Hudson
January 22, 2019, 9:55am
1
See <https://build.geoserver.org/job/geoserver-master/6503/display/redirect?page=changes> ;
Changes:
[Andrea Aime] PMD: enabling priority 3 rules, same way as done in GeoTools
[...truncated 1007.19 KB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] -----------------< org.geoserver.extension:gs-web-sec >-----------------
[INFO] Building GeoServer Security Extension Web Modules 2.15-SNAPSHOT [71/99]
[INFO] --------------------------------[ pom ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target> ;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src> ;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec ---
[info] Skipping format check
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.15-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.15-SNAPSHOT/gs-web-sec-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.15-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.15-SNAPSHOT/gs-web-sec-2.15-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT [72/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target> ;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes> ;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java> ;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> ;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> ;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.409 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.030 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.289 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.556 s]
[INFO] Main Module ........................................ SUCCESS [01:11 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.215 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:16 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 44.381 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 3.290 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.971 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.851 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 17.118 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 56.973 s]
[INFO] Web Feature Service Module ......................... SUCCESS [02:13 min]
[INFO] Web Map Service Module ............................. FAILURE [03:11 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 10.951 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [02:13 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.411 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 25.233 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.190 s]
[INFO] Core UI Module ..................................... SUCCESS [01:52 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 12.881 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.229 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:16 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:41 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.597 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.039 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.107 s]
[INFO] Printing Module .................................... SUCCESS [ 21.739 s]
[INFO] Community Space .................................... SUCCESS [ 0.088 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.089 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 14.648 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 16.192 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.970 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.020 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.700 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.308 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.403 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.770 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.391 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.089 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.818 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.481 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.154 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:42 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.364 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.778 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.603 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.127 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.633 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 13.301 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.183 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 26.489 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.991 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.119 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.153 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 3.418 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.067 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.621 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 23.197 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.067 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.995 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.137 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.553 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.164 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.125 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 20.391 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.432 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.125 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 23.597 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 17.149 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 24.538 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.768 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 15:08 min (Wall Clock)
[INFO] Finished at: 2019-01-22T09:55:57Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports> ; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Failure is expected, I’m waiting for Travis to confirm a green build on the GeoServer PR containing
the follow up changes to have jai-ext enabled by default
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hudson
January 22, 2019, 10:15am
3
See <https://build.geoserver.org/job/geoserver-master/6504/display/redirect> ;
[...truncated 1004.58 KB...]
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-csw ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/classes> ;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes> ;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports> ;
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.829 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.218 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.369 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.705 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.944 s]
[INFO] Main Module ........................................ SUCCESS [01:24 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.107 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:22 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.449 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.907 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.939 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 20.333 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 25.151 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.050 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:57 min]
[INFO] Web Map Service Module ............................. FAILURE [02:30 min]
[INFO] gs-rest ............................................ SUCCESS [ 13.802 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:50 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.363 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 20.724 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.144 s]
[INFO] Core UI Module ..................................... SUCCESS [01:34 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.976 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.069 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:43 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:37 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.753 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.445 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.097 s]
[INFO] Printing Module .................................... SUCCESS [ 13.800 s]
[INFO] Community Space .................................... SUCCESS [ 0.060 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.074 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 14.290 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 17.125 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.640 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.938 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.792 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.341 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.352 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.645 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.462 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.096 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.690 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.472 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.101 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:35 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.665 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.133 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.540 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.874 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.621 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.545 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.277 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.838 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.722 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.172 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.053 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.907 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.059 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.608 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 18.567 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.027 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.445 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.937 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 50.064 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.618 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.078 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.021 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.000 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.080 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.601 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 16.145 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.379 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.580 s]
[INFO] Total time: 13:30 min (Wall Clock)
[INFO] Finished at: 2019-01-22T10:15:42Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
January 22, 2019, 6:48pm
4
