[Geoserver-devel] Build failed in Jenkins: geoserver-master #7541
See <https://build.geoserver.org/job/geoserver-master/7541/display/redirect?page=changes&gt;
Changes:
[noreply] GEOS-9290 jdbcconfig: update catalog info references (#3696)
[...truncated 1.09 MB...]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.708 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.638 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [90/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
[INFO] Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 206.221 s - in org.geoserver.importer.bdb.BDBImportStoreTest
[INFO] Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.667 s - in org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.215 s - in org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 3.979 s]
[INFO] Core Platform Module ............................... SUCCESS [ 9.138 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.356 s]
[INFO] Main Module ........................................ SUCCESS [ 55.707 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.047 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:22 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.226 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.130 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.473 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.392 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.225 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:05 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:06 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:57 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 17.067 s]
[INFO] gs-rest ............................................ SUCCESS [ 6.845 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 54.466 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:27 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.365 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.794 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.297 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.059 s]
[INFO] Core UI Module ..................................... SUCCESS [ 51.954 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 21.999 s]
[INFO] GWC UI Module ...................................... SUCCESS [02:30 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.690 s]
[INFO] Demos Module ....................................... SUCCESS [ 12.388 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.709 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.036 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:03 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [06:42 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.416 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.446 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SUCCESS [ 7.186 s]
[INFO] Community Space .................................... SUCCESS [ 0.058 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [06:29 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.462 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.630 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.672 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.747 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.574 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.210 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.209 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.475 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.492 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.218 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.277 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.930 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 8.279 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.399 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.437 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.429 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.573 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.961 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.419 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.030 s]
[INFO] Core Monitor Extension ............................. SUCCESS [02:48 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.111 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.267 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.490 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 9.651 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.030 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 3.728 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.722 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [03:57 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.734 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.057 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.858 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.038 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.700 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.042 s]
[INFO] Importer Core Module ............................... SUCCESS [ 28.408 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 27.727 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [03:30 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 7.970 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.111 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 24.332 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.279 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 8.648 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.586 s]
[INFO] REST SLD service ................................... SUCCESS [06:53 min]
[INFO] GeoFence security integration ...................... SUCCESS [ 24.352 s]
[INFO] GeoFence Server .................................... SUCCESS [06:02 min]
[INFO] Authentication by unique url key ................... SUCCESS [03:31 min]
[INFO] BUILD FAILURE
[INFO] Total time: 32:57 min (Wall Clock)
[INFO] Finished at: 2019-08-14T12:04:06Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/7542/display/redirect&gt;
