[Geoserver-devel] Build failed in Jenkins: geoserver-master #7464
See <https://build.geoserver.org/job/geoserver-master/7464/display/redirect&gt;
[...truncated 1.09 MB...]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/surefire-reports&gt;
T E S T S
Running org.geoserver.importer.web.AbstractDBPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.886 sec
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.803 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [94/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 612.499 sec
Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.293 sec
Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.912 sec
Running org.geoserver.geofence.rest.RulesRestControllerTest
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.776 sec
Running org.geoserver.geofence.web.GeofenceRulesModelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.071 sec
Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.059 sec
Running org.geoserver.geofence.web.GeofenceServerPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.765 sec
Results :
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.284 s]
[INFO] Core Platform Module ............................... SUCCESS [ 8.682 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.110 s]
[INFO] Main Module ........................................ SUCCESS [ 54.166 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.166 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:38 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.505 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 25.541 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.818 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.084 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.291 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 53.685 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:18 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:40 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 17.717 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.369 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [04:27 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:19 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.958 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 14.486 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [01:17 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.081 s]
[INFO] Core UI Module ..................................... SUCCESS [ 56.939 s]
[INFO] WMS UI Module ...................................... SUCCESS [10:33 min]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 5.955 s]
[INFO] Demos Module ....................................... SUCCESS [02:44 min]
[INFO] WCS UI Module ...................................... SUCCESS [ 7.527 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.031 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:01 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [12:31 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.317 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.208 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.037 s]
[INFO] Printing Module .................................... SUCCESS [ 6.541 s]
[INFO] Community Space .................................... SUCCESS [ 0.052 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:31 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.732 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.896 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.813 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.741 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.566 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.201 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.210 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.217 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.217 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.209 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.321 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.133 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [05:38 min]
[INFO] OGR WPS ............................................ SUCCESS [ 4.432 s]
[INFO] Excel Output Format ................................ SUCCESS [ 7.565 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.388 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.423 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.437 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.464 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 11.687 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 16.413 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.356 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.439 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.026 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 1.719 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.249 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.281 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 9.540 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.050 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.191 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.216 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [06:15 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.915 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.420 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.566 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.464 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [02:17 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.299 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.037 s]
[INFO] Importer Core Module ............................... SUCCESS [ 24.362 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 26.595 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [06:59 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 8.109 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.058 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [02:20 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [03:13 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.422 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.570 s]
[INFO] REST SLD service ................................... SUCCESS [04:04 min]
[INFO] GeoFence security integration ...................... SUCCESS [03:13 min]
[INFO] GeoFence Server .................................... SUCCESS [10:31 min]
[INFO] BUILD FAILURE
[INFO] Total time: 48:05 min (Wall Clock)
[INFO] Finished at: 2019-07-02T11:03:14Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-master/7465/display/redirect&gt;
