See <http://ares.opengeo.org/jenkins/job/geoserver-master/650/>
[...truncated 24644 lines...]
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.74 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.333 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.642 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Query:
feature type: MappedFeatureType
filter: [ shape intersects POLYGON ((-1.3650000000000033 52.475133749539246, -1.235000000000003 52.475133749539246, -1.235000000000003 52.52485219413131, -1.3650000000000033 52.52485219413131, -1.3650000000000033 52.475133749539246)) ]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
filter: [ shape intersects POLYGON ((-1.365 52.475, -1.235 52.475, -1.235 52.525, -1.365 52.525, -1.365 52.475)) ]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
filter: [[ shape intersects POLYGON ((-1.365 53.475, -1.235 53.475, -1.235 53.525, -1.365 53.525, -1.365 53.475)) ] AND [[ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = http://urn.opengis.net ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = a ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = b ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = c ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = d ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = e ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = f ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = g ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = h ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = i ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = j ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = k ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = l ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = m ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = n ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = o ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = p ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = q ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = r ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = S ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = t ]]]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
[properties: ALL ]
Query:
[properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.339 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 28.236 sec
Running org.geoserver.importer.DatesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.geoserver.importer.DirectoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.083 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.75 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.193 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.361 sec <<< FAILURE!
testGeometry(org.geoserver.test.XlinkGeometryTest) Time elapsed: 1354 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[xlinkvalue2]> but was:<>
at org.junit.Assert.assertEquals(Assert.java:115)
at org.junit.Assert.assertEquals(Assert.java:144)
at org.geoserver.test.AbstractAppSchemaTestSupport.assertXpathEvaluatesTo(AbstractAppSchemaTestSupport.java:344)
at org.geoserver.test.XlinkGeometryTest.testGeometry(XlinkGeometryTest.java:40)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.415 sec
Results :
Failed tests: testNamespaces(org.geoserver.test.SecondaryNamespaceTest): expected:<2> but was:<0>
testGeometry(org.geoserver.test.XlinkGeometryTest): expected:<[xlinkvalue2]> but was:<>
Tests run: 151, Failures: 2, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping CSW UI Module
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.743 sec
Running org.geoserver.importer.FeatureDataConverterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.importer.ImportContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.importer.ImportTransformTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.376s]
[INFO] Core Platform Module .............................. SUCCESS [13.750s]
[INFO] Open Web Service Module ........................... SUCCESS [16.207s]
[INFO] Main Module ....................................... SUCCESS [3:12.210s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.817s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.183s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [48.576s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.130s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.891s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.995s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:57.484s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:35.384s]
[INFO] Web Map Service Module ............................ SUCCESS [5:23.218s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:27.351s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:40.115s]
[INFO] REST Support Module ............................... SUCCESS [44.282s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:12.543s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.518s]
[INFO] Core UI Module .................................... SUCCESS [2:31.500s]
[INFO] WMS UI Module ..................................... SUCCESS [1:04.126s]
[INFO] GWC UI Module ..................................... SUCCESS [1:30.864s]
[INFO] WFS UI Module ..................................... SUCCESS [45.251s]
[INFO] Demoes Module ..................................... SUCCESS [1:00.415s]
[INFO] WCS UI Module ..................................... SUCCESS [53.031s]
[INFO] Security UI Modules ............................... SUCCESS [0.305s]
[INFO] Security UI Core Module ........................... SUCCESS [3:52.211s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [47.117s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.242s]
[INFO] Printing Module ................................... SUCCESS [34.629s]
[INFO] Community Space ................................... SUCCESS [0.266s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.373s]
[INFO] Application Schema Support ........................ SUCCESS [0.179s]
[INFO] Application Schema Integration Test ............... FAILURE [4:24.004s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.391s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.701s]
[INFO] GeoSearch Index Module ............................ SUCCESS [45.550s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.574s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.240s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.653s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.458s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.588s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.696s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.908s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.740s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [33.621s]
[INFO] Excel Output Format ............................... SUCCESS [42.203s]
[INFO] Validation Module ................................. SUCCESS [5.433s]
[INFO] Chart external graphics support ................... SUCCESS [1.459s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.175s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.917s]
[INFO] OWS request flow controller ....................... SUCCESS [28.699s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.296s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:23.332s]
[INFO] Web Processing Service GUI ........................ SUCCESS [58.482s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [45.149s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.700s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.357s]
[INFO] Core Monitor Extension ............................ SUCCESS [26.387s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [56.402s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:00.751s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [47.902s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.276s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.374s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [24.831s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:49.707s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.379s]
[INFO] DXF WFS output format ............................. SUCCESS [39.260s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [37.436s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.269s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [51.062s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [34.759s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.199s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 35:17.274s (Wall Clock)
[INFO] Finished at: Thu Jul 17 20:28:48 UTC 2014
[INFO] Final Memory: 73M/262M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
