[Geoserver-devel] Build failed in Jenkins: geoserver-master #7533
See <https://build.geoserver.org/job/geoserver-master/7533/display/redirect&gt;
[...truncated 930.12 KB...]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-sec-cas ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO]
[INFO] T E S T S
[INFO] Running org.geoserver.wfs.web.CSWAdminPageTest
[INFO] Running org.geoserver.security.cas.CasAuthenticationTest
[WARNING] Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.607 s - in org.geoserver.security.cas.CasAuthenticationTest
[INFO] Running org.geoserver.security.cas.CasFilterConfigValidatorTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 s - in org.geoserver.security.cas.CasFilterConfigValidatorTest
[INFO]
[INFO] Results:
[INFO]
[WARNING] Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.16-SNAPSHOT/gs-sec-cas-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [72/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.54 s - in org.geoserver.wfs.web.CSWAdminPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.582 s]
[INFO] Core Platform Module ............................... SUCCESS [ 9.566 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.806 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.050 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:24 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.639 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 14.930 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.738 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.805 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.852 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:05 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:12 min]
[INFO] Web Map Service Module ............................. FAILURE [02:00 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 6.988 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:32 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.554 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.658 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.085 s]
[INFO] Core UI Module ..................................... SUCCESS [ 55.362 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 7.043 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.033 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:06 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 47.445 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.433 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.923 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.093 s]
[INFO] Printing Module .................................... SUCCESS [ 7.260 s]
[INFO] Community Space .................................... SUCCESS [ 0.068 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.055 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.839 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.879 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.999 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.750 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.598 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.247 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.218 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.574 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.224 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.286 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.866 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.945 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.086 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.792 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.438 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.419 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.391 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.718 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.363 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.660 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.437 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.034 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.386 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.312 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.116 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.052 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.774 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.062 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 27.071 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.894 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.024 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.553 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.074 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.066 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 8.955 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.521 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.674 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 09:39 min (Wall Clock)
[INFO] Finished at: 2019-08-11T15:31:35Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-master/7534/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Improving integration when service is spread on various controllers with
[...truncated 929.63 KB...]
[INFO]
[INFO]
[INFO] -----------------< org.geoserver.extension:gs-web-sec >-----------------
[INFO] Building GeoServer Security Extension Web Modules 2.16-SNAPSHOT [71/100]
[INFO] --------------------------------[ pom ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-sec/2.16-SNAPSHOT/gs-web-sec-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-sec/2.16-SNAPSHOT/gs-web-sec-2.16-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.053 s - in org.geoserver.wps.ppio.DXFPPIOTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.654 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.639 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.995 s]
[INFO] Main Module ........................................ SUCCESS [01:04 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.134 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:35 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 47.494 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.078 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.868 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.983 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.672 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:22 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:33 min]
[INFO] Web Map Service Module ............................. FAILURE [02:35 min]
[INFO] gs-rest ............................................ SUCCESS [ 10.164 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:53 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.902 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.412 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.230 s]
[INFO] Core UI Module ..................................... SUCCESS [01:14 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 8.688 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.040 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:11 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 45.360 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.619 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.683 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.057 s]
[INFO] Printing Module .................................... SUCCESS [ 8.082 s]
[INFO] Community Space .................................... SUCCESS [ 0.081 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.284 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.093 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.507 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.848 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.711 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.424 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.300 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.806 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.314 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.073 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.425 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.921 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.049 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 54.679 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.658 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.926 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.521 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.491 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.540 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.344 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 6.635 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.478 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.560 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.033 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 1.983 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.281 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.446 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.046 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.632 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.603 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 22.936 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.697 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.081 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.866 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.350 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.043 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.215 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.790 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.126 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.592 s]
[INFO] Total time: 11:03 min (Wall Clock)
[INFO] Finished at: 2019-08-12T12:48:15Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/7535/display/redirect&gt;
