[Geoserver-devel] Build failed in Jenkins: geoserver-master #763
See <http://ares.opengeo.org/jenkins/job/geoserver-master/763/&gt;
[...truncated 20753 lines...]
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
  at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
  at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
  at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
  at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
  at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:44)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1440)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1375)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:924)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:907)
  at org.geoserver.gwc.GWCDataSecurityTest.testCroppedMosaic(GWCDataSecurityTest.java:153)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
  at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
  at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
  ... 176 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 36.093 sec
Running org.geoserver.gwc.GWCIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.807 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.568 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.922 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.545 sec
Results :
Tests in error:
  testClipRectangle(org.geoserver.wps.gs.ClipProcessTest): java.util.HashMap cannot be cast to net.opengis.wfs.FeatureCollectionType
Tests run: 163, Failures: 0, Errors: 1, Skipped: 0
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.612s]
[INFO] Core Platform Module .............................. SUCCESS [15.746s]
[INFO] Open Web Service Module ........................... SUCCESS [17.733s]
[INFO] Main Module ....................................... SUCCESS [3:21.857s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.094s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:16.164s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [48.746s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.227s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:12.236s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:16.669s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:07.691s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:38.204s]
[INFO] Web Map Service Module ............................ SUCCESS [5:22.159s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.356s]
[INFO] REST Support Module ............................... SUCCESS [46.595s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.663s]
[INFO] Core UI Module .................................... SUCCESS [2:37.505s]
[INFO] WFS UI Module ..................................... SUCCESS [41.793s]
[INFO] Security UI Modules ............................... SUCCESS [0.332s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.322s]
[INFO] Printing Module ................................... SUCCESS [36.086s]
[INFO] Community Space ................................... SUCCESS [0.289s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.791s]
[INFO] Application Schema Support ........................ SUCCESS [0.260s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.062s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.020s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.683s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.160s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.849s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.623s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.440s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.829s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.818s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.856s]
[INFO] Excel Output Format ............................... SUCCESS [39.686s]
[INFO] Chart external graphics support ................... SUCCESS [1.803s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.171s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.250s]
[INFO] OWS request flow controller ....................... SUCCESS [27.167s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.407s]
[INFO] Web Processing Service Module ..................... FAILURE [4:29.017s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.734s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.320s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.268s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [54.088s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.266s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.282s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.971s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.249s]
[INFO] DXF WFS output format ............................. SUCCESS [39.816s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.339s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 21:58.051s (Wall Clock)
[INFO] Finished at: Sat Sep 06 11:34:28 UTC 2014
[INFO] Final Memory: 61M/175M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/764/&gt;
[...truncated 20741 lines...]
  ... 176 more
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.544 sec
Running org.geoserver.wps.gs.UniqueProcessTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 36.258 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.697 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.75 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.639 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.233 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.35 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.594 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.012 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.203s]
[INFO] Core Platform Module .............................. SUCCESS [15.101s]
[INFO] Open Web Service Module ........................... SUCCESS [17.768s]
[INFO] Main Module ....................................... SUCCESS [3:13.102s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.885s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.389s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [46.224s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.997s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:12.908s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.096s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.469s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:42.007s]
[INFO] Web Map Service Module ............................ SUCCESS [5:18.713s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.095s]
[INFO] REST Support Module ............................... SUCCESS [44.847s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.631s]
[INFO] Core UI Module .................................... SUCCESS [2:34.666s]
[INFO] WFS UI Module ..................................... SUCCESS [44.363s]
[INFO] Security UI Modules ............................... SUCCESS [0.405s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.283s]
[INFO] Printing Module ................................... SUCCESS [38.387s]
[INFO] Community Space ................................... SUCCESS [0.267s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.796s]
[INFO] Application Schema Support ........................ SUCCESS [0.249s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.616s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.027s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.776s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.132s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.917s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.579s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.611s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.051s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.747s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.705s]
[INFO] Excel Output Format ............................... SUCCESS [40.976s]
[INFO] Chart external graphics support ................... SUCCESS [2.588s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.234s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.182s]
[INFO] OWS request flow controller ....................... SUCCESS [29.162s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.209s]
[INFO] Web Processing Service Module ..................... FAILURE [4:30.569s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.372s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.582s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.387s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [49.965s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.371s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.261s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.284s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.247s]
[INFO] DXF WFS output format ............................. SUCCESS [40.182s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.201s]
[INFO] Total time: 21:48.087s (Wall Clock)
[INFO] Finished at: Sun Sep 07 19:47:15 UTC 2014
[INFO] Final Memory: 61M/170M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/766/&gt;
[...truncated 46551 lines...]
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-ftp ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #713 from strk/patch-1
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 05.09.2014 @ 16:19:57 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 07-Sep-2014 22:53
[INFO] [GitCommitIdMojo] build.build.time = 07.09.2014 @ 22:54:55 UTC
[INFO] [GitCommitIdMojo] build.branch = d58cabd6d6cd1a2a68dd94a66a6a23d33c0790c4
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d58cabd
[INFO] [GitCommitIdMojo] build.commit.id = d58cabd6d6cd1a2a68dd94a66a6a23d33c0790c4
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #713 from strk/patch-1
Update postgis website to postgis.net
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ftp ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-ftp ---
[INFO] Compiling 10 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/target/classes&gt;
[WARNING] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java&gt;:\[24,47\] ACONST_NULL is internal proprietary API and may be removed in a future release
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-ftp ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-ftp ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-ftp ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-ftp ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/target/gs-ftp-2.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-ftp ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/target/gs-ftp-2.7-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-ftp >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 07.09.2014 @ 22:54:58 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-ftp <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-ftp ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/target/gs-ftp-2.7-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ftp >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ftp <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ftp ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-ftp ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/target/gs-ftp-2.7-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/target/gs-ftp-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/ftp/target/gs-ftp-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-ftp ---
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 96.8 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140907.225458-27.jar
2/22 KB
4/22 KB
6/22 KB
8/22 KB
10/22 KB
12/22 KB
14/22 KB
16/22 KB
18/22 KB
20/22 KB
22/22 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140907.225458-27.jar (22 KB at 374.8 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140907.225458-27.pom
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140907.225458-27.pom (2 KB at 21.1 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml
495/495 B
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (495 B at 28.4 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 2.2 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml
461/461 B
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (461 B at 11.3 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140907.225458-27-tests.jar
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140907.225458-27-tests.jar (2 KB at 41.3 KB/sec)
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 117.2 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140907.225458-27-sources.jar
2/17 KB
4/17 KB
6/17 KB
8/17 KB
10/17 KB
12/17 KB
14/17 KB
16/17 KB
17/17 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140907.225458-27-sources.jar (17 KB at 370.2 KB/sec)
2/2 KB
[INFO]
[INFO] Building GeoServer Web Application 2.7-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-app ---
[INFO] [GitCommitIdMojo] build.build.time = 07.09.2014 @ 22:55:02 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-app ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/src/main/java&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-app ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-app ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.7-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app >>>
[INFO]
[ERROR] GC overhead limit exceeded -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/OutOfMemoryError
See <http://ares.opengeo.org/jenkins/job/geoserver-master/767/&gt;
[...truncated 46632 lines...]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 08-Sep-2014 07:32
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2014 @ 07:33:50 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2014 @ 07:33:53 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 55.3 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.073353-28.jar
2/22 KB
4/22 KB
6/22 KB
8/22 KB
10/22 KB
12/22 KB
14/22 KB
16/22 KB
18/22 KB
20/22 KB
22/22 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.073353-28.jar (22 KB at 314.2 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.073353-28.pom
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.073353-28.pom (2 KB at 14.7 KB/sec)
495/495 B
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (495 B at 34.5 KB/sec)
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 106.5 KB/sec)
461/461 B
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (461 B at 12.5 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.073353-28-tests.jar
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.073353-28-tests.jar (2 KB at 33.0 KB/sec)
2/2 KB
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.073353-28-sources.jar
2/17 KB
4/17 KB
6/17 KB
8/17 KB
10/17 KB
12/17 KB
14/17 KB
16/17 KB
17/17 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.073353-28-sources.jar (17 KB at 268.7 KB/sec)
2/2 KB
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2014 @ 07:33:57 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/768/&gt;
[...truncated 46469 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 08-Sep-2014 20:46
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2014 @ 20:48:27 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2014 @ 20:48:30 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 58.1 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.204830-29.jar
2/22 KB
4/22 KB
6/22 KB
8/22 KB
10/22 KB
12/22 KB
14/22 KB
16/22 KB
18/22 KB
20/22 KB
22/22 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.204830-29.jar (22 KB at 140.6 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.204830-29.pom
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.204830-29.pom (2 KB at 16.7 KB/sec)
461/461 B
[WARNING] Checksum validation failed, expected fa126b76f92011c6fbb539940c1acaa886568b5d but is 8ad7da79f488917801c9ce3ca1ec5240d0a355dd for http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml
495/495 B
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (495 B at 12.4 KB/sec)
2/2 KB
461/461 B
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (461 B at 0.4 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.204830-29-tests.jar
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.204830-29-tests.jar (2 KB at 21.6 KB/sec)
2/2 KB
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.204830-29-sources.jar
2/17 KB
4/17 KB
6/17 KB
8/17 KB
10/17 KB
12/17 KB
14/17 KB
16/17 KB
17/17 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140908.204830-29-sources.jar (17 KB at 133.3 KB/sec)
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 130.2 KB/sec)
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2014 @ 20:48:35 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/769/&gt;
[...truncated 46615 lines...]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 09-Sep-2014 15:08
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2014 @ 15:10:14 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2014 @ 15:10:16 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2014 @ 15:10:17 UTC
[INFO]
[INFO]
[INFO]
[INFO]
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 3.7 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.151017-30.jar
2/22 KB
4/22 KB
6/22 KB
8/22 KB
10/22 KB
12/22 KB
14/22 KB
16/22 KB
18/22 KB
20/22 KB
22/22 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.151017-30.jar (22 KB at 80.3 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.151017-30.pom
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.151017-30.pom (2 KB at 13.5 KB/sec)
495/495 B
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (495 B at 22.0 KB/sec)
2/2 KB
461/461 B
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (461 B at 4.6 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.151017-30-tests.jar
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.151017-30-tests.jar (2 KB at 1.1 KB/sec)
2/2 KB
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.151017-30-sources.jar
2/17 KB
4/17 KB
6/17 KB
8/17 KB
10/17 KB
12/17 KB
14/17 KB
16/17 KB
17/17 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.151017-30-sources.jar (17 KB at 164.9 KB/sec)
2/2 KB
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2014 @ 15:10:23 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR] Java heap space -> [Help 1]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/770/&gt;
[...truncated 46500 lines...]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 09-Sep-2014 18:36
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2014 @ 18:37:40 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2014 @ 18:37:43 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/maven-metadata.xml (2 KB at 40.0 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.183743-31.jar
2/22 KB
4/22 KB
6/22 KB
8/22 KB
10/22 KB
12/22 KB
14/22 KB
16/22 KB
18/22 KB
20/22 KB
22/22 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.183743-31.jar (22 KB at 388.5 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.183743-31.pom
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.183743-31.pom (2 KB at 29.9 KB/sec)
495/495 B
2/2 KB
461/461 B
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/maven-metadata.xml (461 B at 16.1 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.183743-31-tests.jar
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.183743-31-tests.jar (2 KB at 41.3 KB/sec)
2/2 KB
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.183743-31-sources.jar
2/17 KB
4/17 KB
6/17 KB
8/17 KB
10/17 KB
12/17 KB
14/17 KB
16/17 KB
17/17 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-ftp/2.7-SNAPSHOT/gs-ftp-2.7-20140909.183743-31-sources.jar (17 KB at 131.2 KB/sec)
2/2 KB
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2014 @ 18:37:48 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/771/changes&gt;
