See <http://ares.opengeo.org/jenkins/job/geoserver-master/720/changes>
Changes:
[ksmith] Use correct CRS representation and axis order for WFS GeoJSON
[ksmith] Document GEOSERVER_GEOJSON_LEGACY_CRS
[...truncated 19118 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
18 Aug 15:42:39 WARN [geoserver.ows] - OWS20SEH: handling org.geoserver.wcs2_0.exception.WCS20Exception: Invalid Band Name
HTTPcode:404
18 Aug 15:42:39 INFO [geoserver.wcs] -
Request: getServiceInfo
Request: getCoverage
extension:
contents[0]:
name = rangeSubset
namespace = http://www.opengis.net/wcs/range-subsetting/1.0
objectContent = net.opengis.wcs20.impl.RangeSubsetTypeImpl@anonymised.com
service = WCS
version = 2.0.1
baseUrl = http://localhost:8080/geoserver/
coverageId = wcs__multiband
extension:
contents[0]:
name = rangeSubset
service = WCS
version = 2.0.1
extension:
contents[0]:
name = rangeSubset
service = WCS
version = 2.0.1
extension:
contents[0]:
name = rangeSubset
service = WCS
version = 2.0.1
coverageId = wcs__BlueMarble
18 Aug 15:42:39 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Mon Aug 18 15:42:37 UTC 2014]; root of context hierarchy
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.644 sec
Running org.geoserver.wcs2_0.xml.ScalingExtentionTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
18 Aug 15:42:39 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Mon Aug 18 15:42:39 UTC 2014]; root of context hierarchy
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'nullLockProvider' of type [class org.geoserver.platform.resource.NullLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'lockProvider' of type [class org.geoserver.platform.resource.GlobalLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceStore' of type [class org.geoserver.platform.resource.DataDirectoryResourceStore] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs20Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs111Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'extensions' of type [class org.geoserver.platform.GeoServerExtensions] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'dataDirectory' of type [class org.geoserver.config.GeoServerDataDirectory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [test.GeoServerTestApplicationContext] - Bean 'authenticationManager' of type [class org.geoserver.security.GeoServerSecurityManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'Streams'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'MapNeatline'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'Forests'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'Bridges'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'RoadSegments'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'raster'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'BasicPolygons'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'NamedPlaces'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'Lakes'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'DividedRoutes'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'Default'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'Buildings'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded style 'Ponds'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded default workspace gs
18 Aug 15:42:40 INFO [org.geoserver] - Loaded workspace 'sf'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded workspace 'wcs'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded workspace 'cite'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded workspace 'cgf'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded workspace 'cdf'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded workspace 'gs'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded data store 'sf'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded feature type 'sf'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded layer 'GenericEntity'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded layer 'PrimitiveGeoFeature'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded layer 'AggregateGeoFeature'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded coverage store 'RotatedCad'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded coverage 'RotatedCad'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded layer 'RotatedCad'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded coverage store 'World'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded coverage 'World'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded layer 'World'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded coverage store 'multiband'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded coverage 'multiband'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded layer 'multiband'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded coverage store 'BlueMarble'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded coverage 'BlueMarble'
18 Aug 15:42:40 INFO [org.geoserver] - Loaded layer 'BlueMarble'
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.978s]
[INFO] Core Platform Module .............................. SUCCESS [14.986s]
[INFO] Open Web Service Module ........................... SUCCESS [19.172s]
[INFO] Main Module ....................................... SUCCESS [3:22.509s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.214s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:21.021s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [50.773s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.565s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:18.838s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:30.111s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [4:49.801s]
[INFO] Web Map Service Module ............................ FAILURE [6:25.054s]
[INFO] REST Support Module ............................... SUCCESS [46.849s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.494s]
[INFO] Core UI Module .................................... SUCCESS [2:32.824s]
[INFO] WFS UI Module ..................................... SUCCESS [44.175s]
[INFO] Security UI Modules ............................... SUCCESS [0.526s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.211s]
[INFO] Printing Module ................................... SUCCESS [40.788s]
[INFO] Community Space ................................... SUCCESS [0.305s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.849s]
[INFO] Application Schema Support ........................ SUCCESS [0.212s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.494s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.958s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.869s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.572s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.698s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.452s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.368s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.905s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.446s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [38.488s]
[INFO] Excel Output Format ............................... SUCCESS [41.182s]
[INFO] Chart external graphics support ................... SUCCESS [2.606s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.036s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.032s]
[INFO] OWS request flow controller ....................... SUCCESS [29.725s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.335s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.017s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.902s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [51.498s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.287s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.640s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.306s]
[INFO] DXF WFS output format ............................. SUCCESS [38.176s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.299s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 18:56.050s (Wall Clock)
[INFO] Finished at: Mon Aug 18 15:42:40 UTC 2014
[INFO] Final Memory: 58M/198M
18 Aug 15:42:41 INFO [org.geoserver] - Loaded coverage store 'DEM'
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
