See <http://ares.opengeo.org/jenkins/job/geoserver-master/714/>
[...truncated 20369 lines...]
Results :
Tests run: 110, Failures: 0, Errors: 0, Skipped: 3
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-kml ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/gs-kml-2.6-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-kml ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/gs-kml-2.6-SNAPSHOT-tests.jar>
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-kml >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-kml ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing links to old website
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.08.2014 @ 13:55:08 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Aug-2014 19:45
[INFO] [GitCommitIdMojo] build.build.time = 16.08.2014 @ 20:08:32 UTC
[INFO] [GitCommitIdMojo] build.branch = e9193aaabe12af4c1f5e9323cd5dcfc5fb647fa1
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e9193aa
[INFO] [GitCommitIdMojo] build.commit.id = e9193aaabe12af4c1f5e9323cd5dcfc5fb647fa1
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing links to old website
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-kml <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-kml ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/gs-kml-2.6-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-kml >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-kml <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-kml ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/gs-kml-2.6-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-kml ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/gs-kml-2.6-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.6-SNAPSHOT/gs-kml-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.6-SNAPSHOT/gs-kml-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/gs-kml-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.6-SNAPSHOT/gs-kml-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/gs-kml-2.6-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.6-SNAPSHOT/gs-kml-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/gs-kml-2.6-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.6-SNAPSHOT/gs-kml-2.6-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.532s]
[INFO] Core Platform Module .............................. SUCCESS [14.633s]
[INFO] Open Web Service Module ........................... SUCCESS [16.721s]
[INFO] Main Module ....................................... SUCCESS [3:17.209s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.810s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:29.854s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:06.259s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.251s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:21.303s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:10.657s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [3:15.209s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:00.176s]
[INFO] Web Map Service Module ............................ SUCCESS [5:22.281s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:20.089s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [5.191s]
[INFO] REST Support Module ............................... SUCCESS [45.177s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.518s]
[INFO] Core UI Module .................................... SUCCESS [2:29.228s]
[INFO] WFS UI Module ..................................... SUCCESS [46.037s]
[INFO] Security UI Modules ............................... SUCCESS [0.575s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.186s]
[INFO] Printing Module ................................... SUCCESS [46.655s]
[INFO] Community Space ................................... SUCCESS [0.181s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.437s]
[INFO] Application Schema Support ........................ SUCCESS [0.171s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.132s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.644s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.369s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.164s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.613s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.389s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.351s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.120s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.676s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [34.871s]
[INFO] Excel Output Format ............................... SUCCESS [42.497s]
[INFO] Chart external graphics support ................... SUCCESS [2.281s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.911s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.891s]
[INFO] OWS request flow controller ....................... SUCCESS [28.472s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.200s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:51.921s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.399s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.794s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [1.459s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [52.388s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.222s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.515s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [49.144s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.394s]
[INFO] DXF WFS output format ............................. SUCCESS [55.114s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.183s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:16.108s (Wall Clock)
[INFO] Finished at: Sat Aug 16 20:08:32 UTC 2014
[INFO] Final Memory: 60M/179M
[ERROR] Failed to execute goal on project gs-gwc: Could not resolve dependencies for project org.geoserver:gs-gwc:jar:2.6-SNAPSHOT: The following artifacts could not be resolved: org.geowebcache:gwc-core:jar:1.6-SNAPSHOT, org.geowebcache:gwc-georss:jar:1.6-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.6-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.6-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.6-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.6-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.6-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.6-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.6-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.6-SNAPSHOT: Could not find artifact org.geowebcache:gwc-core:jar:1.6-SNAPSHOT in boundless (http://repo.boundlessgeo.com/main) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
