See <http://ares.opengeo.org/jenkins/job/geoserver-master/675/>
Started by an SCM change
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/>
Checkout:geoserver-master / <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/> - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 03e726d344ffb20ee18e6e27c612a9ef95642f33 (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
hudson.plugins.git.GitException: Command "git fetch -t origin +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: fatal: unable to connect to github.com:
github.com: Name or service not known
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:790)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:756)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.fetch(CliGitAPIImpl.java:144)
at hudson.plugins.git.GitAPI.fetch(GitAPI.java:221)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:791)
at hudson.plugins.git.GitSCM.access$000(GitSCM.java:58)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:983)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:948)
at hudson.FilePath.act(FilePath.java:914)
at hudson.FilePath.act(FilePath.java:887)
at hudson.plugins.git.GitSCM.determineRevisionToBuild(GitSCM.java:948)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1114)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1320)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:609)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:518)
at hudson.model.Run.execute(Run.java:1689)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:231)
ERROR: Could not fetch from any repository
java.io.IOException: Could not fetch from any repository
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:992)
