResolverTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.603 sec
Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.399 sec
Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.432 sec
Running org.geoserver.geofence.rest.RulesRestControllerTest
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.084 sec
Running org.geoserver.geofence.web.GeofenceRulesModelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.812 sec
Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.221 sec
Running org.geoserver.geofence.web.GeofenceServerPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.548 sec
Results :
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-geofence-server ---
[INFO] Processed 19 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-geofence-server/2.15-SNAPSHOT/gs-geofence-server-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-geofence-server/2.15-SNAPSHOT/gs-geofence-server-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-geofence-server/2.15-SNAPSHOT/gs-geofence-server-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-geofence-server/2.15-SNAPSHOT/gs-geofence-server-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-geofence-server/2.15-SNAPSHOT/gs-geofence-server-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.892 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.725 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 21.684 s]
[INFO] Main Module ........................................ SUCCESS [01:52 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.204 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:48 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:00 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 14.218 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.915 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.893 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 37.207 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:16 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:36 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 55.595 s]
[INFO] gs-rest ............................................ SUCCESS [ 24.603 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [03:47 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:24 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 36.807 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 40.301 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 24.783 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.121 s]
[INFO] Core UI Module ..................................... SUCCESS [02:11 min]
[INFO] WMS UI Module ...................................... SUCCESS [01:04 min]
[INFO] GWC UI Module ...................................... SUCCESS [01:43 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 26.323 s]
[INFO] Demos Module ....................................... SUCCESS [ 48.428 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 29.397 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.123 s]
[INFO] Security UI Core Module ............................ SUCCESS [04:34 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:12 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 22.124 s]
[INFO] REST UI Module ..................................... SUCCESS [ 23.680 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.212 s]
[INFO] Printing Module .................................... SUCCESS [ 28.962 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 14.092 s]
[INFO] Community Space .................................... SUCCESS [ 0.156 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.074 s]
[INFO] Application Schema Integration Test ................ SUCCESS [04:07 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 20.295 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 27.145 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 23.504 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.864 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.667 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.248 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.311 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 36.670 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.676 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.581 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.056 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.314 s]
[INFO] OGR WFS ............................................ SUCCESS [ 24.254 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.040 s]
[INFO] Web Processing Service Module ...................... SUCCESS [03:12 min]
[INFO] OGR WPS ............................................ SUCCESS [ 20.836 s]
[INFO] Excel Output Format ................................ SUCCESS [ 24.024 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.672 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.214 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.748 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 21.380 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 24.183 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 50.783 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 31.749 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 4.329 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.158 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 46.875 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.084 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 11.563 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.185 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.588 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 35.652 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [01:18 min]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 40.606 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.105 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 19.742 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 42.321 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:09 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 20.349 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.068 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 31.760 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 16.289 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.048 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 46.204 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 22.301 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 46.605 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.421 s]
[INFO] Importer Core Module ............................... SUCCESS [01:09 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:17 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 29.796 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 29.702 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 37.652 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [01:32 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:20 min]
[INFO] Vector Tiles ....................................... SUCCESS [01:15 min]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 33.424 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.923 s]
[INFO] REST SLD service ................................... FAILURE [ 58.895 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 47.067 s]
[INFO] GeoFence Server .................................... SUCCESS [01:02 min]
[INFO] BUILD FAILURE
[INFO] Total time: 37:45 min (Wall Clock)
[INFO] Finished at: 2018-11-28T18:25:07Z
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-sldservice: Found 1 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-sldservice
Not sending mail to unregistered user tbarsballe@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/6410/display/redirect?page=changes&gt;
Changes:
[github] [GEOS-9027] MongoDB complex store iterator enters in an infinite loop if
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.importer:gs-importer-web >---------------
[INFO] Building Importer Web UI Module 2.15-SNAPSHOT [98/99]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-importer-web ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-importer-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-web ---
[INFO] Copying 27 resources
[INFO] Processed 30 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Copying 20 resources
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-importer-web ---
[INFO]
[INFO] Compiling 33 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/classes&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/surefire-reports&gt;
T E S T S
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.885 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[INFO] Processed 34 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.094 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.005 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 18.267 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.271 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:28 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 47.955 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 9.748 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 12.538 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.475 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 27.223 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 54.324 s]
[INFO] Web Feature Service Module ......................... SUCCESS [06:07 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:50 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 49.370 s]
[INFO] gs-rest ............................................ SUCCESS [ 56.366 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:21 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:02 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 21.196 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 24.635 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 24.999 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.118 s]
[INFO] Core UI Module ..................................... SUCCESS [04:47 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 42.496 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:38 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 17.308 s]
[INFO] Demos Module ....................................... SUCCESS [ 23.874 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 24.473 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.189 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:12 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:55 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.875 s]
[INFO] REST UI Module ..................................... SUCCESS [ 16.415 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.247 s]
[INFO] Printing Module .................................... SUCCESS [ 19.471 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 12.720 s]
[INFO] Community Space .................................... SUCCESS [ 0.039 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.079 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:51 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 15.327 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 18.704 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 19.622 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.068 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.764 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.294 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.299 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 14.650 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.147 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.326 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.053 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.730 s]
[INFO] OGR WFS ............................................ SUCCESS [ 14.016 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.058 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:02 min]
[INFO] OGR WPS ............................................ SUCCESS [ 19.208 s]
[INFO] Excel Output Format ................................ SUCCESS [ 19.850 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.741 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.599 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.554 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 22.582 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.255 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 53.505 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.555 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.838 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.245 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 49.840 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.089 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 13.498 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.112 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.600 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.158 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [01:02 min]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 26.572 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.201 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 14.367 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 17.805 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 58.986 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 19.469 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.064 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 16.330 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 19.508 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.036 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 32.532 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 20.878 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 27.695 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.228 s]
[INFO] Importer Core Module ............................... SUCCESS [ 56.763 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:10 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 29.090 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 22.819 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 23.053 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 49.611 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:11 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 37.243 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 27.083 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.499 s]
[INFO] REST SLD service ................................... FAILURE [ 33.313 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 37.013 s]
[INFO] GeoFence Server .................................... SUCCESS [ 55.562 s]
[INFO] Total time: 32:42 min (Wall Clock)
[INFO] Finished at: 2018-11-28T21:43:00Z
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/6411/display/redirect&gt;
[...truncated 1.21 MB...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.09 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.19 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO]
[INFO] Webapp assembled in [480 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.632 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.031 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.352 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.109 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:09 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.020 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.560 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.506 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.387 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.912 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 41.164 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:31 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:57 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.920 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.417 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:01 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:16 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.042 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 16.290 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.124 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.074 s]
[INFO] Core UI Module ..................................... SUCCESS [01:07 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.740 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 46.292 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.522 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.904 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.804 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.131 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:27 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:03 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.022 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.024 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.089 s]
[INFO] Printing Module .................................... SUCCESS [ 12.193 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.714 s]
[INFO] Community Space .................................... SUCCESS [ 0.058 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:16 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.242 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.734 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.389 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.783 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.551 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.806 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.062 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 6.378 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.083 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.319 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.061 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.322 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.530 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.075 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:10 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.371 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.674 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.464 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.614 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.542 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.778 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.263 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 28.326 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.844 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.730 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.087 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.035 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.088 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.035 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.763 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.684 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.726 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.412 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.111 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.866 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.715 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.499 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.494 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.607 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.891 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.027 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 16.037 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.377 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.831 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.055 s]
[INFO] Importer Core Module ............................... SUCCESS [ 49.531 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 39.412 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.378 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.517 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.381 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.872 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 51.535 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 18.890 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 14.062 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.423 s]
[INFO] REST SLD service ................................... FAILURE [ 20.495 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 20.261 s]
[INFO] GeoFence Server .................................... SUCCESS [ 33.414 s]
[INFO] Total time: 17:52 min (Wall Clock)
[INFO] Finished at: 2018-11-29T00:00:37Z
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/6412/display/redirect&gt;
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.221 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.562 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO]
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.066 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.879 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.997 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 19.908 s]
[INFO] Main Module ........................................ SUCCESS [01:49 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.208 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:52 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:09 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.162 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.004 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 32.042 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 39.743 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:41 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:46 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:35 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 54.542 s]
[INFO] gs-rest ............................................ SUCCESS [ 31.448 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:51 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:28 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 36.099 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 36.362 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 25.203 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.095 s]
[INFO] Core UI Module ..................................... SUCCESS [02:03 min]
[INFO] GWC UI Module ...................................... SUCCESS [01:00 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 19.630 s]
[INFO] Demos Module ....................................... SUCCESS [ 30.429 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.559 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.097 s]
[INFO] Security UI Core Module ............................ SUCCESS [03:12 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:22 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.360 s]
[INFO] REST UI Module ..................................... SUCCESS [ 21.118 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.144 s]
[INFO] Printing Module .................................... SUCCESS [ 21.128 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.414 s]
[INFO] Community Space .................................... SUCCESS [ 0.089 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.071 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:21 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 17.368 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 20.852 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 20.457 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.180 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.542 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.348 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.278 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 13.986 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.883 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.551 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.159 s]
[INFO] OGR CORE ........................................... SUCCESS [ 5.122 s]
[INFO] OGR WFS ............................................ SUCCESS [ 17.469 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.170 s]
[INFO] Web Processing Service Module ...................... SUCCESS [04:46 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.092 s]
[INFO] Excel Output Format ................................ SUCCESS [ 29.759 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.591 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.460 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.561 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 22.700 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 14.259 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.384 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 23.375 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 4.317 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.154 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 27.713 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.776 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.070 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.270 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 37.217 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 33.860 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.277 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.114 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 16.623 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 20.126 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 35.858 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.628 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.044 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 22.407 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.863 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.052 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [01:15 min]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.167 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 17.450 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.123 s]
[INFO] Importer Core Module ............................... SUCCESS [ 32.258 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 40.732 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.155 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 14.515 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 25.610 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [01:13 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 50.764 s]
[INFO] Vector Tiles ....................................... SUCCESS [01:10 min]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.701 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.753 s]
[INFO] REST SLD service ................................... FAILURE [01:36 min]
[INFO] GeoFence security integration ...................... SUCCESS [ 22.831 s]
[INFO] GeoFence Server .................................... SUCCESS [ 36.966 s]
[INFO] Total time: 31:37 min (Wall Clock)
[INFO] Finished at: 2018-11-29T01:38:44Z
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/6413/display/redirect?page=changes&gt;
Changes:
[Alessio Fabiani] [JIRA GEOS-9040] Move the GeoServer ENV Parametrization documentation to
[INFO]
[INFO] Webapp assembled in [815 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.457 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.271 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.921 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.722 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.644 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.682 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.552 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.351 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.435 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.496 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.239 s]
[INFO] Main Module ........................................ SUCCESS [01:30 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.150 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:44 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.394 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 12.923 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.478 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.206 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 34.252 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:12 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:18 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:20 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 51.934 s]
[INFO] gs-rest ............................................ SUCCESS [ 24.317 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:48 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:15 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 29.705 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 33.769 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 23.223 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.096 s]
[INFO] Core UI Module ..................................... SUCCESS [01:53 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 53.739 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:44 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 20.683 s]
[INFO] Demos Module ....................................... SUCCESS [ 37.695 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 38.670 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:41 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:02 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 22.952 s]
[INFO] REST UI Module ..................................... SUCCESS [ 21.922 s]
[INFO] Printing Module .................................... SUCCESS [ 21.852 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 13.907 s]
[INFO] Community Space .................................... SUCCESS [ 0.081 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [04:05 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 19.167 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 25.507 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 22.019 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.752 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.553 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.217 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.252 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 15.079 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.981 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.400 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.087 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.591 s]
[INFO] OGR WFS ............................................ SUCCESS [ 17.134 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.226 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:57 min]
[INFO] OGR WPS ............................................ SUCCESS [ 19.404 s]
[INFO] Excel Output Format ................................ SUCCESS [ 22.753 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.852 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.751 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.527 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 25.282 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 19.213 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 45.262 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 25.740 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 5.476 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.089 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 38.807 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.068 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 13.139 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.174 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 4.624 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 33.291 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [01:05 min]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 31.575 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.137 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 19.183 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 17.973 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:01 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 20.933 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.062 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 24.323 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 15.262 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.059 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 31.902 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 25.527 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 17.944 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.241 s]
[INFO] Importer Core Module ............................... SUCCESS [01:05 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:13 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 27.346 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 23.444 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 34.137 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 35.856 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:12 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 30.595 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 29.149 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.463 s]
[INFO] REST SLD service ................................... FAILURE [ 42.843 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 42.482 s]
[INFO] GeoFence Server .................................... SUCCESS [01:01 min]
[INFO] Total time: 31:12 min (Wall Clock)
[INFO] Finished at: 2018-11-29T13:58:28Z
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/6414/display/redirect?page=changes&gt;
