[Geoserver-devel] Build failed in Jenkins: geoserver-master #7486
See <https://build.geoserver.org/job/geoserver-master/7486/display/redirect?page=changes&gt;
Changes:
[noreply] Update PULL_REQUEST_TEMPLATE.md
[...truncated 1.78 MB...]
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.731 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.587 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [96/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 270.303 s - in org.geoserver.geofence.internal.InternalUserResolverTest
[INFO] Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.316 s - in org.geoserver.geofence.rest.AdminRulesRestControllerTest
[INFO] Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.983 s - in org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Running org.geoserver.geofence.rest.RulesRestControllerTest
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.818 s - in org.geoserver.geofence.rest.RulesRestControllerTest
[INFO] Running org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.1 s - in org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.476 s - in org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.123 s - in org.geoserver.geofence.web.GeofenceServerPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 17, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 22.820 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.704 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.198 s]
[INFO] Main Module ........................................ SUCCESS [01:14 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.137 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:28 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.157 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.653 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.722 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.356 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.395 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 58.742 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:09 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:06 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.693 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.289 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:32 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:30 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.408 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.234 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.387 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.080 s]
[INFO] Core UI Module ..................................... SUCCESS [01:00 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 28.749 s]
[INFO] GWC UI Module ...................................... SUCCESS [05:53 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.488 s]
[INFO] Demos Module ....................................... SUCCESS [ 33.900 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 7.746 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.036 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:04 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [04:45 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.102 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.711 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.037 s]
[INFO] Printing Module .................................... SUCCESS [ 31.415 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 10.497 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.029 s]
[INFO] Application Schema Integration Test ................ SUCCESS [04:34 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.463 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.377 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.223 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.839 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.480 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.420 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.240 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.117 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.625 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.410 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.394 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.751 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... FAILURE [ 53.841 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.476 s]
[INFO] Chart external graphics support .................... SUCCESS [ 5.628 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.505 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.143 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.654 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.235 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.446 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.035 s]
[INFO] Core Monitor Extension ............................. SUCCESS [01:05 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.326 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.385 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 14.213 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 20.325 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.004 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.030 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.692 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.216 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [09:52 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.106 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.032 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.845 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [02:33 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.634 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.266 s]
[INFO] Importer Core Module ............................... SUCCESS [ 27.836 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 29.385 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [03:52 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 10.939 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 28.517 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [04:12 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [04:04 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 18.704 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.086 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.848 s]
[INFO] REST SLD service ................................... SUCCESS [02:05 min]
[INFO] GeoFence security integration ...................... SUCCESS [04:56 min]
[INFO] GeoFence Server .................................... SUCCESS [05:15 min]
[INFO] Authentication by unique url key ................... SUCCESS [04:59 min]
[INFO] BUILD FAILURE
[INFO] Total time: 42:23 min (Wall Clock)
[INFO] Finished at: 2019-07-12T11:02:43Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/7487/display/redirect&gt;
